Old 12-26-2001, 08:35 AM   #976
johnbull's Avatar
Hi guys. Greetings from Malta.
Azmi. Go the other way. Open it up more to get the grit out quicker than it gets in.
If you look about a week back on this thread, I explained exactly how I did mine. I have had virtually no more problems with belts, gears, etc.
If you can't find it let me know and I will repeat.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 12-26-2001, 09:40 PM   #977
Trader Rating: 71 (100%+)
Default Yok Special carpet set up w/foams?
Just got a Yok Special. I run on carpet with foams. I will not be running the one-wayS. Anybody have any good set up tips??
loverb_2000@yahoo.com
RBLove is offline   Reply With Quote
Old 12-27-2001, 07:09 AM   #978
Rob..How goes it?Its Hal from Corcar I just spotted your reply and thought I would say hello.Jason sez you may run gas some this year?
Sorry for the interruption on the thread.
blimey is offline   Reply With Quote
Old 12-28-2001, 03:11 PM   #979
Yokomo Fan's Avatar
YEY! The new YokomoUSA website is almost up and is under constuction, woh ho! Christmas is abitlate though
Yokomo Fan is offline   Reply With Quote
Old 12-28-2001, 04:04 PM   #980
Regional Moderator
daniz24's Avatar
COOL
Finally.......
daniz24 is offline   Reply With Quote
Old 12-28-2001, 08:29 PM   #981
JimmyMac's Avatar
Yeah, but how long will that sign stay there? Another 6 months? LOL
JimmyMac is offline   Reply With Quote
Old 12-29-2001, 12:25 AM   #982
I'm thinking of getting an MR-4 TC R (the one that was very similar to the MR4 Rally).
I'm trading in a Yokomo YR4 M2 Type J for it... worth it? Stupid idea?
dugrant153 is offline   Reply With Quote
Old 12-29-2001, 07:36 AM   #983
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I'd say worth it, the MR-4 is a newer car, and you can always upgrade it to special spec. Good luck
Speedo is offline   Reply With Quote
Old 12-29-2001, 01:20 PM   #984
I heard the MR4 TC has chassis flex?
Old 12-29-2001, 04:04 PM   #985
Simon K's Avatar
Wink
The original TC can a bit, the newer cars with the one piece upper deck can twist but not flex end to end.
Simon K is offline   Reply With Quote
Old 12-29-2001, 06:38 PM   #986
Is it really bad flex?
Old 12-30-2001, 12:15 PM   #987
Moderator
Speedo's Avatar
Simon, I think that is considered flex No, not nearly as bad as, oh I don't know, the PRO 3!
Old 12-30-2001, 03:55 PM   #988
Simon K's Avatar
Wink
I don't think so, it depends on the track, low grip asphalt-No problem.
I've heard that you need a stiffer chassis for carpet racing indoors although I've never done it, many of the guys here have.
Old 12-30-2001, 06:33 PM   #989
Moderator
Speedo's Avatar
It works fine here, and it has really high traction. Still, it would be better if it was a bit stiffer, but we can work around it
Old 12-30-2001, 07:29 PM   #990
My YR4 chassis seems quite stiff. Will it be any less stiffer than my YR4? (You can barely twist it almost).
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
