Old 11-29-2001, 10:23 AM   #886
kentech's Avatar
SimonK: Sorry, I know of no sites with good pics from the Japan nats. Masami won both classes at the offroad nats...results should be up at rcZone really soon.
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-29-2001, 06:21 PM   #887
Simon K's Avatar
Wink
Thanks for that
I hated being left in the lurch-only knowing Qualifying positions.
Simon K is offline   Reply With Quote
Old 11-29-2001, 08:43 PM   #888
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Mouting the rear link on the bulkhead give more rear traction becuase it effectively makes the link longer, therefore gives more roll, hence more traction
Speedo is offline   Reply With Quote
Old 11-30-2001, 05:48 PM   #889
Has anyone tried the Yokomo 'Andy's' Honda Accord.
Is it designed to give more steering than the Stratus?
Yorkie
Yorkie is offline   Reply With Quote
Old 12-02-2001, 08:34 AM   #890
Thumbs down
i have mr4tc,the problem ,rear belt no tension,and the rear belt slip ,i many time change this belt, the puley damage,because belt slip.
you have a trick,solution,or make it tensioner in the rear belt ???
allen is offline   Reply With Quote
Old 12-02-2001, 08:45 AM   #891
Regional Moderator
daniz24's Avatar
Allen : just don't use the low-friction belt (SP kit standard). very short life-time (not durable), harmful to alum pulley.... BTW have you already received your rear belt from Aswin??
daniz24 is offline   Reply With Quote
Old 12-02-2001, 09:13 AM   #892
Wink
thank's daniz .
who are you man? you my friend, send me my friend gotcha...
i'm waiting pete.......,i just try guess you ,harr.....or.....
Old 12-02-2001, 09:23 AM   #893
hello kentech sportsman from finland,
what the good combinasion mr4tc spurgear X pinion
i used trinity d4 9X3 ?
wright now i used 78 X 22.
and how the good timing / degree used adjusting this motor
ooo ye the track shorty ...
Old 12-02-2001, 04:21 PM   #894
is there a way for me to fix my blue driveshafts on my yoke. they broke where the yoke and shaft meet
was ist los? is offline   Reply With Quote
Old 12-02-2001, 04:35 PM   #895
Trader Rating: 62 (100%+)
has anyone broken a diff screw on their mr4tc before? mine broke off near the allen head. luckily, i had a spare screw. what could be the problem? i dont think the diff is too tight because it runs fine without slipping and im just running stock motors. i adjusted the diff according to the manual (back of 1/8 turn after tightening.) also, a couple of racers broke theirs about a couple of weeks ago. could using a stainless steel screw help strengthen that part? thanks for any info! sorry if this question was already asked, but i havent had time to read the whole thread.
also, will the TC3 shock pistons (white color) fit the mr4tc's threaded shocks? i got my mr4 from a trade and i dont have the yokomo shock pistons. thanks again for any info!
marvi is offline   Reply With Quote
Old 12-02-2001, 07:08 PM   #896
Simon K's Avatar
Wink
Marvi,
Don't tighten the diff screw all the way up. I run mine fairly loose, just to the point where they don't slip. Don't go any tighter than that. Put some black grease under the head of the screw.
Associated Pistons fit the shocks, I use a #3 in mine.
Was ist Los?,
You could buy the parts seperately, In New Zealand it is cheaper to just buy a complete new pair of Yokomo CVDs. Check out the prices at your LHS.
Old 12-02-2001, 09:04 PM   #897
Moderator
Speedo's Avatar
Smile
marvi-I broke one just today...Front wheel drive! Yeaaah! Luckily mo had one though, apparently the screw gets hot and can shear off. He said to make sure you put a lot of black grease under the thrust bearing on the screw head to help keep it cool.
Speedo
Old 12-03-2001, 06:26 AM   #898
I am fitting a front diff to my SP and I was wondering which way the smooth side of the diff pulley should be facing.
In the manual it says that for the rear diff the flat side of the pulley should be facing the right (towards spur gear). OK, no problem.
For the front one-way it says that the flat side of the pulley should face to the left. Now, does the front diff need to be the same as this or the same orientation as the rear diff?
Or does it not matter as long as the belt sits right in the middle?
Yorkie
Old 12-03-2001, 04:34 PM   #899
Moderator
Speedo's Avatar
Wink
I don't remember which way it is, but I know the pulley is offset, which is why it has to be like that. I just guess, and if I'm wonrg, swap it around
Old 12-03-2001, 06:22 PM   #900
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Good news guys- The tool we had machined to replace the oneway bearings in the front oneway WORKS !!! I have found the bearings, and so far the best price I have found is about $9 each. So on the yok, you can replace both bearings for $18 plus whatever I charge to do it, and the shipping, which will be minimal since it's so light. I think you could safely use a small padded envelope since it's not very fragile (unless it's in my Yok...lol) When I actually get the new bearings will depend on how fast I get responses because I can't afford to buy a bunch right off the bat. You can use my email below or go to my website and get my phone number. The link is below. I'll get some 4x8 and 5x8 bearings just in case someone has a bad one. The 4x8 bearings are on the inside of the oneway bearings in the housing. Mine were fine, but better to be prepared than not.
You could also PM me
BigDogRacing is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
