Old 03-04-2003, 07:14 PM   #2581
Default Strange understeer problem
I was running my car today(both diffs are very tight--turn any wheel & the other 3 turn the same direction)and it would spin out at high speed(1/2 throttle to full throttle) This is on a fairly dusty surface with radials. I'm only running a 13 turn, so it's not 'that' powerful. It's almost as if the diffs work at low speed, then the front loosens at high speed, as if it suddenly turns RWD with torque bias to one side.
I'm running the same tires all around andgreen front/orange rear on the springs. The understeer is so bad it's pretty much undrivable.
1.Should I just lock out both the diffs completely? Or just lock the front and loosen the rear?
I may try mmoving more weight to the front, but understeer is pronounced that I doubt it's anything that simple
Janders is offline   Reply With Quote
Old 03-04-2003, 08:58 PM   #2582
Try Tighting your diff all the way let 1/4 to 1/2 out. it sounds like something rubbing. check your bearing one might be froozen. and i think your gearing is wrong your getting to much accel so try a diffrent gearing go 1-2 tooth up .hopefully that helps
Yokomo_King is offline   Reply With Quote
Old 03-04-2003, 11:36 PM   #2583
Default gearing
I'm running 23/78 so it should be good. The ball bearing's sound like a probable cause, since it is more pronounced at high speed. I just need to find bearing info(can I buy a full set anywhere?) If not, What are the wheel and diff bearing sizes(I got thecar used)
Old 03-05-2003, 01:54 AM   #2584
Default bearing sizes
the diff bearings are 10mm internal X 15mm external X 4mm wide
axle bearings are 6mm internal X 10mm external X 3mm wide
and the layshaft and steering arm bearings are 4mm internal X 8mm external X 3mm wide
Mort is offline   Reply With Quote
Old 03-05-2003, 12:24 PM   #2585
Default thanks!
just got all the axle and diff bearings for $35 from tower. Hopefullt that will fix my problem. I'll also disassemble my diffs and relube them. I was planning on getting a direct drive Delphi Indy and running it with a 13T, but after I played around with loosening the front diff and running RWD in my Yoke, I couldn't imagine running something that much lighter on anything other than the best prepared of surfaces.
Old 03-05-2003, 01:09 PM   #2586
Hi everybody the MRTC-SD will cost about 39,000 yen or whatevre
Old 03-05-2003, 06:10 PM   #2587
Send a message via AIM to Leon
Default MR-4TC SSG Conversion Kit and Chassis
Anyone interested in the SSG Conversion kit and Chassis? I'm willing to sell them for $150 shipped (in the US). They're brand new in the package. I bought them in anticipation I would buy an MR-4TC SP2. I ended up with a Losi XXX-S G+, but still wanted a MR-4 and they've been sitting here and now I'm in need of money. Can anyone help me out?
Sorry the picture isn't crisp as I'd like. I only have a 1 megapixel fossil of a digital camera.
-Leon
Leon is offline   Reply With Quote
Old 03-05-2003, 06:22 PM   #2588
I've not long aquired a SP and was after a basic setup for Asphelt on foams or rubbers. Basically something that I can work on from there.
Also can anyone point me to a Setup guide for the SP. I know there is the XXX Main guide but I'm after something more specific to the Yokomo.
QuickParrot is offline   Reply With Quote
Old 03-05-2003, 07:59 PM   #2589
mo
mo's Avatar
Check out my website for many setups for asphalt and carpet.
www.mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 03-06-2003, 12:55 PM   #2590
iron chef's Avatar
I am picking up a used MR4 and plan on a weekend wrench session. The previous owner could not keep the front end from chattering coming out of turns and has given up. Im not sure what to look for or what his set-up was like, probably real close to stock. Has anyone else had this kind of problem? Any recommendations as to what parts to upgrade?
iron chef is offline   Reply With Quote
Old 03-06-2003, 02:06 PM   #2591
mo
mo's Avatar
Just pust some thick grease, like associated black grease, on the drive pins in the outdrive cups. That should pretty much take care of the problem.
Old 03-07-2003, 08:58 PM   #2592
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Chris Toso's car..Sweet..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 03-07-2003, 09:36 PM   #2593
Matt Howard's Avatar
I thought he ran for Orion? that looks an awful lot like a Ti motor in his car
Matt Howard is offline   Reply With Quote
Old 03-08-2003, 02:57 PM   #2594
Tosolini runs Fantom/SMC if I'm not mistaken
Brian B is offline   Reply With Quote
Old 03-08-2003, 04:50 PM   #2595
He ran fantom/SMC about a year ago and this year he signed with Orion. If that is indeed his car with the Ti can maybe he switched back. but that still doesn't explain the Peak battery!
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
