Old 02-13-2007, 06:17 AM   #2806
Bikerbob's Avatar
Send a message via ICQ to Bikerbob Send a message via MSN to Bikerbob Send a message via Yahoo to Bikerbob
Talking
Originally Posted by smojoe
the shaft that the spur gear attaches to and has the two pullies; one that goes to the front diff and one that goes to the rear? Is that the correct one though? If it is, JACKPOT
smojoe - I looked in my manual and the SHAFT that the part you listed goes on to is termed the layshaft. But that is a different part than the one you listed. The part you listed is the pulleys and the adaptor to fit the spur gear. But if you are talking about something that is wearing down from the drive belt.. teeth.. then I woiuld assume it is the part you listed... YES!
Wayne.. yeah.. while looking in my manual.. I got mixed up.. I thought I had an 87 tooth spur on it.. it is a 78tooth... so 35t for the pinion is a bit much. I have 25/78 now.. and I will try a 27t .. I am also not running the hottest batteries, so I want speed but not at the cost of coasting to the finish.
Xray T3'11 (17.5t spec)
Xray T3'11 CanVTA
12rr BMI 1/12
Bikerbob is offline   Reply With Quote
Old 02-13-2007, 08:34 AM   #2807
Its been a while since I have even worked on my car, so I might be confusing it with the BD. There is a metal shaft that rides on bearings and has a hole drilled in it to hold a cross-pin that keeps the spur gear adapter/center belt pullies in "place." The thing that is messed up is the spur gear adapter/center belt pullies.
www.freerice.com
Help hungry people while learning.
smojoe is offline   Reply With Quote
Old 02-13-2007, 08:37 AM   #2808
Bikerbob's Avatar
EXACTLY - and the item you listed from stormer is the gear adapter/centre belt pully part!
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-13-2007, 09:10 AM   #2809
Sweet, now I just need $$$
The front belt is the 179 tooth, correct? Might as well replace a few drivetrain parts while I am at it
www.freerice.com
Old 02-13-2007, 09:25 AM   #2810
Bikerbob's Avatar
You mentioned the BD.. do you run that car as well?
What has made you bring this car out of the closet?
Is it the SP ver. or a Pro or older?
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-13-2007, 09:28 AM   #2811
Bikerbob's Avatar
BTW you can still get pretty much everything for this car from Yokomo directly.. they are CA based.. might even be cheaper than mailorder elsewhere.
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-13-2007, 10:45 PM   #2812
I sold the BD about eight months ago. Car was really good but I needed the cash to support my 12th scale fever. the MR4 was my original onroad car that I got used about four years ago. It is the pro version
www.freerice.com
Old 02-15-2007, 09:07 AM   #2813
Bikerbob's Avatar
At the moment the thing I am looking into for this is getting the SSG stuff from Yokomo or a Penguin Chassis.
Something with a Graphite plate so that batteries and weight distribution is more adjustable..
Also have to get off my butt and buy 2 more threaded aluminum shocks... I am running two plastic and 2 threaded.. lol - cheap bastard I am.. lol
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-18-2007, 12:30 PM   #2814
Send a message via MSN to Zacharopoulos
guys please check this
http://www.rctech.net/forum/showthre...17#post2990417
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Zacharopoulos is offline   Reply With Quote
Old 02-19-2007, 01:42 AM   #2815
sorry broken link!!!
Z works RC paints
www.zworks.tk
^^^Check it ^^^
Old 02-19-2007, 06:42 AM   #2816
Bikerbob's Avatar
Well took my car racing on the weekend.. and it sucked.
I can set this car up for rubber.. and I can get it to run pretty good.
So far on carpet with foams.. crap.
I cannot dial out enough stearing.. I have my dual rate below 50.. I have stiff springs up front( going to try stiffer). Thing runs better with no compound on it at all. Hate not having droop screws.
I did still have the centre oneway in.. so I am taking that out. I was also told that my rear diff is much tighter than the front and the difference will cause the rear to get loose.. so i am rebuilding that.
This car is LIGHT as well.. at full trim I am 100grams shy of big race weight.
I think I need to get this thing balanced.. get the weight on it.. and then try again.
GOD this car need droop screws.. lol.. YES cant complain when I am the one deciding to run it.
That is my vote for best new innovation in RC.. not rebuilding your shocks, every race day.. and I do have to because the foams wear.
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-20-2007, 09:59 AM   #2817
jak43's Avatar
Trader Rating: 14 (100%+)
I ran a MR4-tc early in the season in a 19t rubber tire class on carpet. It worked well in that class. I made the A-main every time which is not bad for a car that I picked up off of ebay for under $20. Don't give up on it yet. I upgraded to a BD and it is a great car. I would recomend putting your car on someone's setup station like an Integy or Hudy and see what all of the settings are at and go from there.
John
jak43 is offline   Reply With Quote
Old 02-20-2007, 10:33 AM   #2818
Bikerbob's Avatar
John
Oh I have not given up on it John... but my question to you is.. When are you going to sell me that car for $15????
As for the BD.. I would love to go there.. but used they are still selling in the 250-300 range.. and I can pickup a T2 or FK04 for $150...Xray is all they sell at my track (all anyone buys) so as much as I HATE being a sheep and running what everyone else does, the only car you are safe with anywhere is associated... so maybe a TC5 in my future.
James
Xray T3'11 CanVTA
12rr BMI 1/12
Old 02-20-2007, 12:02 PM   #2819
jak43's Avatar
Yeah, I don't like running the same car as everyone else does either. I'm the only one at the track with a Yokomo. Another guy runs a Corally. Otherwise everyone is running a Losi or TA05. I sold my spare parts MR4-TC to a guy and now he wants to get rid of it. I'll see if he still has it and let you know. Parts are'nt really an issue with it. The only thing I've broken is the steering blocks. I upgraded to aluminum blocks and have not had a problem yet.
I got my BD from a guy on here for $220 with parts. Just watch out and you can probably get one in the $200 range.
John
Old 03-01-2007, 05:00 PM   #2820
Bikerbob's Avatar
Hey Jak43, any news on that $20 car??
I am giving up on running this car with Foams... not worth all the hassle I think. It is not like I am competing with the fast guys and I am just not sure even with a newer car if I can be bothered chasing a setup all day.. aka foams.
Anywho.. My MR4-tc is back to rubber!!!
James
Xray T3'11 CanVTA
12rr BMI 1/12
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
