Old 09-22-2001, 11:30 PM   #436
Simon K's Avatar
Wink
I ordered my MVP today. I shall let you know what happens....I don't have a dyno so it'll be the tried and tested"That sounds better" test
Simon K is offline   Reply With Quote
Old 09-23-2001, 12:40 AM   #437
What do you guys use to add weight to your car, and where do you put it??? I heard the rule is 53oz, and I'm 49oz, without transponder. lol... gotta get up there.
JeffC is offline   Reply With Quote
Old 09-23-2001, 06:23 AM   #438
AllPimpRacing's Avatar
Send a message via ICQ to AllPimpRacing Send a message via AIM to AllPimpRacing
JeffC,
I've used just about anything...From a fifty cent piece to 2 tripple A batteries! But I finally got me some Lead weights! I usually put it on the side of the batteries. I'm not sure if thats the "correct" place to put them for weight ballance, but at a race that was the quickest place to get to!
AllPimpRacing is offline   Reply With Quote
Old 09-23-2001, 10:02 AM   #439
I think I'll just look around for some lead weights, and try them in different places. There's not much room on the side of the batteries (SP chassis), but I'm thinking either straight across from the motor, or between the motor and ESC... probably both. Might balance out pretty good that way.
Old 09-23-2001, 10:33 AM   #440
Regional Moderator
disaster999's Avatar
JeffC: y dont you put them on the side of the chassis?
disaster999 is offline   Reply With Quote
Old 09-23-2001, 10:38 AM   #441
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
I have some nice AE ones that work well. Our LHS owner has four digital scales, so I'll just use those to balance it out
Speedo is offline   Reply With Quote
Old 09-23-2001, 09:27 PM   #442
TK
JeffC have your hobby shop order some RaceTech lead(I dont know the proper name of it). It comes in 4 oz(I think) little squares. Then just cut them up and zoo goo them in the middle of the chassis next time you have the top plate off. Then you dont have to worry about ballancing it out because all the weight is close to center line.
TK
TK is offline   Reply With Quote
Old 09-23-2001, 11:16 PM   #443
Simon K's Avatar
Wink
I use stick on, lead weights(used for balancing tyres on your real car)
They are flat enough to stick to the lower part of the bumper mount(under the foam bumper). This also increases the weight over the front wheels which improves steering.
I believe it is also done on 2wd off roaders....
Old 09-23-2001, 11:18 PM   #444
Simon K's Avatar
Wink
Any recommendation for my MVP brushes, should I go full face or with the vertical slot?
Old 09-24-2001, 09:32 AM   #445
senna's Avatar
Default Silver Brushes!
Hi Guys,
I would like to know if any of you guys did try silver brushes which give 2 or 3 runs only during testing or races.
Are they effective with STOCK motors?
Do they really increase acceleration and top speed?
What spring will you advise to use and why?
Senna
senna is offline   Reply With Quote
Old 09-24-2001, 12:27 PM   #446
Ball bearings
I am loking for some teflon sealed/red sealed or rubber sealed ball bearing complete set for the Mr4-TC...
Dynamite (website?) or even a set from another car that would fit in the Mr4-TC?
Any body know a set I can order?
Thanx for your help
Stratovarius is offline   Reply With Quote
Old 09-24-2001, 02:09 PM   #447
Good luck guys, I posted some questions a page or two back and haven't gotten a answer yet, I feel like I'm interupting a conversation just by asking.
Interceptor is offline   Reply With Quote
Old 09-24-2001, 02:27 PM   #448
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
BEARINGS:
You can order from www.rcboyz.com or www.acerracing.com or call up Yokomo USA who also makes teflon sealed bearings. Good luck.
Ty is offline   Reply With Quote
Old 09-24-2001, 04:50 PM   #449
TK
Interceptor try reposting your question.. Also just because your question wasnt answered doesnt mean that they dont like you. Maybe they just dont know the answer to it.
Old 09-24-2001, 05:40 PM   #450
Moderator
Speedo's Avatar
rcboyz is good. Boca is nice, but pricey.
All stock motor brushes are silver. Using silver in a mod would eat the comm fast, almost everybody uses copper, and you HAVE to in low turn mods.
Simon-a 767 will work in any stock motor. the 767 is full face serated. You may want to pick up some slotted ones too, and try some 766's, alot of people have been having success with them in MVPs, I think they are a kind of timed brush.
Josh
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
