Old 05-05-2003, 01:32 AM   #2656
overtki11
welcome to the world of the MR4TC
you might want to check out This Site there's a lot of useful stuff there.
As for what motor... a stocker will give you plenty of runtime and some of them can be pretty quick as well depending on which one you get.
I have an Orion Core Stock, which is quick enough for me, the Grean Machine, i believe, is quicker again.
Mort is offline   Reply With Quote
Old 05-05-2003, 01:40 AM   #2657
overtki11's Avatar
Location: founding member of THE "like to post BIG BIG pictures in the Off Topic, Special Interest Group".
Trader Rating: 15 (100%+)
thanks Mort. yeah i've been to that site...really cool and informative..... he did cover 12T motors as well as stockers.....stockers are 27T? what kinda gearing should i use with the stockers? i got a 25T pinion at the moment, is that too big??? actually i need a powerful enuf motor coz i'll be lugging this bodyshell around, not as light as TC shells but i do want to be different. haha
overtki11 is offline   Reply With Quote
Old 05-05-2003, 04:25 AM   #2658
Nice shell.
What is it, old Ford van or something?
Yes, stockers are 27t motors.
Not sure about gearing, it depends what motor you are going to use.
It might be worth you getting a couple of other pinions though, say a 23, 21 and 19. Smaller the pinion faster acceleration, bigger the pinion the higher top speed.
Hope this helps
Old 05-05-2003, 05:53 AM   #2659
overtki11's Avatar
thanks Mort,
its a maxx chevy panel for the E/T maxx. didn't follow the regular cut lines but followed the TC's wheels instead. so i got a "lowrider" of sorts....haha.
thanks for the tips on pinions....i guess i'll go experiment a little.
Old 05-05-2003, 06:06 AM   #2660
Oasis's Avatar
Trader Rating: 36 (100%+)
I would say a 19 wind,I would gear it 82/23 or 22,they are alot faster than a stock motor,you get almost as much runtime and they cost $39,thats for a spec. 19 turn.Thats what my choice on speed and runtime would be.Cool body.
Oasis is offline   Reply With Quote
Old 05-05-2003, 07:51 PM   #2661
overtki11's Avatar
thanks for the advice dude.....i was contemplating a 15 or 16 turn but wasn't sure about the run time.....
i guess i'll try a 19 and see how it goes....cheers man. so in your opinion this 19T is a "inbetweeny" type of motor ei?!!!
Old 05-20-2003, 09:46 PM   #2662
lonestar1127's Avatar
guys, how do i position the servo like masami mr4tc?
lonestar1127 is offline   Reply With Quote
Old 05-20-2003, 10:18 PM   #2663
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Cut off the servo mounting 'ears', use Goop or good strong servo tape to stick the servo onto the chassis. You will also need to mount the servo saver on the other steering post and modify the servo saver assemby. Hard to explain here without pictures, try asking BK Lim (Chi Long Hobbies) or Jerry.. if all else fails, ask Chris Cher for help
NightKidZ is offline   Reply With Quote
Old 05-21-2003, 04:26 AM   #2664
pucho's Avatar
Send a message via AIM to pucho
Default Check this out.
2 MR4tc's If anything you guys could use the parts that are included with the kits. Like it says on the add any reasonable offer will be accepted.
pucho is offline   Reply With Quote
Old 05-21-2003, 06:47 AM   #2665
kyew, i remember yr car got that modification.... how did u did it?
thanx
Old 05-21-2003, 08:15 AM   #2666
NightKidZ's Avatar
Lonestar :
ME NOT Kum Yew lah
You are using a MR4-SP chassis correct?
Like I said, the steps are as follows :
1) Cut the mounting ears off the servo
2) Use servo saver part (C) instead of (D).
3) Mount the servo saver on the OTHER steering from the kit instructions.
4) Attach the servo with Goop or servo tape.
Attached is a pic of my car WHEN the mods were in place.
DISCLAIMER : I have since converted back to the original servo layout. Reason being I did not detect much if any improvement in forward weight distribution with the mod in place. Moreover, the Goop or servo tape never seem to hold the servo as well as I wanted them to, hence its back to the original mount for me.
Old 05-21-2003, 09:00 AM   #2667
i noe that u are charles....
thanx aniwae
Old 05-21-2003, 11:38 AM   #2668
btw iszit necessary to CA the battery slots?
Old 05-21-2003, 12:26 PM   #2669
NightKidZ's Avatar
?? Which MR4 are you driving??
There are only two MR4 chassis which requires CA sealing of the battery slots, the MR4 SSG SP chassis and the MR4 SD SSH SP.
Only graphite plate chassis requires CA sealing of their edges to prevent
1) the graphite layers from delaminating in a hard crash
2) the batteries from being shorted out due to contact with the graphite. (Hence CA on the battery slots.)
If you are using a tub chassis MR4, there is no need to CA the battery slots.
Cheers
Old 05-21-2003, 12:47 PM   #2670
Drive Belts
Guys,
just a quick question.
I raced outside yesterday for the first time.
Most enjoyable as well.
Anyway, I just stripped down the rear
bulkhead to clean it up inside and I noticed
my rear belt had become furry along the outer
edges and also along the teeth of it.
Is it time to replace it? Or is that normal wear?
Mort
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
