Old 02-26-2002, 03:47 PM   #1276
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
The wheel bearings are 6 by 10 by 3mm.
Castor- Darkseid is right, that is the theory, but it doesn't really work that way. Having tried both, I feel that basically the 3 degree blocks give the car a more agressive feel and more steering all round, while the 7 degree blocks smooth the car out.
What castor is doing is raising the front of the car when you turn the wheel. The less castor, the less the front is raised so more weight can be transfered onto the front when slowing down, hence more steering.
Speedo is offline   Reply With Quote
Old 02-26-2002, 03:55 PM   #1277
RAP66's Avatar
Default Speedo.....
On my M2 USA and my Type J I used 0 castor and absolutely loved the way I could throw the car around... U think that with 0 castor the car would drive the similar?
Rich
hehehe
what's the setup for Castle??
Rich Pedro
rap66@rcracing.com
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 02-26-2002, 04:37 PM   #1278
Regional Moderator
Darkseid's Avatar
Speedo: well that theory is what all the major manufacturers place in their set up guides and seem to go by. So I find it kind of hard to believe that what they believe really doesn't work???
But, hey, what do they know?
TLR 22...Tamiya F104...
Old 02-26-2002, 04:53 PM   #1279
Simon K's Avatar
Wink
Used to run the blue alloy front gearbox(less castor) on my old M2 and it definately sharpened things up a bit, steering wise.
I think the three degree blocks will be better if you don't quite have enough steering normally. They should add just that little bit extra.
Simon K is offline   Reply With Quote
Old 02-26-2002, 05:41 PM   #1280
Moderator
Speedo's Avatar
They add quite a bit. They actually give the car a total of 5 degrees castor, with the 2 degrees kickup.
Darkseid, what does Mo know? LOL, that's what he told me, and testing it has proved it true.
They don't make 0 degree blocks for the MR-4, but they do make the 3's, and they will make it much more agressive.
Right now my car is having problems setup wise, I have made the camber link mods, and it still needs a lot of work...
Speedo
Old 02-26-2002, 05:59 PM   #1281
ottoman's Avatar
Thanks for the information. But I didnt see anyone say what degree castor blocks come stock? I just got some 3 degree blocks to try but they only have one hole drilled for the lower mount, and it is the upper hole, which I have never used before, should it have two holes?
ottoman is offline   Reply With Quote
Old 02-26-2002, 07:30 PM   #1282
Moderator
Speedo's Avatar
The car comes stock with 5 degree blocks, plus the 2 degrees of kickup, and you get a total of 7. Using the 3 blocks reduces it to 5. Yep, they only have the upper hole. This raises the roll center. You may want to make your shocks shorter, but I would leave them the same at first, the increased steering from more droop may balance the decreased steering from the higher roll center.
Good luck,
Speedo
Old 02-26-2002, 07:50 PM   #1283
ottoman's Avatar
Thanks Speedo.... boy that seems kinda dumb to make a caster block to let you remove caster but make you run a higher roll center at the same time. Kinda defeats the age old tunning rule of "only change one thing at a time". It would have been nice to give us the option of both holes so we could compare just the caster change.
Old 02-27-2002, 11:27 AM   #1284
when talking about casterblocks. Anyone tested the 1mm trailing steeringblocks?
moonman is offline   Reply With Quote
Old 02-27-2002, 04:34 PM   #1285
Moderator
Speedo's Avatar
Yeah, I agree, I guess they just got lazy and didn't drill a lower hole. That's OK for me, I always use the upper hole, but they should have made a lower one.
Nope, haven't gotten those yet...I'm thinking I could make some pretty easily.
Speedo
Old 03-02-2002, 02:50 PM   #1286
ottoman's Avatar
Speedo
What change can I expect from using the upper hole in the caster block? I run carpet with rubber and both my Mission and my Losi work better with low roll center set ups so I am not sure about raising the roll center but I would like to try less caster.
Old 03-03-2002, 10:00 AM   #1287
Moderator
Speedo's Avatar
Using a higher roll center in the front will make the car less aggressive, which is a good thing with the front one-way. If you had the 3 degree blocks with the lower hole and a front one-way, for me the car would be too aggressive. But if you have the front diff, I used the lower hole most of the time, but the upper hole may be better with the 3 degree blocks.
Speedo
Old 03-03-2002, 07:45 PM   #1288
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Does anyone know the part number for the servo saver piece you need to turn your servo sideways like Masami and Baker used to run? Just out fo curiousity, what chassis did it come off of?
Thanks in advance....
BigDogRacing is offline   Reply With Quote
Old 03-03-2002, 11:39 PM   #1289
rccarracer's Avatar
When I did it on mine, I used the spare servo saver that come with the Special on the parts tree. I had to modify it by cutting off the second hole, so it could clear the battery strap post. I also had to buy a longer turnbuckle for between the servo and servo saver.
rccarracer is offline   Reply With Quote
Old 03-04-2002, 04:33 AM   #1290
Trader Rating: 35 (100%+)
BigDogRacing: If you started with a brand new kit (MR-4TC, Pro, Worlds or Special) you should already have the part. As rccarracer said, the needed part is standard with the kit.
Geppetto is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
