Old 02-11-2002, 06:12 PM   #1201
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
It was the second weekend on it, but it had been used before. I bought it cheap just to try it out, so it probably has 5 race-days total on it. Still, it only brakes from crashing
Speedo is offline   Reply With Quote
Old 02-12-2002, 06:36 PM   #1202
Originally posted by Speedo
Yeah, looks good john. I've just dremeled out the back of the rear bulkhead cap (little piece that goes over hinge pins) at the bottom so grit will find a way out. Also have a hole under the spur gear because I needed it to use my 96 tooth BK pitch spur, along with a trued down outdrive to match. And will cut out the place where the spur rides under the bulkhead, to match my carbon fiber top deck when I get that made.
One way broke on Saturday, so I have a HD one coming in, along with the kingpin-ballstuds to mount to front link on the castor block, and also have modified the rear hubs to give that a try too.
Hi Speedo,
Any picture to share on your carbo fiber top deck ? I got a piece of fiber glass and planning to do something similar.
ongbenghui is offline   Reply With Quote
Old 02-13-2002, 03:17 PM   #1203
Moderator
Speedo's Avatar
Attached is an image of the solid works design. I'll get some pictures up when I get it cut, hopefully by the end of this week.
Speedo
Old 02-13-2002, 09:04 PM   #1204
Simon K's Avatar
Very nice.
On another tangent....
Can you all please let me know the Minimum weight limit for 4WD Touring cars(in Grams) in each of your countries, and also if there is a difference if you run Foam or rubber tyres/Indoor or Outdoor racing.
Eg. Rubber tyres XXXX grams
Foam tyres XXXX grams.
Thanks.
Simon K is offline   Reply With Quote
Old 02-13-2002, 09:06 PM   #1205
Moderator
Speedo's Avatar
1500 grams foam and rubber, pretty sure
Old 02-14-2002, 03:36 AM   #1206
Regional Moderator
daniz24's Avatar
1500 grams without transponder....
Greetings from Indonesia
daniz24 is offline   Reply With Quote
Old 02-14-2002, 04:59 AM   #1207
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Minimum weight for all Sinagpore races is 1500g without transponder. The rules are rubber tires only for now.
NightKidZ is offline   Reply With Quote
Old 02-14-2002, 08:23 AM   #1208
that's very nice.
By the way, have you check this out ?
http://www2u.biglobe.ne.jp/~kmodels/mr4tcspkai.htm
Old 02-14-2002, 11:47 AM   #1209
Da4head's Avatar
On Mo's web page is a setup which resembles Chris Tosolini Novak race setup. What is this setup suppose to give you in terms of handling feel. Also are those blue springs Yokomo's?
Da4head is offline   Reply With Quote
Old 02-14-2002, 03:29 PM   #1210
Moderator
Speedo's Avatar
ongbenghui-thanks! No, I have never seen that before, looks cool.
c/f top decks are done, all worked out very nicely. Will be very interesting to see what this does.
4head- Yes, yokomo blue springs. Running a softer spring on the front helps smooth the car out when using the front one-way.
Old 02-14-2002, 04:48 PM   #1211
Simon K's Avatar
Wink
Thanks for the responses guys.
I checked out that Japanese link and it was quite interesting, Hard to follow exactly what was going on with Bablefish but I got the general idea.
Old 02-15-2002, 09:54 AM   #1212
Default Hey guys!
If you are looking for a really nice Worlds Yok. take a look at mine ! It has some pretty interesting features and is extremely fast. I am currently using a 6mm oneway from a TAMIYA TA04. Also I have changed several other parts of the car for improved performance. Takle a Look:
Yokomo MR4TC Worlds Car! $150.00
Thanks,
SWG
simulatedwood is offline   Reply With Quote
Old 02-15-2002, 03:30 PM   #1213
Moderator
Speedo's Avatar
Got my top deck made.
Old 02-15-2002, 03:31 PM   #1214
Moderator
Speedo's Avatar
Old 02-15-2002, 05:52 PM   #1215
rccarracer's Avatar
Nice Job!! Have you tested it yet?
rccarracer is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
