Old 07-18-2002, 07:53 AM   #1771
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Hi Guys,
Just an update for anyone who may be interested
I tried on a set of Yokomo 26mm foams a couple of days ago, on the same track where I experienced tire overheating problems just a couple of days prior to the test. I was using the ST-A261M front (35 shore, pink) and ST-L261M (35 shore, green). Roll-out anf ride height were compansated to be similar to the setup used for rubber. The Yok USA website stated my front foams were "low wear compound".
Anyway, I was testing with another guy on rubbers ( he was the TQ in that race driving a MR4 TC Pro, I'm on a MR4TCSP)....... suffice to say the foams worked very very very well
For all its worth..... given the traction foams gave on that track, plus fade free performance.... they will make for damm good racing but it takes a huge chuck of skill out of the equation, coz as far as I can see.... trottle control becomes redundent with foams...... they grip too well..... period.
NightKidZ is offline   Reply With Quote
Old 07-19-2002, 01:30 AM   #1772
Simon K's Avatar
Just remember your car will be a lot lighter, up to 40gms if not more. The foam tyre car is lighter than one running rubber tyres/inserts. The weight will also reduce after each run, so keep a close eye on tyre wear and become friends with someone at a tyre shop(stick on lead wheelweights).
You'll be able to turn inside any cars running rubber tyres and will have plenty of grip from the start.
If you're happy with the tyres as they are-cool
If not, try a "30 shore rear compound" on the back.
Simon K is offline   Reply With Quote
Old 07-19-2002, 05:24 AM   #1773
NightKidZ's Avatar
Simon K : Thanks for the reminder abt car weight : )
Hahahaha 30 shore rears you say???? Hmmmm never traction-rolled my car on tarmac before.....heheheh
Old 07-19-2002, 08:51 PM   #1774
Simon K's Avatar
Wink
You'll also want to keep a close eye on Camber, we tend to run around 2 degrees negative.
Ideally, the tyre should wear "Uniformly" but if there are a lot of high speed corners one edge will go first(outer edge).
Trial and error will help with setup, you can see where the wear is occuring and adjust camber to compensate.
Old 07-20-2002, 05:32 AM   #1775
Keep Practicing and learn what your car like to do. Yes keep an eye on tire wear. I run 1.5 degree of camber.
rowdyrj is offline   Reply With Quote
Old 07-20-2002, 02:29 PM   #1776
I heard of kentech that Yokomo are making hop ups for the SP not brining out a new chassis yet. I also heard that masami was driving other cars before the on road worlds! - maybe this is old news but i'm the last to hear anything, the yok forum on the yok site is dead!
have a ncie day
sv
www.schumacher.clara.net - NEW TOP DECK!
schumacher is offline   Reply With Quote
Old 07-23-2002, 12:12 AM   #1777
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Default servo sideway?
could anyone show me or got a picture for this mod? i heard it makes yoru steering sensitive? i want that.
im a beginner on yok. just bought a week ago. MR4TC custom kit.
pls hlp.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 07-23-2002, 12:19 AM   #1778
jfc_tech's Avatar
pls hlp.
Old 07-23-2002, 04:04 PM   #1779
mo
mo's Avatar
Default Setups
Hey guys. I just added a new setup to my web page. It is probably mainly for low to medium grip asphalt like when it's really hot. In Northern California (Speedworld and Ripon), the tracks get up in the 140 to 160 range pretty easily. This generally causes the rear to get pretty loose. The setup I am running now seems to keep that to a minimum. www.mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 07-25-2002, 02:04 AM   #1780
jfc_tech's Avatar
can anyone help me on this matter? don't tell me, no one knows about this mod by masami??? pls...
Old 07-25-2002, 07:19 AM   #1781
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
JFC- I don't have a picture here at work, but basically you cut the ears off of the servo, and mount it horizontally. To do this, you must change the servo saver peices to the other ones that came with the kit. It moves the arm to the passenger side of the servo saver posts. I'm not sure about what other did, but I had to dremel a small cut out for the servo arm. When you go to test fit the servo you'll see what I mean. Anyway, to mount the servo I used Zap Goo. It's sorta like shoogoo, but a lot stronger. If you don't have the optional servo saver mounts you can order them and even get them in gfaphite, but I don't have the part number.
If I get a chance after our big race next month, I'll take some pics and do a small tech article to add to the other tech articles on our club's website. www.msra-racing.com
Hope this helps!!
BigDogRacing is offline   Reply With Quote
Old 07-25-2002, 06:30 PM   #1782
Send a message via AIM to ZER01
Default Servo Modification for Yok MR4 series
Here's some more information about that mod jfc_tech. This mod will put more overall weight towards the front of the car which will give the car more steering when exiting corners.
ZER01 is offline   Reply With Quote
Old 07-27-2002, 02:49 AM   #1783
jfc_tech's Avatar
I CAN'T SEE THE PICTURE!!!???
Sorry proudwinner, but the attached graphic file is only text description of the mod and no picture to show it.
but anyway, thank you for all yer concern and help nevertheless. AND yes, you too BigDogRacing. give me more picture!!???
Old 07-27-2002, 03:06 AM   #1784
jfc_tech's Avatar
Exclamation GEARING QUESTION
I'm using 11T motor and it seems the standard 78Tspur 22Tpinion do not seem to work well. i mean at the end of race, the motor and my sanyo 3000 battery very hot. it must be overgeared, right? our track is very tight with lots of corner and hairpin and one long straight. pls advice me.
Old 07-27-2002, 01:13 PM   #1785
mo
mo's Avatar
The motor and batteries are just going to get hot. If at the end of the race you still have good power, you are probably fine.
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
