Yokomo MR-4 TC Thread
#2642
I thought I read that the internal gear ratio is 2.35????
#2643
R/C Tech Founder
For the MR4TC? Nope, the internal drive ratio is 2.2, unless you change the size of the center pulley (I seem to remember somebody made 14T/15T options for it, but I could be wrong).
#2644
For the new SD. IS that 2.35???
#2645
I was referring to the SD. Sorry for the confusion. I just checked Yok's site and it is 2.353.
#2647
I just got a yokomo mr-4tc and it is great but the drivetrain seems a little big stiff, is there anything that i can do to possibly loosen it up? The car won't free roll very much.
#2649
Try using the Silent Low Friction front belt, and if you are running stock try the Silent Low friction rear belt as well. I don't recomend using the silent rear belt with mod motors. The wd-40 was used on the very first belts to break them in faster. Not needed on the new belts.
#2650
Hi guys. greetings from Malta.
Nice to see this thread resurected again.
Careful assembly should see to everything running loose. Like others have said, use the soft belts - they help.
Also ensure that the wheel hub bearings don't tighten up when you tighten up the wheel nuts. One of mine does and I have to remember not to tighten the left front up too much - and make sure I use a good nut that locks.
Also see that the belts don't touch anything, particularly the front belt.
Regards
Joe from sunny Malta.
Regards
#2652
I'm not sure if getting new belts would fix anything, when i push the car on the ground it makes a clicking noise every inch or so, but the wheels are moving and the belt is moving too. Should i just try to clean out the drivetrain, and there is probably a rock or something jamming the drivetrain in there?
#2653
Check your diff screws and make sure your whole drive train is free of dirt, especially in the rear.
#2654
yea i think that may be the problem, there must be a rock or something jamming up the belts.
#2655
Location: founding member of THE "like to post BIG BIG pictures in the Off Topic, Special Interest Group".
Trader Rating: 15 (100%+)
just got a yokomo mr4tc
hey guys,
i figure this'd be the best place to get some help.
i just got a mr4tc in a trade and so far i'm loving it. my very first TC.!!!!
to start off, what kindda motor would you guys recommend for a basher....i want fast but not super short run times....i'm gonna use 3300s. whats the best "in between motor" in terms of number of turns...please help. dun wanna spend precious $$ buying stuff i'll regret. any advice?
TIA guys
regards
TIA guys
regards
