Old 03-23-2002, 09:15 PM   #1411
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
LOL
Hey guys!!! Chris is TQ at the Carpet Nats and my buddy that's racing and helping run the race says he is SHMOOOKIN' fast!!
Man, I'm sooo glad to see a Yok kickin butt again. He said Mo finally got a good run in today, but I don't think he's where he wanted to be in the qualifying.
Go Toss- U DA MAN!!
BigDogRacing is offline   Reply With Quote
Old 03-23-2002, 10:09 PM   #1412
Simon K's Avatar
Wink
Josh,
Car looks good with that top deck.
Had a cool days racing, even with very few cars at the track, perfect weather and the car ran really well. After changing to the 3 deg caster blocks it actually felt very similar to before(5 deg).
Probably didn't help that I changed a whole pile of things during the week, hard to tell exactly what-did-what
Simon K is offline   Reply With Quote
Old 03-23-2002, 11:45 PM   #1413
yeah bigdog, nice to see yoks are on the winning edge again!!!
i'll be racing on another track which is an indoor asphalt and the traction is very good maybe because its very new.
i'll be trying bigdog racing set-up using the upper hinge pin on the bulkhead both front and rear! i only have losi's 37.5 and 27.5 oil. i hope this work!
bigdog, why is that tossilini and other yoke drivers prefer not to use the rear sway bars.
how can i adjust the droop on the sp? got no idea on this!
maski is offline   Reply With Quote
Old 03-24-2002, 01:28 AM   #1414
TK
Maski : The reason why the pro drivers dont use a rear sway bar is because it takes away rear traction. Most pro drivers perfer to have the most traction possible so adding a rear sway bar wouldnt help that. They would how ever use a rear sway bar if they had a push and felt like putting it on.
Concerning the droop issue. The way we adjust droop is by the length of our shocks. The longer they are the more you have. The shorter the shock the less droop you.
Hope this Helps,
TK
TK is offline   Reply With Quote
Old 03-24-2002, 05:14 AM   #1415
Maski- TK is correct about both questions. I would like to add that Masami originally started the trend of using a relatively stiffer rear spring/no swaybar combination as opposed to the softer or equal (same as front) rear spring with a swaybar. In my opinion, the stiffer rear spring/no swaybar combination gives more steering and the car rotates through the turn better given the situation where both setups are optomized and everything else is equal.
Old 03-24-2002, 09:52 AM   #1416
Moderator
Speedo's Avatar
I agree, looks like Tossolini may finally have fiured the setup out
Was it Masami? I thought it was BBaker, but I could be wrong.
I agree, doesn't look like mo would be too happy with where he's sitting.
Speedo
Speedo is offline   Reply With Quote
Old 03-24-2002, 10:41 AM   #1417
thanks guys, now i'll have to work my way without using the rear swaybars.
Old 03-24-2002, 06:34 PM   #1418
Registered User
I got this from the Trinity site: Tossolini TQ's and wins Sedan Mod at the ROAR Carpet Nats
thatdog is offline   Reply With Quote
Old 03-24-2002, 08:23 PM   #1419
STLNLST's Avatar
Trader Rating: 19 (100%+)
TOASTY!!!!!!
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-24-2002, 11:48 PM   #1420
sweetpea's Avatar
what is everyone talking about new rear shocks for the mR4tc????? Bear with me, I am deployed overseas and haven't had a chance too check out any updates for the car. I have the worlds............so what is new besides the special chassis?
sweetpea is offline   Reply With Quote
Old 03-25-2002, 01:49 AM   #1421
TK
Sweetpea The new shocks that you are hearing about are just longer ones. They allow the piston to remain in the oil longer.
Other new gagdets include Pink springs, rear arms that u lengthen or shorten wheelbase, a bigger front one way for durabillity, hollow center shaft, hmm I know I am missing something here.
Hope this helps.
TK
Old 03-25-2002, 03:24 AM   #1422
hollow centre shaft? am i right in thinking that this is the one the spur gear rotates around and where the 2 belts meet?
if so, how much weight (grams plz) does it save over the original?
TCRboy is offline   Reply With Quote
Old 03-25-2002, 04:52 AM   #1423
sweetpea's Avatar
anybody got part #'s for all the new hopups??????? Also do the drive cups of the new one way fit the old one way?
Old 03-25-2002, 07:49 AM   #1424
Moderator
Speedo's Avatar
No, the drive cups of the new one don't fit the old one.
I know www.yokomousa.com has some of the part numbers, including for the pink springs and HD one-way.
I would not get the longer shocks though, nobody seems to be running them.
Speedo
Old 03-25-2002, 09:19 AM   #1425
bootyjuice's Avatar
Yokomo MR-4TC-SP score big again over the weedend at the 2002 ROAR Carpet Nats held at the Ripon Raceway. Tosolini the overall winner. Congrats Chris!!!!!!!
Here are the results from the mains:
---- Multiple A Main Scores ----
pos t.pts e.pts 1st 2nd 3rd laps/time name
1 199 99 .... 100 99 99 69/15:08.24 CHRIS TOSOLINI Yokomo
2 199 97 .... 99 97 100 70/15:26.59 MIKE DUMAS
3 198 98 .... 98 100 98 69/15:08.83 PAUL LEMIEUX
4 194 96 .... 97 96 97 69/15:24.03 MARK PAVIDIS
5 193 92 .... 95 98 92 57/13:08.21 BRIAN KINWALD
6 190 94 .... 94 95 95 68/15:31.78 MIKE BLACKSTOCK
7 190 93 .... 93 94 96 67/15:12.69 JIMMY JACOBSON
8 189 92 .... 96 92 93 66/15:09.25 BARRY BAKER
9 186 91 .... 92 91 94 66/15:30.04 CURTIS SCHLAHT Yokomo
10 184 91 .... 91 93 91 34/8:03.09 JOSH CYRUL
Side note from qualifying - Chris was the only driver with a 24 lap run, which also happened to be the fastest qualifying run of the weekend.
Pics of his car and a setup sheet will be up soon at www.yokomousa.com
bootyjuice is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
