Old 01-06-2002, 11:49 AM   #1021
R/C Tech Founder
R/C Tech Charter Subscriber
The problem was that they changed hosts on Yokomo's site and it takes some time for the new host information to make its way around the internet. By tomorrow or so, I would think it would be working for everybody.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-06-2002, 11:09 PM   #1022
Send a message via AIM to pilot
hello,
speedo- i tried the #3 pistons in the rear, with 45oil and standard springs, and the car wasn't as stable as with #2 pistons in the rear and #3 in the front. I am using the front top sway bar now, but i am wondering if i should use the lower one and the rear? I will try my car with the rear sway bar on sunday with the stiff setup, but i was wondering if you know what the sway bar will do, so i know what to expect.
I also have a question about the oil. Can you guys compare the yokomo numbers (#450, #500.....) with regular numbers for weight of oil?
Thanks again
matej
pilot is offline   Reply With Quote
Old 01-06-2002, 11:58 PM   #1023
johnbull's Avatar
Kentech,
Have you abandoned this site completely?
Happy New Year.
Joe from sunny....but very cold Malta.
johnbull is offline   Reply With Quote
Old 01-07-2002, 04:04 PM   #1024
Moderator
Speedo's Avatar
Yeah, less stability makes sense. A swaybar stops the car from rolling, taking away traction on that end of the car. They can make the car more stable, or responsive, depends. They basically will take away steering on that end of the car. So if the rear end is too locked, you might try a rear swaybar. Currently I have both. I can post my setup if you want.
Speedo
Speedo is offline   Reply With Quote
Old 01-08-2002, 07:35 AM   #1025
Can you please post your setup? Oh and i just heard that we are going to run foam tires, so i will make my car stiff and use front and rear roll bars. Also, what are the standard rear toe in hubs(1deggree, 2)?
And how much front and rear castor is there?
thanks for the help
matej
Would anyone happen to know for a used amb transponder system?
Old 01-08-2002, 04:12 PM   #1026
Moderator
Speedo's Avatar
Using center one-way and front diff. Sorex 24R front, Sorex 20R rear, echo red all around, TQ orange.
front: Outer hole on tower, outer hole on arm. Upper inner hole on tower. Green springs, 40wt, #3 pistons. Second thickest front swaybar (bronze?), worlds stlye. lower hole on castor block, shock length, 63.1mm. 5mm ride hieght, 1/2 degree toe out
rear: Middle hole on tower, outer hole on arm. Upper inner hole on tower, outer hole on toe block. Green srpings, 40wt, #3 pistons. Thickest swaybar (bronze?) Lower hole on toe block. Shock lenth, 59.35mm. 5mm ride hieght, 1 degree toe blocks.
Standard front castor blocks is 5, plus the 2 deg. of kickup, for a total of five. I'm not positive, but I think the standard rear toe blocks are 2, I'm running 1.
Speedo
Old 01-09-2002, 02:13 AM   #1027
when do you think the new yokomo tc is going to be out? I think yokomo is working hard on it now to be ready in time for the worlds in may.
moonman is offline   Reply With Quote
Old 01-09-2002, 04:20 AM   #1028
ausracer's Avatar
what ride height is every one running? my car 5.5 in the rear and 6.5 in the front is this too high and should they be the same?
also my shocks are the same length on both sides but the droop gauge shows a significant difference left to right, should i just leave it or adjust it so both sides are the same.
ausracer is offline   Reply With Quote
Old 01-09-2002, 10:22 AM   #1029
Trader Rating: 35 (100%+)
moonman: Are you referring to a "New" 4WD Touring Car from Yokomo??? Where did you hear of this???
Anyone else seen the chassis setup kit pictured on the Yokomo Japan web site? Cost?
Geppetto is offline   Reply With Quote
Old 01-09-2002, 10:43 AM   #1030
Gepetto: I read it on some forum so its very hard to tell if there is any truth in it but Yokomo is always pushing hard on car development and I'm sure we're going to see new car in 02 but when ??
Old 01-09-2002, 04:49 PM   #1031
Simon K's Avatar
Wink
Geppetto,
Seen the setup thingy and also the LWB kit for the BC. Would the LWB kit be a viable tuning option for a touring car?
Would a 6mm increase in wheelbase muck up more than it could benefit?
Moonman,
There is a direct drive 4 cell pan car type chassis(Like the Associated RC10L based Touring car) pictured in the 2002 Yokomo catalog. It is called the DD and uses Touring car wheels..
Other than that, there is a cheaper version of the SP, called the SP-RS.
I think there won't be a new car as such but you may see the parts shown at the JMRCA on-road Nats used again if required.
Will be an interesting few months anyway.
Simon K is offline   Reply With Quote
Old 01-10-2002, 01:56 AM   #1032
Simon K: It's possible that there will be some upgrades to the SP but instead I would like to see a completely new car built for racing.
The mr 4 series started as an sport level car which evolved into a racing car and I think the bulkheads ,suspension and also the drivesystem are a little outdated.
Old 01-10-2002, 05:55 AM   #1033
johnbull's Avatar
Hi guys. Greetings from Malta.
I am as eager as you guys to see a new Yoke, but is it really necessary. Point is Masami still seems able to win more events than he looses, with a car that is very much like the car you and i can buy from the shops, and for which all the shops are now well equipped and aquainted with spares.
I've no doubt Masami and Dad will come up with something, and i certainly can't wait to see, but somehow I'm sure it won't be something revolutionary, just an improvement on the proven theme perhaps?
We race on a very technical track this Sunday, which won't be so good for my 55 year old reflexes, so i suppose what I must do is just keep off the bankings, and hope everyone else doesn't!
Regards
Joe from sunny Malta.
Old 01-10-2002, 01:57 PM   #1034
sac
the first new yokomo in this country will be called the yokomo mr4 custom and it will have a rx-7 body with it, like the gt-4rtr .it will still be VERY similier as the current mr4 ,with some small upgrades.then there will be upgrade kits for it as you get to be a better driver,i do believe the first upgrade kit will include a one -way and threaded shockbodies,the next upgrade will make it like the current mr4tc pro and then the 3rd upgrade kit will make it like the current special edition .that is what i understand the plan is. should find out availibility soon !!!
sac is offline   Reply With Quote
Old 01-10-2002, 03:24 PM   #1035
Moderator
Speedo's Avatar
sac, yea, news of that has been out for a while. It is basically a begginners car, if you plan on racing competitively and can afford it the special is still the best kit.
I have had, for a few weeks now, the yokomo ride height/droop guage tool and it is great. Ride height is measured in 1/2mm increments, and droop is measured in 1mm increments. Very easy to use.
Speedo
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
