Old 10-14-2002, 02:16 PM   #2146
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
007Yoshi I would start with the same springs in the front and back and then work from their.
John sounds like you have a pretty good day.
Old 10-14-2002, 03:32 PM   #2147
007yoshi's Avatar
OOOO I just drove my yok outside on the street (smooth asphault) and boy it handled sweet! It wasnt twitchy at all, and this is w/ stock setup but no rear sway bar. I also used the stock tires too Man this thing is QUIET too!!! I cant wait to race it!!!!!
007yoshi is offline   Reply With Quote
Old 10-15-2002, 09:39 AM   #2148
TeamGoodwrench's Avatar
Default YOKOMO MR4 PRO WORLDS CAR ** AND** SP CONVERSION KIT FOR SALE!!
Forgot to add this -- the MR4 "motherlode" sale below also includes an Airtronics 94737 servo too.
TeamGoodwrench is offline   Reply With Quote
Old 10-15-2002, 10:50 PM   #2149
johnbull, we cut up the weights to fit in the center slots under the front belt, as far back as you can. It worked very well and did not upset the balance of the car.
pops is offline   Reply With Quote
Old 10-16-2002, 02:15 AM   #2150
Pirvan's Avatar
Default Rollout?
Hi guys, i was just wondering what rollout and gear ratio means?
EG, how high is high and how low is low? my rollout is 81.4, what does that mean? And is there is a safety zone that gearing ratio should stay in? And what would be better for a short tight track compared to a bigger one.
Sorry about all these questions...I'm quite new to electric.
Jeff
ps-racing 540 and stock
Pirvan is offline   Reply With Quote
Old 10-16-2002, 03:50 PM   #2151
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Hopefully will run the Yokomo in a few weeks, carpet season is starting up again.
I think I'm going to stick with it, it would be nice to see Yokomo's next offering before I get a new car.
Speedo is offline   Reply With Quote
Old 10-16-2002, 03:57 PM   #2152
Moderator
Speedo's Avatar
Default Re: Rollout?
Jeff
I'm not so familiar with rollout as I have never worked with it before, but I believe your 81.4 is the distance the car will travel with one revolution of the armature ?
As for gear ratio, it has to do with what spur/pinion combination you use. Gear ratio = spur/pinion * internal ratio of your car.
Example, you have an MR-4 with a 78 tooth spur, and a 22 tooth pinion. 78/22 = 3.54 continued * 2.2 (internal ratio of the MR-4) = 7.8. This means it takes 7.8 revolutions of the armature to equal one revolution of the tires. The lower your gear ratio is (eg. 6.4 is lower than 7.2) the harder it is for your motor to accelerate your car, but since the motor is performing less revolutions to equal one revolution of the tires, you will have higher top speed. The opposite is true for a higher gear ratio. Larger pinion yields lower ratio, large spur yields higher ratio and vice versa.
Hope this helps,
Josh
Old 10-16-2002, 04:19 PM   #2153
Pirvan's Avatar
Default Thanks!
HI there,
Ooops sorry, i actually measured the spurs as pinion and the other way around my rollout is actually 37.Thanks for the information at least now i know what rollout and gearing is.
Jeff
Old 10-16-2002, 05:27 PM   #2154
contact's Avatar
yokomo's new car will be a mr4 sp with the 'worlds' kit (deck and towers etc) my understanding is that no 'revolutanary' change is anywhere close
on another issue there wont be a hpi pro4 untill all pro3's are gone (no surprise there i guess)
Veni, Vidi, Veci
contact is offline   Reply With Quote
Old 10-16-2002, 06:44 PM   #2155
Guys -- see my earlier post on called "Yokomo MR4-TC Pro Worlds ** AND ** SP conversion "motherlode" sale".
You can get a Pro Worlds car ** AND ** the SP conversion kit ** AND ** a BUNCH of brand new parts and hopups for the SP -- all for a GREAT price!!
This car has only been run for 2 carpet seasons indoors. It is in PERFECT condition -- like it was just built !!!
Pictures available of everything !
email: jeff.fritsche@esker.com
Old 10-16-2002, 11:24 PM   #2156
ant
ant's Avatar
so us guys with mr4tcsp cars should be able to get
an upgrade kit to the new specs
ant is offline   Reply With Quote
Old 10-17-2002, 04:34 AM   #2157
007yoshi's Avatar
if there arent any revolutionary changes, then probably yes. I would like to hope so
Old 10-17-2002, 04:53 PM   #2158
contact's Avatar
my source suggested that initally at least there was not going to be an upgrade kit... but i dare say it will become available or certainly the parts would
Veni, Vidi, Veci
Old 10-17-2002, 06:34 PM   #2159
Got a Web site from Japan. Picture from Tokyo Hobby Show.
Last three pictures are from Alex Racing.
http://www.pro-s-futaba.co.jp/hs2002-4.htm
Looks like it will be a package deal, kind of like MR4TC Special Upgrade.
J.
DoCoMo is offline   Reply With Quote
Old 10-17-2002, 06:54 PM   #2160
wyd
Tech Legend
wyd's Avatar
Damn as soon as that setup is available in the US I will have my new Yoke stuff on order. That car is just bad azz. I want it!!!
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
