Old 05-21-2003, 07:28 PM   #2671
lonestar1127's Avatar
Originally posted by NightKidZ
?? Which MR4 are you driving??
There are only two MR4 chassis which requires CA sealing of the battery slots, the MR4 SSG SP chassis and the MR4 SD SSH SP.
Only graphite plate chassis requires CA sealing of their edges to prevent
1) the graphite layers from delaminating in a hard crash
2) the batteries from being shorted out due to contact with the graphite. (Hence CA on the battery slots.)
If you are using a tub chassis MR4, there is no need to CA the battery slots.
Cheers
thanx alot charles...
lonestar1127 is offline   Reply With Quote
Old 05-22-2003, 07:06 AM   #2672
Kyew's Avatar
charles has explained it very well.
if you are using the ssg chassis, sealing the sides with ca is a Must.
heh heh, my steering servo is superglued to the chassis.
Actually the original mount is fine (factory driver Adachi uses the original layout on his SP).
have fun with your mr4. it's a great car.
Kyew is offline   Reply With Quote
Old 05-22-2003, 09:33 AM   #2673
ic... hope so too...
now i using the hara chassis for the yokomo cup
thanx
Old 05-30-2003, 11:36 AM   #2674
hi guys,
does the heavy duty one way more durable than the normal one way??
thanx
Old 05-30-2003, 02:54 PM   #2675
Yeah the HD is a stronger
Yokomo_King is offline   Reply With Quote
Old 05-30-2003, 03:00 PM   #2676
how do you tell the difference between the standard and HD one-way diffs?
Mort is offline   Reply With Quote
Old 05-30-2003, 03:03 PM   #2677
On the package it will say HD or standard . Just check it out i think the Diffrence is its just Thicker
But use the one from the yokomo GT4 oneway thats what i heard from chris tosolini j
Old 05-30-2003, 08:44 PM   #2678
serious
can the thing fit?
Old 06-01-2003, 05:28 PM   #2679
Default MR4-TC hinge pin
bought a used MR4-TC SP, found one of the hinge pin is bend. Anyone knows where can I buy it online? Is the new SD hinge pin has the same size? the 2.5mm x 48mm. Speedtechrc doesn't carry it anymore.
desertracer is offline   Reply With Quote
Old 06-01-2003, 06:09 PM   #2680
WEll i could get you the parts that you need just pay shipping.i My LHS gives 25% off yokomo parts.
lone star that is what he told me
Old 06-01-2003, 07:02 PM   #2681
Yok King,
Thanks for your reply. Do you take paypal?
Old 06-01-2003, 07:34 PM   #2682
No im sorry. But if you e-mail me i can Get you the things you need. Just pay for shipping and thats it. I have done this b4 some1 wanted a GT4- S type kit and i got if for himi less then a 3days then i shipped
Old 06-01-2003, 08:43 PM   #2683
Randy Caster's Avatar
Trader Rating: 46 (100%+)
What hobby shop is it that has 25% off?
Old 06-11-2003, 02:38 PM   #2684
Guys,
I have shredded 3 belts now on my MR4 due to stones gettng into the rear diff casing.
I fitted the rally undertray to keep stuff out, which does work well apart from the odd stone gets in there.
I am thinking of cutting the part that retains the rear hinge pins so there is a slot in the middle to let stones out.
Also what is the strongest belt to use?
TIA
Old 06-11-2003, 03:20 PM   #2685
There's not too many choices for belts: Standard or Low-friction.
Headbanger is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
