Old 02-01-2002, 07:57 PM   #1141
rccarracer's Avatar
Do any of you guys run Sanyo HV's in your Yok Specials? More importantly do you heat shrink the individual cells? Because I did this be now the cells won't sit flat in the chassis, and it is a real tight fit. Anyone else had this problem?
rccarracer is offline   Reply With Quote
Old 02-01-2002, 08:01 PM   #1142
rccarracer's Avatar
Do you think I should remove the extra layer of shrink wrap that I put on from the cells?
Old 02-01-2002, 08:02 PM   #1143
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Yes, I have them, and they are heatshrinked with the thickest heat shrink I know of...They fit a little loosly in mine, but that may be because I dremeled some areas out of the tray and filed down the sides of the posts. I had trouble with my 2400's fitting when I first got the kit.
You may want to try filing down the sides of the battery posts a little. If that still doesn't work, do what I did and on the two end slots, dremel the ends out a little bit so they are square instead of rounded.
Good Luck,
Speedo
Speedo is offline   Reply With Quote
Old 02-01-2002, 08:36 PM   #1144
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Josh is correct on the tires for the Novak race. Both Baker and Chris ran yok 139gs2 compound tires.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-01-2002, 10:14 PM   #1145
Moderator
Speedo's Avatar
Man, he was doing crazy things, but it must have worked!
Old 02-01-2002, 11:08 PM   #1146
Regional Moderator
Darkseid's Avatar
Thanks for the input on the tires guys.
TLR 22...Tamiya F104...
Old 02-02-2002, 12:18 AM   #1147
R/C Tech Founder
Anybody know of an alternate battery-hold-down method for the Special?
The way my battery posts are bent right now, there is an extreme danger of the aluminum Yokomo bar bridging the packs. I'd rather avoid that, if possible, without re-doing my packs (I have many of them! heh)
Is there any sort of aftermarket battery bar available for the car?
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 02-02-2002, 12:23 AM   #1148
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Futureal- use a small zip tie and zip a piece of lexan onto the battery hold down at the battery post - no danger of shorting then...
U can kinda fold it around the brace to make sure....
BTW, I can ue DW4 to upload the pics from the Snowbirds- I forgot it was on my laptop...hehe
BigDogRacing is offline   Reply With Quote
Old 02-02-2002, 12:27 AM   #1149
R/C Tech Founder
That's such a crazy (and cheap!) idea that it will probably work just fine!
If for any reason the IP I gave you does not work, just send me a quick email and I will double check things. I tested it from a friend's house today and got in just fine, so it should be all good.
Good luck at the race!
Old 02-02-2002, 10:55 PM   #1150
Registered User
Futureal,
I'm using the TC3 battery hold down in my Special. I know the Yokomo aluminum hold down acts as a heat sink, but I just didn't like the way it fit. The pieces way flopping around an making noise. So I switched to the TC3 hold down.
thatdog is offline   Reply With Quote
Old 02-03-2002, 03:24 PM   #1151
Moderator
Speedo's Avatar
I have a TC3 aluminum hold down from my Pro I might re-drill to fit the special.
Old 02-04-2002, 02:05 AM   #1152
johnbull's Avatar
Hi guys. Greetings from Malta.
I'm surprised you guys are having difficulty with the Special battery hold down. it covers a larger area of the cells than any other I have seen, and nobody out here has had any problems with it, unlike the old MR4 TC style battery hold down arrangement.
Quite right, if you cover the cells with shrink wrap, like I do, they are a tight fit, but that's a good thing, and I'm certainly not complaining at that.
Had a strange day's racing yesterday. Finished 4th in the A in race 1 with a reasonable performance. Son Josh won with his TC3. He was 3 seconds off 23 laps - I was 3 seconds off 21....and still 4th.
In the second final, I decided to changer tyres, having had a bit too much oversteer in the first race, but didn't bother weighing the car after the change to softer - and lighter inserts. Result - the car was underweight at post race scrutineering and I was disqualified. Shame!
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 02-04-2002, 02:20 AM   #1153
Battery Strap,
If you find the battery strap on the loose side, try fitting a thin piece of foam material between the cells and the strap. I need to do this when running 1700Mah cells in stock.
My Sanyo 2400Mah are a nice snug fit so don't need the foam.
One of the best features of the Specail is that battery brace. I thought it looked cheesey at first but it grows on you. Plus it makes an exelent heat sink.
Yorkie.
Yorkie is offline   Reply With Quote
Old 02-04-2002, 06:31 AM   #1154
Here is a picture of my car.The Body Shop
rowdyrj is offline   Reply With Quote
Old 02-04-2002, 08:56 AM   #1155
Regional Moderator
daniz24's Avatar
My Spesh :
daniz24 is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
