Old 09-27-2002, 08:36 AM   #2026
I've had this problem too with my special. if you haven't tried this already, try some toe-in in the front. I know just a little cured it for me.
Kdonks is offline   Reply With Quote
Old 09-27-2002, 08:44 AM   #2027
007yoshi's Avatar
When I had my schumacher 4wd cat3000 I had that steering problem. I bet wyd is right, besides, my xx4 and xxx sure have some considerable slop in the steering but it never wanders.
007yoshi is offline   Reply With Quote
Old 09-27-2002, 11:39 AM   #2028
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Remember you always need some slop because without any slop the car will not track straight either. You will always need a little slop for the car to work properly. More than likely it is a servo problem or the servo moves around in the car some.
Old 09-27-2002, 02:53 PM   #2029
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Replace all of your ballcups in the steering. Yokomo ballcups are soft plastic and they strtch and wear pretty quick. Also you can put shock o-rings on a few of the ballcups like the servo arm link and the ballcups on the servo saver etc. That should get the slop out.
BigDogRacing is offline   Reply With Quote
Old 09-27-2002, 03:10 PM   #2030
R/C Tech Founder
I've had success using GS Racing ballcups on both of my Yokomos. They seem to last a lot longer than the stock cups and eliminate a bit of the slop.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 09-27-2002, 03:45 PM   #2031
Good idea Shane, but as any of you that have owned Schumachers in the past know, Schumacher has the best ballcups BY FAR that I've found anywhere. Those bad boys will bust your dang thumb trying to get them on the first time!!
Old 09-27-2002, 03:59 PM   #2032
Default NEW YOKOMO
Where the pics of the new Yokomo Touring Car.... ? Does anyone have some?
Chris
ECHOLogic is offline   Reply With Quote
Old 09-27-2002, 04:19 PM   #2033
Erik R.'s Avatar
Yokomo may already have a new car, but we probably won't see it for a while. I think masami was running a Sp at the Japanese Nats.
Erik R. is offline   Reply With Quote
Old 09-27-2002, 08:28 PM   #2034
007yoshi's Avatar
I doubt we'll see a new yok for a year at least I hope so
Old 09-28-2002, 05:36 PM   #2035
Guys. I have a question about the stock shocks that come from MR4TCPro. Why the shocks have a screw hold on the top cap? I don't seem to find a screw hold on any other type shock. What is the hold on the cap for? Is the hold will make the shock better or what? Thanks.
ckh1328 is offline   Reply With Quote
Old 09-28-2002, 06:48 PM   #2036
TeamGoodwrench's Avatar
Hey -- what is the difference between the ZS-200L (anodized blue aluminum) servo saver mount posts and the ZS-200T ??
The ZS-200L is about $6 and the ZS-200T is about $12 ??
Thanks.
TeamGoodwrench is offline   Reply With Quote
Old 09-28-2002, 07:13 PM   #2037
Macky's Avatar
Send a message via AIM to Macky Send a message via Yahoo to Macky
That screw is basically a bleeder screw. After you put the cap you push in the shaft and any air should go out the hole then you put the screw in.
Macky is offline   Reply With Quote
Old 09-28-2002, 07:22 PM   #2038
Macky's Avatar
Thanks.
If I remember the ZS-200T is the complete parts needed for the servo saver and the ZS-200L is just the aluminum post anodized in blue for the servo saver.
Old 09-28-2002, 07:38 PM   #2039
OK thanks.
I was hoping the ZS-200T were titanium posts
Old 09-28-2002, 09:32 PM   #2040
I know, but shocks like Tamiya feel like better. When you push the shaft in, it will just push back by itself even the spin isn't there. But Yokomo's shocks won't come back out if you don't put a spin in it. So should the shafts come out even no spin is better or what?
Race Results Addict sa RC Manila Racers 1028 03-29-2016 09:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 04:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 09:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
