Old 10-07-2002, 12:44 PM   #2131
007yoshi's Avatar
thanks
YAAAAY IM NOW A CLUB CHAMP HAHAHAHAH
007yoshi is offline   Reply With Quote
Old 10-08-2002, 11:49 AM   #2132
007yoshi's Avatar
Whats a good setup apart from the stock setup for a smaller 80 x 40 carpet layout? I have the direct drive and the ball diff already. Thanks
Old 10-08-2002, 03:56 PM   #2133
Front
FShock 60.5 #3 Pistons Blue Springs 400wt oil
Copper roll bar Front Shock #1 on the shocktower Camber link #2 or #3 front arms #2 on chassis shock #2 on the arm. 3 deg caster blocks#2 on the block. 5mm ride height. 1deg front camber
Rear
59.5 RShock #3 pistons Yellow Springs 350wt oil
Shock #3 on the tower Rear Camber link mounted to the bulkhead cap. Shock mounted to #2 on the arm Arm mounted #2 on chassis 2 degre toe in blocks Arm mounted on bottom hole of blocks. 5.5mm rear ride height. Graphite Pro Arms used instead of Worlds Arms. TQ Orange used for traction additive
Set-up for ROAR Carpet Nationals min required ride height was 5mm and control tires Take Off 27s with stock inserts. Highest finishing Yokomo 6th Place Stock Class.
Try this as a starter and make adjustments.
Both one-ways used, would not use a front diff unless is was outlawed. Don't want start a debate, and will not, but truth is I believe you will be faster with a one-way once you learn to drive with it. It is much harder to drive a one-way car than a diff car.
I think the new high roll center set-ups may be better. We are using one now on asphalt and it is extremely good, we will be using it this winter on carpet. The High Roll center is the set-up Chris Tosolini used to win the Novak and the Carpet Nationals in Mod.
pops is offline   Reply With Quote
Old 10-08-2002, 06:18 PM   #2134
007yoshi's Avatar
Thanks for the big help
Old 10-12-2002, 06:10 AM   #2135
007yoshi's Avatar
WAKE UP!!!!
Old 10-12-2002, 08:13 AM   #2136
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey I'm awake but no racing this week or next as I have 2 weddings the. One to go to today and one next week as well. After that I will be racing again.
Old 10-12-2002, 05:55 PM   #2137
007yoshi's Avatar
Old 10-13-2002, 11:29 AM   #2138
wyd
Tech Legend
wyd's Avatar
007Yoshi have you had a chance to run your car at all or do you have only one track to race at. I know the one is closed for a few more weeks as you mentioned in a earlier post.
Old 10-13-2002, 11:59 AM   #2139
007yoshi's Avatar
No its not open until Nov. 2nd now and I cant go then, so the first race will be Nov 9th
Old 10-13-2002, 03:11 PM   #2140
wyd
Tech Legend
wyd's Avatar
Man I feel for you buddy. I just put on a bunch of new GPM stuff and I want to test my car out but can't make it for another week. I put on some new 4mm thick front and rear graphite shock towers (very nice ) and new GPM blue front 5 degree caster blocks and blue alum. steering hubs. The graphite towers are the nice woven graphite type. Man at 4mm thick they are super strong. This week would have been great racing weather as it has been raining on and off since Thursday.
I want to race!!!!!
Old 10-13-2002, 07:50 PM   #2141
007yoshi's Avatar
Man ive been given tons o setups for carpet.... I wish I knew which to start with
Which surface do you run on wyd?
Old 10-13-2002, 08:16 PM   #2142
wyd
Tech Legend
wyd's Avatar
I run indoor asphalt with foam tires at our local track. I guess with rubber tires on carpet I would try a setup with a little lighter oil and a little lighter spring. I guess a setup with 35 to 50wt oil and yellow or green springs.
I imagine with rubber tires on carpet traction is a little harder to get than when I run foams on carpet.
Old 10-13-2002, 08:27 PM   #2143
007yoshi's Avatar
should the rear spring be stiffer than the front?
Old 10-14-2002, 12:05 AM   #2144
johnbull's Avatar
Hi Guys.
Greetings from Malta.
We started our National championships yesterday, with some fairly good results for my Yoke.
I finished 2nd in both finals, so it's not a bad start. I am racing in stock this season. Son Josh won the mod class with his TC3, so you could say we had a good day.
I got a bit of a scare a couple of days ago. After practicing, setting up, etc for weeks, and having got it to run really well, i weighed it. Wow! I found I needed 60 grams of weight. I put the weight in the empty space behind the cells but that upset the handling. ventually I moved half of it (30 grams) up front, between the steering pivots, which brought the handling back to normal.
But that extra weight lost me so much straight line speed!
Next round next Sunday. i'll see what i can do till then.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 10-14-2002, 07:32 AM   #2145
TeamGoodwrench's Avatar
Default MR4 "Motherlode" FOR SALE !
Here it is guys -- I'm selling the whole lot -- OVAL is alive again here, so i'm going back to "go fast turn left" !!
FOR SALE:
<b>YOKOMO MR4 PRO WORLDS CAR ** AND** SP CONVERSION KIT !</b>
All in <b>** MINT ** condition</b>. Only raced on carpet and has had LOTS of TLC.
Full kit with original boxes and all manuals.
<b>ALSO A LOT OF NEW SPARE PARTS IN ORIGINAL PACKAGES!!</b>
The car has almost <B>ALL of the hop-ups</b> including:
* hardened universals front and rear (new in package)
* low cg aluminum servo mounts
* new front upper sway bar kit
* center aluminum one-way and direct pulleys
* lightweight hollow center pulley shaft
* 8 NEW Yokomo precision rims (new in package)
* spare low friction belts (new in package)
* SP aluminum transponder mount
Also included are a good assortment of Sorex tires on Yokomo rims -- mostly Sorex 20 - 24 compounds with Yok med or HPI red inserts.
Pictures are available if you would like to see it. I'm selling the whole lot -- NO REASONABLE OFFER REFUSED !
If interested, e-mail: <b>jeff.fritsche@esker.com</b>
Thanks!
TeamGoodwrench is offline   Reply With Quote
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
