Old 12-07-2001, 11:00 PM   #916
is there a difference in the driveshafts from yokomo and those from integy/eagle
was ist los? is offline   Reply With Quote
Old 12-08-2001, 12:03 AM   #917
STLNLST's Avatar
Trader Rating: 17 (100%+)
Yeah...........the price
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-09-2001, 04:33 PM   #918
any performance differences
Old 12-09-2001, 04:52 PM   #919
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I recomend the MIP driveshafts. The shiny ones are very druable (although I managed to bend one) and the aluminum ones are virtually the same as the yoks, except cheaper. I use the shiny's up front, and yok aluminum in the back. One thing I notice about the design of the MIPs is they don't pick up nearly as many carpet fibers in the joint than the yoks do. This is because they have a cup that covers the joint.
Speedo
Speedo is offline   Reply With Quote
Old 12-11-2001, 11:18 AM   #920
Can anyone recommend gearing for the Yok SP running in stock with a P2K or a GM3 pro.
I'm running on a tight technical track with low traction using the P2K pro. My gearing last night was 23/81(stock spur). Punch was great but top end was slow. I think I can go higher with the pinion as there was plenty of battery life and the motor was not too hot. Just want to make sure in case I fry the comm.
Yorkie
Yorkie is offline   Reply With Quote
Old 12-11-2001, 04:27 PM   #921
Moderator
Speedo's Avatar
Yes, you should easily be able to go to a 24 and that should be just about right.
Old 12-12-2001, 06:34 AM   #922
johnbull's Avatar
Hi guys. Greetings from Malta.
Haven't been on much recently. Haven't had much to report.
Had a lousy day's racing Sunday. Just couldn't do anything right all day. Finished 7th and 8th in the two finals - worst result this season.
I ran the car Friday and it felt great. I was consistantly just off 17 laps in 5 minutes. Come Sunday I couldn't even do a 16. The Yoke was handling like a pig and was slow as a snail.
I pulled it apart yesterday but couldn't find much wrong. Put it together again, skimmed the armature and put a new set of brushes on. I replaced a couple of bearings that were giving a bit too much slop, but other than that all went back together the same way. Tried it today and it's fine again. Hope it stays that way next Sunday when we're at it again.
Son Josh won both finals with his TC3 so at least he picked up some of the honour.
Does Darkside check into this thread at all nowadays? If so, Hi!
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 12-12-2001, 06:50 PM   #923
JimmyMac's Avatar
Hey guys. I'm gonna run a trophy race this Sunday on a very rough parking lot track.... ride height = 8-10mm!! Thats how rough it is. Anyways, any tips for better rough handling? I was thinking about shortening the camber links just a tad. Some slightly heavier oil. No sway bars. Perhaps #2 pistons. Possibly even moving the lower shock mounts in some. I don't know, any other tips? Softer springs than yellow? Thanks guys...
Jimmy Mac
JimmyMac is offline   Reply With Quote
Old 12-13-2001, 02:46 AM   #924
johnbull's Avatar
I would think soft as possible, with as much travel as possible.
Old 12-13-2001, 07:39 AM   #925
Send a message via AIM to pilot
hello. I am getting an mr4 sp next week. I was wondering what spare parts i need for the car. Which parts brake easily? can someone post pics of their special.?
thanks for the help
pilot is offline   Reply With Quote
Old 12-13-2001, 08:10 AM   #926
Do you guys know where there is a rc shop in the center of london that caries yokomo? Thanks again
Old 12-13-2001, 02:06 PM   #927
Regional Moderator
daniz24's Avatar
thanks for the help
Just don't use the low-friction belts from the kit. i suggest you change them with standard belt (World Replica) coz the low-friction belts can damaged your aluminum pulley.
daniz24 is offline   Reply With Quote
Old 12-13-2001, 05:07 PM   #928
Moderator
Speedo's Avatar
I would keep the front low-friction belt in, but scrap the rear one. Parts- driveshafts (consider replacing with MIP shiny or Yok hardened if they do bend) shocks towers, arms, the usual...I have had the most trouble with the rear bulkhead piece that holds the hingpin. Overall though, very durable car. I would say arms and shock towers, most other stuff won't break bad enough that you have to replace it right away, with the driveshafts and rear bulkhead pieces, the will usually last for the raceday.
Old 12-13-2001, 05:58 PM   #929
Trader Rating: 62 (100%+)
does anyone know if there are an aluminum diff pulley and front oneway diff pulley available for the mr4tc? robinsons racing makes aluminum pulleys for the hpi pro2 and i was wondering if there are manufacturers that make similar pulleys for the yoke. thanks for any info!
marvi is offline   Reply With Quote
Old 12-13-2001, 07:47 PM   #930
Moderator
Speedo's Avatar
Nope, i don't think so. The only aluminum pulleys are on the center shaft. Why would you want to have aluminum pulleys on the diffs?
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
SEO by vBSEO 3.5.0
