Old 02-23-2002, 01:22 AM   #1261
Da4head's Avatar
Default Chassis tweak
I'm looking for suggestions on how to eliminate chassis tweak. It seems that everytime while driving my special that when I hit the board and even lightly the car will end up steering either way other than straight. Should the upper brace be firmly connected to the bulkheads or should the screws be loose enough to allow the brace to float.?
Da4head is offline   Reply With Quote
Old 02-23-2002, 07:55 AM   #1262
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
You want to have the top deck tightened down pretty well. That is one of the reasons I built a carbon fiber top deck with countersunk holes, the coutersunk holes hole the chassis more rigid and stop it from tweaking as easily.
Speedo is offline   Reply With Quote
Old 02-23-2002, 10:46 AM   #1263
Cosmo's Avatar
Default gearing?
I'm going to start running modified with my Yokomo. It is a medium sized track that has a few tight turns, but mostly pretty open, and I'm running a 12x3 motor. What gearing (64 pitch) would be a good starting place?
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 02-23-2002, 10:58 PM   #1264
Simon K's Avatar
Wink
Da4Head,
Your problem may be due to the soft Yokomo steering ballends being smacked around, a sharp knock may push the ballend further onto the turnbuckle.
Same way that a good hit might alter the camber on your wheels, the balljoints are a fairly soft nylon and not able to handle abuse. Think along the lines of what happens when you hit a kerb, parking your fullsize car.
RPM ones might be an option.
Perhaps loosening your servo saver tension may help, so that takes the impact instead of the ballends?
Simon K is offline   Reply With Quote
Old 02-23-2002, 11:57 PM   #1265
Da4head's Avatar
Simon,
I had this wandering problem last week so I went through the steering linkage and check all the ball ends for play and replaced all ball end cups. The servo saver is set to the manual. Tonight I was playing around with the tweak board and trying a few things. When I intentionally gave the chassis a slight twist and then checking on the tweak board, the results indicated a tweak condition and it stayed that way till I gave it a opposite twist. Now I removed the upper brace and tried it again, same thing.
I conclude that this car is very easy to tweak and will not return to its original state by itself. Judging by the response on this forum is it safe to say that I should counter sink the upper brace to the bulkheads. Any suggestion is very welcome.
Old 02-24-2002, 10:06 AM   #1266
Moderator
Speedo's Avatar
Here is a picture of the top deck I made. It also stiffens up the car alot (my main goal) which helps a bit on carpet.
You shouldn't have that many problems with chassis tweak though. I had the same problem a while back, and it was my servo. You may try borrowing a servo to see if that fixes it.
Speedo
Old 02-24-2002, 10:53 AM   #1267
Cosmo: I run 7.46 final drive ratio with a 12x2.
To calculate final drive ratio (spur/piniong x 2.2)
timing about 7mm, hard brush springs, Reedy Quasar brush
moonman is offline   Reply With Quote
Old 02-24-2002, 01:42 PM   #1268
AE_Racer's Avatar
Send a message via AIM to AE_Racer
Well, looks like im joining the Yok clan. I have a Special on the way, traded an Axis2 for it....Speedo, can you get on AIM? Want to ask you some things
AE_Racer is offline   Reply With Quote
Old 02-24-2002, 02:12 PM   #1269
Yokomo Fan's Avatar
Originally posted by Speedo
ottoman, you probably have the silent belt in, if so, do not soak it in WD40. It will ruin the belt. Mine was the same, but is just starting to loosen up now. I guess it's something we just have to live with.
Yokomo Fan- I have to buy the carbon in sheets, so if I milled out more, they would just be little pieces and be wasted. It is the cost of manufacturing them that is the biggy though, and making more cutouts would only take the engineers more time.
Cosmo, just drain the oil, and gently push the black spacer up from the bottom, then you can push everything out. You might need to replace the small stepped black spacer at the very bottom, and the o-rings. I think the AE shafts are wider, so the shock seals probably are too...
Speedo
I also presume that the weight difference would not be noticeable since carbon is fairly lightweight.
Yokomo Fan is offline   Reply With Quote
Old 02-24-2002, 06:24 PM   #1270
Moderator
Speedo's Avatar
I'm on now AE_Racer...Usually on around 7 or 8 o'clock.
Well, it is pretty dense, but taking that much out wouldn't make a huge difference, and since my car is already underweight, no point.
Old 02-25-2002, 08:08 AM   #1271
Hi all,
I got the Special at the end of December last year. After a month getting used to the one ways, I must say I am thoroughly pleased with this car.
Ras Thavas is offline   Reply With Quote
Old 02-25-2002, 08:12 AM   #1272
Cosmo's Avatar
Ras Thavas- where in VA are you?
Old 02-25-2002, 08:21 AM   #1273
Virginia Beach. I race at Hobbytown there, also have raced at Hobbytown's Newport News store a few times last summer.
Old 02-25-2002, 08:16 PM   #1274
ottoman's Avatar
I am just going through my special (worlds with special upgrade kit) to get it ready to run some carpet again and I have a few questions. I need some wheel bearings and my book says they are 6mm by 10mm. My Boca catalog lists 6x10x2.5 and 6x10x3 so which size do I need? I also noticed that there are some optional caster blocks available. What degree is the std kit block and what effect does changing the caster have on the handling of the car?
ottoman is offline   Reply With Quote
Old 02-26-2002, 09:30 AM   #1275
Regional Moderator
Darkseid's Avatar
ottoman: caster effects the amount of steering your car has going into or coming out of a turn. More caster will make the car turn in less, but with more steering under power out of the corners. Less caster will make the car turn in more, but with less steering coming out of the turn.
Hope this helps.
TLR 22...Tamiya F104...
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
