Old 01-04-2002, 03:38 PM   #1006
Yokomo Fan's Avatar
Originally posted by thatdog
Speedo - I think they meant 1/02/03 for the launch date!!LOL
Well it says 1/3/02 on there right? Well in England DD/MM/YY is used so it should be ready in two months
Yokomo Fan is offline   Reply With Quote
Old 01-04-2002, 06:01 PM   #1007
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
pilot, I assume you have the kit yellow springs for the special. For carpet I would get a set of greens and a set of oranges. Right now my car is just crap, can't get it to work worth sh*t. I'll work on it tomorrow, and if I arrive on anything I think works, I'll post it here. Have you tried using the #3 pistons in the rear? I am strugling to get enough steering, especially on power, so I run the same piston all around. The car feels like it is too stuck, I thought I had it freed up, but was told it was still stuck...sigh...
If you do want to go heavier, I would say no higher than 70, and if you did go 70, put #2 pistons all round, 70 with #3's up front will give the car almost no roll in the front, and you would loose a lot of steering, I think. But experimenting is how you learn, so I encourage you to try it, and share your results with us.
Speedo
Speedo is offline   Reply With Quote
Old 01-05-2002, 12:31 AM   #1008
Simon K's Avatar
Wink
You waiting for some of the three degree front hub carriers Josh?
I don't know if my HV's and hub carriers will arrive in time for the nats in three weeks.
My Big Jim tuned MVP and Tribo drops have shown up though, looking forward to laying the smack down, if I can
Simon K is offline   Reply With Quote
Old 01-05-2002, 04:40 AM   #1009
Yokomo Fan's Avatar
hey Josh, new yokomo site. bad news, all the posts are gonna have to go, re-register at http://1.mymobilecity.com/phpBB2/index.php
everyone is welcome to join!!
Old 01-05-2002, 06:02 AM   #1010
ausracer's Avatar
i just got a centre oneway for my mr4 pro and i cant work out how to put it on. firstly the instructions are in japanese but that shouldnt matter the thing is it shows parts that didnt come with it or the car. do i need to buy more parts or is there some way of getting it to work without them.
ausracer is offline   Reply With Quote
Old 01-05-2002, 06:34 PM   #1011
SpeedTech's Avatar
Hi Guys,
We should have the new 3 degree and 7 degree (I believe) castor block, and the transponder mount in stock next week. We got the hollow layshaft in stock this week, and we also have the new pink springs in stock as well. Look for them soon on our website!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 01-05-2002, 08:04 PM   #1012
Simon K's Avatar
Wink
Ausracer,
To run the one way on your PRO, you'll need a 15 tooth front drive pulley, part number ZM-674. Add a capital "H" for the hardened one which I recommend(ZM-674H).
To use the one way unit you need to put a small pin into the center layshaft, then push the 15t pulley so it locks onto the pin.
You then slide the one way unit on the other end of the shaft and Voila! it's ready to go.
Just use thin shims to space the assembly out so it spins freely.
Any problems or questions, don't hesitate to ask.
Old 01-06-2002, 02:15 AM   #1013
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Hey, the new site at http://www.yokomousa.com is up and not lookin' too bad.
MarkA is offline   Reply With Quote
Old 01-06-2002, 03:45 AM   #1014
Yokomo Fan's Avatar
Pretty cool, you should sign up for the forum!
Old 01-06-2002, 04:45 AM   #1015
Regional Moderator
disaster999's Avatar
the site is totally not working....its still have that its updating message on it!
disaster999 is offline   Reply With Quote
Old 01-06-2002, 05:40 AM   #1016
Yokomo Fan's Avatar
No infact it is up! Try the forum address instead.
http://www.yokomousa.com/phpBB2/index.php
Old 01-06-2002, 06:16 AM   #1017
Regional Moderator
well..its not working for me....i think its my comp....sigh
Old 01-06-2002, 06:56 AM   #1018
Yokomo Fan's Avatar
Try again in a few days.
Old 01-06-2002, 07:13 AM   #1019
Yokomo Fan's Avatar
Hey I see you managed to get there!
Old 01-06-2002, 11:15 AM   #1020
Moderator
Speedo's Avatar
Simon, I'll probably get both the 7 and 3 blocks, they are cheap and nice tuning options to have. Right now my car has plenty of turn in, but not enough high speed steering, so I'm thinking maybe the 7's will be best...
I got a pack of HV's about a week ago, they are simply amazing! Will probably be getting three more and a T35 stealth and a Ti or two very soon, to run mod Just hope ROAR doesn't run foamies at the carpet nats, then our track will run them...And the yokomo has a fair ammount of flex, not good.
Speedo
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
