Old 01-21-2004, 09:16 PM   #2701
RedBullRacin's Avatar
Thumbs up MR-4TC setup
This might be bad practice but goto this line http://www.rcracing.com/msgthread.cf...iteMessages=62
and look for the post Posted: Jan-14-2004 05:01PM
I just used this with 27 on the front and 20 on the rear.
Jack the Gripper on the complete backs and a 1/2 in the inside of the fronts. and it was hooked up for carpet plus final gearomg was 25/78 with a monster motor
RedBullRacin is offline   Reply With Quote
Old 01-22-2004, 10:15 AM   #2702
Me+RC=$$$'s Avatar
Send a message via AIM to Me+RC=$$$ Send a message via Yahoo to Me+RC=$$$
Thanks, anything is better than nothing
Me+RC=$$$ is offline   Reply With Quote
Old 02-06-2004, 07:15 PM   #2703
oro27's Avatar
Trader Rating: 33 (100%+)
Hello guys just wonderin the advantages of using the narrow SPECIAL chasis over the pro chasis. Im now currently using the special chasis but unfortunately the belt rubs the motor, to prevent this I have to shim the motor with washers just to lift it a bit to prevent the belt from rubbing. Any comment will be fine with me, please help....
oro27 is offline   Reply With Quote
Old 04-19-2004, 07:42 AM   #2704
Moderator
Cmotif's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Cmotif
So is anyone else still running the old belt driven MR4TCs? I currently have three of them. I need to learn as much about them as possible.
Snakeeyes, what was up with your old mR4TC that made you thing that it was cursed? I need to know, because through some transactions, I end up with your car this week. It might have been nice to know that you were having troubles with it before I bought it.
Obviously the MR4TCs are great cars, have had two specials and now I have a SSG.
Cmotif <><
International Racing Team Member #18
IRT Established: 1999
Everything About You -- Sanctus Real
www.dontblamejesus.com
Cmotif is offline   Reply With Quote
Old 04-19-2004, 09:39 PM   #2705
I just got one of these....Hara-Worlds edition
Are these things even competative any more? If so...whats the hot setup? I'll probably run it outdoors
If I get into the car I'll go with the Penguin Graphite Conversion
The Black Kat is offline   Reply With Quote
Old 04-20-2004, 08:53 PM   #2706
Moderator
Cmotif's Avatar
They are still competitive from what I heard from the guy that sold me three of them. He had several other TCs including an X-Ray and said that they were still able to keep up. I think that the new MR4TC would be less maitenance.
I have a penguin conversion that I am not using. I will use my SSG for the racing on Saturday.
Cmotif <><
Old 04-21-2004, 09:27 PM   #2707
my sp with the yok trailer head...
razi is offline   Reply With Quote
Old 04-28-2004, 06:05 PM   #2708
Switch Blade's Avatar
Send a message via AIM to Switch Blade
Hello, I just bought an MR-4TC and was looking at the parts list on yokomousa.com. I was wondering which of the chassis and components would be better: the Pro, World's, or Special. Yokomo sells a SPECIAL conversion kit, which i assume has all of the SP components. Is this the most resent and probobly the best one to get? What are the main differences. And what is the difference between the HD hub carriers and the regular ones?(or all of the HD and regular parts)
College
Switch Blade is offline   Reply With Quote
Old 04-28-2004, 08:17 PM   #2709
Moderator
Cmotif's Avatar
SSG is the best, followed by Special, followed by World's, followed by Pro.
Socal Snakeeyes, I figured out what was wrong with your old MR4TC. One of your front shocks was dry. But more than that, you had two different front suspension arms. One was newer and the other the older style. The problem was the mounting point for the shocks were different on each arms. So one side the shock was standing more up and down and the other is was lying down more.
Recently bought and sold another MR4TC. As a club member and I were checking it out before getting into the hands of new club member, we saw a couple of problems. 1. A wheel that came of a street weapon, has a smaller hex and came undone. 2. That same corner was also missing an outer bearing on the hub. Needless to say the car would spin out in the corners. We sorted it out quit and now it runs very well.
Cmotif <><
Old 04-28-2004, 08:30 PM   #2710
Moderator
Cmotif's Avatar
Default All MR4TC Line Up
This photo is from last weeks racing at Weed Berean RC club. My car is the one in front!
Old 04-28-2004, 08:32 PM   #2711
rice's Avatar
question?
fellow yokomo guys. can i convert my mr-4tc special to cgm?
rice is offline   Reply With Quote
Old 04-29-2004, 03:11 PM   #2712
Moderator
Cmotif's Avatar
CGM? I do not know that one. SSG, I do know about. Anyone know what all is offered from Yokomo?
A good person to ask questions to is probably Steve Wang, the owner of Speedtechrc. He, I am sure knows all things Yokomo.
Cmotif <><
Old 04-29-2004, 06:58 PM   #2713
yodace's Avatar
I was looking at one of the setup sheets for the SSG.
It side RS#2 pistion what does RS stand for?
I was wondering what is the best place is to get the CG conversion?
Is Speedtech the only place that sells the conversions?
yodace is offline   Reply With Quote
Old 04-30-2004, 05:57 AM   #2714
does yokomo sell any other foam tires besides the low wear type?
o yeas, and i think you can get the CG(?? ) conversion directly from yokomo.
College
Old 04-30-2004, 01:20 PM   #2715
Yodace, this thread is for the older Yokomo *Belt* drive car. I think you are refering to the CGM conversion for the SD, right?
Any number of online shops carrying Yokomo parts should have them or be able to special order them.
Headbanger is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
