Old 06-17-2002, 07:48 PM   #1726
Simon K's Avatar
Wink
Sweeeet.
Might be getting an off road track built next to our on road one.
There's a bit of a surge of new members keen to play in the dirt, I'll be able to run my old YZ10W(Yay!)
Simon K is offline   Reply With Quote
Old 06-18-2002, 09:44 AM   #1727
Yoke Racers,
Everybody is looking for this part : King pin ballstud - part # ZR-007F
What are they for ? Is it a new upgrade part ?
Ralf is offline   Reply With Quote
Old 06-18-2002, 10:49 AM   #1728
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Kingpin ballstud for front camber link modification.
BigDogRacing is offline   Reply With Quote
Old 06-18-2002, 11:33 AM   #1729
Big Dog racing,
Thanks for the info, How do you make these modifications ?
I also heard about modifications on the rear of the car, any infos ?
Thx
Old 06-18-2002, 12:30 PM   #1730
Here's a picture of the rear hub mod borrowed from Mo's website.
The total height of the rear hub should be 30mm after cutting the top off. A standard 3mm thread ballstud should be used.
In the front, you just whack the ears off the top of the hub carrier and use those kingpin ballstuds in place of th top hex head kingpin.
Old 06-18-2002, 01:41 PM   #1731
WOW!
Now my question how come the main gear i got in the car is differnt from what i purchased its listed as the same part number does anyone know? i have the regulat tc
Chris@WeaponR is offline   Reply With Quote
Old 06-18-2002, 05:58 PM   #1732
anyone have experinced that their rear belt rub against the motor heat sink? not sure if it on the motor heatsink but the belt after few races begin to loose its label on the otherside and makes it thin and results to a loose belt!
maski is offline   Reply With Quote
Old 06-19-2002, 02:00 PM   #1733
2nd ANNUAL BEAT THE HEAT SUMMER BASH
We'll be holding our 2nd Annual race on the 18th of August. for more information and updates check out the MSRA thread on this site.
Race held outdoors on Asphalt, OK traction, little bumpy in certain areas. VHT will be laid down.
Old 06-22-2002, 07:52 AM   #1734
superk's Avatar
Hi guys! I just bought a new 3000HV batts pack! and wondering what is the best way to start taking a good care of it?? How many charge do I have to run b4 I can get it up to the maximum performance?
Thanks.
superk is offline   Reply With Quote
Old 06-22-2002, 07:56 AM   #1735
superk's Avatar
Another questions please! I have like 12 pack of an old used 3000Sanyo and panasonic pack! It's like a year old and I bought it used! I just bought a Turbo35BL and some how those cell # is really low why is it?
Also..I hert that I can do a dead shorting batts and it will help on the performance? but...What is dead shorting? can you explain to me how to do it? I hert that I need a discharge tray??
Also Zapp the batts? How can I zapp the batts? What kind of equipment do I need?
I just hate it when my buddy have 2 labs over me and we have the same skill of driving!! Please help!
Old 06-22-2002, 08:16 AM   #1736
superk's Avatar
Ops ..I was in difference form sorry...
Old 06-22-2002, 10:55 AM   #1737
shrekair's Avatar
Trader Rating: 9 (91%+)
yes my losi is fast, no you may not drive it. actually i would cuz losi drivers are very courteous
shrekair is offline   Reply With Quote
Old 06-24-2002, 05:40 AM   #1738
what's the difference between an mr4-tc sp and mr4-tc sp rs? i only saw this at a japanese online hobby shop!
Old 06-24-2002, 07:32 AM   #1739
ausracer's Avatar
in remember some talk of this a while ago. im pretty sure the rs is a lower spec car then the special. simon k will be able to answer this, he was the one with the catalogue.
ausracer is offline   Reply With Quote
Old 06-24-2002, 09:30 AM   #1740
oh, also what an upper I arm set? my manual is in jap version so i have a hard time identifying every part. what do you call the round steel part that has a hole on the middle where a screw is inserted to tighten. they're found in the shock towers F/R with another of them on the rear hub carrier! the alum. linkage is connected to them with the plastic part. anyone knows the part number? thanks in advance
Does Yokomo sell rear bulkhead w/o the cap. they only have the set with part number zs-300rt.
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
