Yokomo MR-4 TC Thread
#2011
Tech Legend
Trader Rating: 51 (100%+)
Hey Yoshi I still run the SP. The only thing I broke was the front shocktower and front bulkhead. I had a really bad wreck but it was kinda a freak one as I normally don't have wrecks anything like this one. It was one of the worst I have had in 6 years of touring.
I would think like most cars that a arms, caster blocks, and caster blocks would be the stuff you break the most.. You know the other things like hingepins and a spare belt. I have a bunch of stuff and probably won't ever need it but it is nice to have. I have 2 front belts, 2 rear belts, 3 rear arm sets, hinge pins, some misc screws and shock towers. I will slowly buy more stuff as time goes on as my shop has a decent supply of MR4TC parts which fit my car. Mainly the rear SP arms are different because of the mounting holes.
The car has been great for me. The SP is a very nice car. I did take out the oneways because the track I run at is very tight and brakes are needed alot. I will run the one ways on longer more open tracks.
#2012
I know the part #s for the direct drive pulley, but what do i need to install a fron ball diff? thanks
#2014
hi, i've been away for the last 4 months in rc i'd like to ask if the camber mod masami is using right now is the same as the tosolini camber link before which has part # z-007f?
#2015
Well I ordered my Mr-4tc sp yesterday, cant wait till next weekend to test race it
Wyd, I think I'll see how I like the oneways before I spend $$$$ on a diff and a direct drive pulley
#2016
Guys. Can you tell me more about the one way, front one way, center one way, direct drive, etc. please. I want to know more about their abilities, and what effect would they make to the car, and their differences between each other. Thanks.
#2017
Tech Legend
007Yoshi the diff and the center pullies you need will run you about 40 bucks total. It might be a tad less. The lockout pulley is 17.99 at SpeedTech (I have one on now and will be ordering a spare) and then you need the plastic diff halfs, diff bearings, balls, and so on.
My track is just too tight to run the one way setup but it is nice to have both but if you can hook up with the one way you can save a few bucks. It is a fairly easy kit to build. No custom work is needed to get the car together.
#2018
The track Im runnin on will be 100 x 60 feet. Is that big enough for a oneway to seem handy? I figure if I get used to the oneways I'd be better off
#2019
#2020
I have never tried using just the front, but from what I hear it has a bigger effect than both the front and center one-ways
Josh
Josh
#2021
LOL all that was only from what I understood. I'll be running the 2 oneways it comes with
#2022
Tech Legend
007Yoshi It mainly depends on how flowing the track is. If it is really tight and alot of 180's and hairpins then a diff might be better, especially if they run alot of cars in the mains. If you have one ways you will have to let off sooner to make the corners and if you leave off the throttle more than half alot of times the car will want to oversteer. You counterparts running diffs will drive in deep to the corner and hit the brakes at the last moment and then punch it. You will carry more speed thru the corners but if they get the line on you or you need to let off alot you could be in trouble.
All I can tell you is in the long run it is nice to probably have both. When I look at the tracks like the big boys run they are almost always pretty big and flow very nicely so a one way is useful, plus they do drive very well. 2 weeks ago was the first time I could have used a one way and been faster in a super long time for me. If I had more time to practice I would have tried it but since I didn't I left the diffs in since I was comfortable with them and the car was pretty fast and stable for me with those rubber tires on.
#2023
Well crap I dont have 40$ to get a diff and directdrive and since I'm saving up for the xxx4 i wont untill mid november
#2024
ive just given up nitro and bought a mr4tcsp.
raced it once sofar but i think thay seem to have an issue
with the steering as in play{way to much}
having trouble with it wandering on the strait
no its not my driving LOL.
eny little mods yous have don to stop this...
#2025
Tech Legend
Mine has the same slop but if your servo horn fits tight and your servo don't move in the mounts that little slop shouldn't make the car wander down the straights. Try the low profile alum. mounts and make sure all your steering components more freely. Sounds more like the servo no properly centering under load.
I had a Schumacher car do what you are discribing and if I would bump a wall the servo would move in the mounts and another time the serov just didn't center right. I only use digital servos now (Futaba 9550) and never had that problem no matter how hard I hit the wall.
