Old 03-08-2003, 10:16 PM   #2596
Oasis's Avatar
Trader Rating: 36 (100%+)
Hey matt,When are you and mo going to get the new yokomo?I should have ran mine(mr4 sp)at the state race but I had a ton of spare parts for my tc-3(and needed most of them..LOL)Oh well live & learn.
Oasis is offline   Reply With Quote
Old 03-09-2003, 08:05 AM   #2597
Oasis's Avatar
On the rear roll centers what do you get if you put them in the top position,more traction or less,I would think less,but I'm not sure.And what is the stock degree hubs on the rear..It's an mr4 special.Thanks for any help.
Old 03-09-2003, 08:58 AM   #2598
STLNLST's Avatar
Trader Rating: 19 (100%+)
you should've run your Losi at that race....LOL
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-09-2003, 11:03 AM   #2599
Oasis's Avatar
I should have used YOUR car,it was working better than any of mine..LOL
Old 03-09-2003, 02:20 PM   #2600
STLNLST's Avatar
It was really working well yesterday.
Old 03-09-2003, 07:14 PM   #2601
R/C Tech Founder
R/C Tech Charter Subscriber
For those of you who haven't already, be sure to check out the ROAR Nats Car Pictures pages, there are some interesting modifications that Tosolini did to his car over the weekend.
Sadly, he was breaking left and right, and it pretty much trashed his weekend. He broke in both of the first two rounds, so after the resort he was in the "ugly" heat and never posted a good time. Then in the main he clipped a wall and it ripped the entire left-front suspension assembly out of the car. Bummer.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 03-09-2003, 09:31 PM   #2602
SUp all Any mods that would help out on the MR4-SP such as freeing drive train and stuff like that i need some serious speed with stock ive been working on the oykomo all day today and i made the car so that there will be no loose thing no woobles etc. so i really need your help.
Yokomo_King is offline   Reply With Quote
Old 03-10-2003, 01:01 AM   #2603
johnbull's Avatar
Hi guys. Greetings from Malta.
YOKE KING.
Apart from the usual care keeping friction to a minimum, I went another step recently.
The angles of the MR4 drive shafts have always bugged me. In my book the ideal race car should have absolutely straight running drive shafts, for least friction. The Yoke's are aweful.
I straightened the rear ones up a bit by going for the long wheelbase arrangement - spacer in the front on the rear outer wishbone pivot.
I have now done a similar mod up front, moving the wishbones back 1.5 mm. To do this I filed 1.5 mm off the inner area of the front pivot support on the wishbone, which effectively allows the wishbone to move front and back. A spacer between the rear pivot support and the bulkhead and another between the front pivot support and the bumper for safety, moves the wishbones back 1.5mm.
The drive shafts are still not perfectly straight, and the vertical angle is all wrong anyway, but there is little we can do about those, short of putting a 1mm spacer between the chassis and the bulkheads. It would have been a thought for the future if I haven't gone all crazy about the new SD car.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 03-10-2003, 12:47 PM   #2604
could you show me in pics?
Old 03-11-2003, 12:55 AM   #2605
johnbull's Avatar
YOKOMO KING.
I should have some up to date pics this evening.
I'm not too good with computers. i'll try and post them this evening, or tomorrow.
Don't know if I'll be successful though. I have never done this before.
Can anybody guide me through the procedure. The pics will be photos and CD.
Regards
Old 03-11-2003, 07:56 AM   #2606
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default HEAVY DUTY UNIVERSAL AXLES
Has anyone used the hd universals as replacement for the lightwieght blue universals?? Do they in fact last longer??
I have been wearing out the blue axle portion after about a month of use (I race 2x a week). They were at the point were the pin goes thru the dogbone to hold it to the axle...The were seem high and the replacement dogbones are not cheap...the front wear out nearly 2x as fast as rears....rear last around 2 months before they need to be replaced.
Help
Jamie
J.Gonzalez is offline   Reply With Quote
Old 03-11-2003, 08:11 AM   #2607
Senna555,
I recently switch to steel bones for the front as I run front one way and the blue aluminum have broken very easily.
I used them for around 25 packs and there is no problem with them, no wear, no breakage.
Go for them, it is not a bad investment.
Ralf is offline   Reply With Quote
Old 03-11-2003, 11:21 AM   #2608
mo
mo's Avatar
Speedworld raceway is having a 40% off sale on all yokomo parts until 3/20/03. Yokomo kits are also on sale. Check it out. http://www.speedworldraceway.com
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 03-11-2003, 02:47 PM   #2609
Post
Everybody heard about this car? Looks like this is the REAL Team ride for Yokomo pro drivers.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3121237031
smash123 is offline   Reply With Quote
Old 03-11-2003, 02:49 PM   #2610
yes this car is the SP with the SSG chassis and accesorys masami uses that car. it was only limited edition only
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
