Old 11-03-2002, 07:56 AM   #2206
Yokomo Fan's Avatar
I'm not sure if anybody has posted this, but here's a site with some pretty nice Yokomo stuff.
Click Here
Yokomo Fan is offline   Reply With Quote
Old 11-03-2002, 09:35 AM   #2207
sosidge's Avatar
Default Rear toe-in carriers...
Do the rear toe-in carrier add 1 or 2 degrees per wheel, or per axle?
I thought it was per axle, but I just fitted the 2 degree versions on my BC buggy and the toe-in is way more than I expected (roughly measured at 4 degrees per wheel).
Old 11-03-2002, 03:35 PM   #2208
Per side... There should already 1 deg of rear toe built into the rear bulkhead, add 2 deg rear hubs and you have 3 degrees of toe-in.
pops is offline   Reply With Quote
Old 11-03-2002, 04:43 PM   #2209
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Anyone have the part number for the stock rear hub carriers in the Yoke SP kit? What to in if any are those hub carriers?
This is one thing I don't like about Yokomo, they don't have any damn part numbers in my SP instruction manual. It is a pain in the rear when I want to order a few things and then I have to search the websites til I possibly find the part I'm looking for. They need to do a better job of that.
Brian
Old 11-03-2002, 05:28 PM   #2210
007yoshi's Avatar
Wyd... sorry no part no. but they are 2 degree toe in.
I ran the yok finally saturday ... in 3 heats, I got a 1st and 2 seconds in my heat and finished 4th in the main ( I think there were a total of 11 stock sedan racers) I never got to try the front ball diff, it never went together..... but I did just fine with the oneway diff. All that stuff they say about oneways being hard to control... its a bunch of baloney if a rookie like me could handle it
007yoshi is offline   Reply With Quote
Old 11-03-2002, 06:04 PM   #2211
mo
mo's Avatar
wyd: there is a parts list on yokomo usa's website at http://www.yokomousa.com/kits/MR4TC_PARTS_LIST_III.xls and on my website with the setups at www.mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-03-2002, 06:21 PM   #2212
wyd
Tech Legend
wyd's Avatar
Hey thanks Mo. I was just getting ready to check out your site and the Yoke site. I like that Barney theme and then the shooting of him on your site. Man I was busting a gut when I heard that. I played it for my wife and she was cracking up as well.
Old 11-04-2002, 12:54 AM   #2213
johnbull's Avatar
Hi guys. Greetings from Malta.
Just an update of yesterday's results.
I ended up 2nd in both finals in stock, beat by a TC3. He had so much more speed. My car was handling OK but I just couldn't do the times, so it must be down to speed. Pity.
It leaves me with just a 1 point lead in the championship!
Son Josh did great in mod winning both finals with his TC3.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 11-05-2002, 12:16 PM   #2214
SpeedTech's Avatar
Hi Guys,
We updated our website and added the new Yokomo Low-Friction shocks for the MR-4TC. Check them out! These are suppose to be one of the smoothest shocks on the market with easier access to the cartridges.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 11-05-2002, 12:59 PM   #2215
mo
mo's Avatar
Believe it, they are extremely smooth and easy to build and maintaind. Plus, they look cool....lol
Old 11-10-2002, 06:22 PM   #2216
wyd
Tech Legend
wyd's Avatar
Man it is slow on the Yoke thread the last few days. I think it is because everyones Yokes are dialed and work perfect.
I just did the rear ball stud setup on my Yoke this week. Very easy to do. I was going to do the front but if I do I will have trouble using the standard width foams as they rub. I don't want to use those JAco 24mm foams as the 28mm are alot better in ever catagory.
The only complaint I can really say about the Yoke SP is that it is really made to run 24mm rubber tires and the slop in the ball ends. I know of alot of other touring sadans with this problem, the 414M2 rubs the inline ball ends, the TC3 rubs the bottom of the shock ends, and XXXS rubs as well. My buddy gets the dremel out on his Losi but it is a pain in the a$$.
It is really a minor complaint overall the whole scheme of things. I just would like for the Yoke and others to know that not everyone runs rubber tires.
Old 11-11-2002, 05:53 AM   #2217
johnbull's Avatar
More Yoke results.
I had another stock win yesterday, with another Yoke in 3rd place.
Who said the MR4 is dead!
Regards
Old 11-11-2002, 01:14 PM   #2218
007yoshi's Avatar
In the State Carpet Champs I got the 5th spot in the expert stock A main and finished 6th overall and this was only my 2nd race Before I ever raced it, I threw a setup on it and since then I havent touched it... what lucky guessing I did I liked rubber tires alot, I dont think I'll ever run foams unless its mod
Old 11-11-2002, 02:04 PM   #2219
wyd
Tech Legend
wyd's Avatar
007Yoshi does your local track let you run foams and what surface do you run on? Glad the Yoke is dialed for you.
John I expect a little better from you!!!!! Only 2 firsts and a 2nd place in 3 weeks, I want three wins in a row!!!!!
Old 11-11-2002, 02:54 PM   #2220
007yoshi's Avatar
Tight carpet track. Foams werent allowed anyway for stock
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
