Old 09-28-2002, 09:01 PM   #2041
Simon K's Avatar
Wink
Steering slop
Go back a page(or 2) and read the post I made about replacing the two silver ballstuds used in the SP steering(servo arm to bellcrank).
I replaced all the plastic rod ends and ballstuds before selling my car and the steering was fine, other than the two new silver ballstuds.
Ditching them and replacing with the shorter black ones used elsewhere in the steering minimised the problem.
It makes a big difference!
Also buy the Yokomo shim set and use it. With the stiff SP rear arms, Graphite fronts and correct shimming throughout the suspension, it improved the car.
Simon K is offline   Reply With Quote
Old 09-29-2002, 06:50 PM   #2042
007yoshi's Avatar
whats the part # for the ballstud your talkin about?
thanks
007yoshi is offline   Reply With Quote
Old 09-29-2002, 07:58 PM   #2043
TeamGoodwrench, try the new lowered C/G servo mount, (blue) part# ZS-203TA.
pops is offline   Reply With Quote
Old 09-29-2002, 08:01 PM   #2044
Our carpet track is opening in 2 weeks, and mod sedan will now be using foam tires for the first time. Any suggestions on what foam tires to buy? Has anybody tried the Yokomo foams?
Old 09-29-2002, 08:13 PM   #2045
ckh1328 Yokomo has just put in new shocks like the Tamiya shocks. The o rings are in a cartridge that unscrews at the bottom of the shock for easier re-building. The new part number is YS-ISSS-6. The upper caps still have the bleed screws.
Old 09-29-2002, 08:42 PM   #2046
Simon K's Avatar
Wink
thanks
A very good question.
I don't have the manual/Parts list for either my MR4 or my YZ10 that I sold at the same time, last month so I can't tell you the part number.
They are the standard short black ballstuds found on the steering blocks and the bellcranks, nothing special but they certainly fit the plastic ballends a lot better than the silver ones do....Someone here will have a manual or parts listing.....
Old 09-29-2002, 09:31 PM   #2047
007yoshi's Avatar
Thats OK I'll have my new kit tomorrow. I just wanted to know so I could see if it was stocked on a website.
Old 09-30-2002, 06:44 AM   #2048
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I have not tried the Yokomo foams but for Jaco's and TRC's the most common types seems to be Purple rears and Plaid (Orange/Purple) for the front. The Plaid is mostly a Purple with a small Orange (firm) ring on the outside of the tire.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-30-2002, 07:37 AM   #2049
007yoshi's Avatar
Hey Simon, would any length 4-40 ballstud fit those steering parts? I have a bunch of short and medium 4-40 black ballstuds from my losi xxx.
Old 09-30-2002, 03:57 PM   #2050
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
The Losi ones will fit but you will have to use Losi ballcups.
Speedo is offline   Reply With Quote
Old 09-30-2002, 07:44 PM   #2051
007yoshi's Avatar
Default HELP!!!!!
I'm in the middle of building my new mr4tc sp.... and its all been good except.... Those freakin tapping screws that go in the shock cap's bleeding hole have been giving me nothing but hell the screws refuse to go in all the way and now theyre stripped... i cant even get a part #!!!!!! What can I do?!? Will an AE shock cap fit? Thanks
Old 09-30-2002, 09:38 PM   #2052
Yoshi, you need to have a phillips screwdrive that fits really well, because the screw is so small. I found one at Sears that works really good without striping the screws. I do believe an AE cap will work in a pinch.
The part number for the Yokomo shock end cap is YS-8Y, I think there are two caps with screws in each pack.
Old 09-30-2002, 09:39 PM   #2053
007yoshi's Avatar
Thanks. I think Im goin the AE cap route. I looked and saw that they included optional AE shock bushings so it MUST be compatible hehehh.
Old 09-30-2002, 09:49 PM   #2054
You should stay with the Yokomo shock caps in the future, they are much better with the bleed screws. The Craftsman screwdriver I bought also fits the small screws that retain the hinge pins on the arms. Next time put a little grease on the threads before you install the screw, it will help a lot. Good luck!
Old 10-01-2002, 04:36 AM   #2055
007yoshi's Avatar
Is there a certain size to the screwdriver you bought? Oh and I have to stick to AE caps for now.... everywhere else has the yok. caps on back order and I need something for this weekend Thanks
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
