Old 05-22-2002, 10:56 AM   #1636
Trips's Avatar
Trader Rating: 16 (100%+)
I've been wanting to try a Yok since April of 2000, and for one reason or another I haven't. The closest I came was the end of last summer when I actually had one but didn't take the radio out of my Losi...
I just ordered the MR4SP from my local shop, it should be in by Thrusday or Friday... I'll probably run the Losi this weekend, but after that I'm definitely putting the SP to work.
I'm really looking forward to this...
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 05-22-2002, 11:02 AM   #1637
superk's Avatar
Default ON EBAY!! Yokomo MR4TC Special with extra parts! with picl.
On ebasy again! help me out! I need the money for real car!
Thanks guys!
http://cgi.ebay.com/ws/eBayISAPI.dll...ndexURL=0&rd=1
superk is offline   Reply With Quote
Old 05-22-2002, 06:53 PM   #1638
rcruv's Avatar
Dear yokomo mr4tc experts,
could you check if following spring rate is correct?
Thank you in advance.
(g/3mm)
ys-1360 Black 519g
ys-1355 Blue 561g
ys-1465 White 591g
ys-1460 Flourescent Yellow 690g
ys-14525 Stainless 692g
ys-1455 Flourescent Green 738g
ys-1450 Flourescent Orange 949g
rcruv is offline   Reply With Quote
Old 05-24-2002, 09:01 AM   #1639
This list was sent to yokomofinland from Yokomo in japan so they should be correct. As you can see the rates are the same as yours rcruv.
TC springs (g/3mm)
YS-1360 Black (519g)
YS-1355 Blue (561g)
YS-1465 White (591g)
YS-1460 Hot Yellow (690g)
YS-14575 Hot Pink (703g)
YS-1455 Hot Green (738g)
YS-14525 Stainress (692g) (different material)
YS-1450 Hot Orange (949g)
GT4 springs
YS-1560 Dark Green (870g)
YS-1660 Red (982g)
YS-1655 Yellow (1210g)
YS-1650 Green (1335g)
YS-1760 Silver (1389g)
YS-1755 Gray (1416g)
YS-1750 Brown (1722g)
moonman is offline   Reply With Quote
Old 05-24-2002, 04:03 PM   #1640
Trips's Avatar
I just finished my SP, and I'm curious about something... does anyone know the equivalent for the "450" shock oil included in the kit?
Thanks,
Trips
MARSHAL!!
Old 05-24-2002, 04:54 PM   #1641
R/C Tech Founder
R/C Tech Charter Subscriber
I always assumed it was something like 45, but I'm probably totally wrong. I never used it in either of my Yoke kits.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 05-24-2002, 07:02 PM   #1642
Moderator
Speedo's Avatar
It is equivilant to 40wt
Hope you enjoy the car
Speedo
Speedo is offline   Reply With Quote
Old 05-25-2002, 03:23 AM   #1643
Simon K's Avatar
Talking
The Yokomo kit shock oil is quality stuff, don't lose it like I did...
Simon K is offline   Reply With Quote
Old 05-26-2002, 07:18 AM   #1644
Regional Moderator
daniz24's Avatar
Any news from Yokomo about their new touring car??
And also their brand new 1/8 On-Road Gas Powered.......
daniz24 is offline   Reply With Quote
Old 05-27-2002, 12:29 AM   #1645
Trips's Avatar
I raced my new SP Saturday night and Sunday, the car is fast but so unstable that it's almost frightening to drive.
Any tips on where to go from the stock SP setup to get the car into a more comfortable feel, or should I just get rid of the oneways and put a solid center shaft and a regular diff up front?
Thanks,
Trips
MARSHAL!!
Old 05-27-2002, 05:01 AM   #1646
Regional Moderator
daniz24's Avatar
what tires are you using???
I suggest you use Sorex 36R with Sorex Type B Medium Insert for better handling
Old 05-27-2002, 09:22 AM   #1647
Trips's Avatar
It was a bit cool on Saturday night, I ran Sorex 32R with Yokomo 037M medium inserts on Yokomo dish rims. I also ran some TakeOff 27's which worked a bit better for the mains as the temperature was getting cooler.
There seems to be some problems with Sorex tires around here... My 32's seemed to blister the tread after just one run, and it was a cool night and the track wasn't even warm. Another driver ran a new set of 32's and one of them lost a strip of rubber and the belt was showing again on the very first run.
Trips
MARSHAL!!
Old 05-27-2002, 09:29 AM   #1648
STLNLST's Avatar
Trader Rating: 19 (100%+)
Thanks,
Trips
Let's hope that Yokomo is working on a new car cause that thing looked terrible this weekend at the Reedy Race. Masami looked fast as always but their were other driver's that were fighting the car all weekend. I saw a few guys run the MR4TC PRO instead of the Special.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-27-2002, 12:37 PM   #1649
Moderator
Speedo's Avatar
Trips, you might want to try the camber link mods. If you haven't heard of them, what you do is use a ballstud on top of the kingpin int he front castor blocks (part number ZR-007) Most people use the outer hole on the tower to mount the link when using this mod.
In the rear, you cut a bit off the top of the rear hubs and mount the ballstud vertically, again probably using the outer hole on the tower...I forget how much you are supposed to cut off.
Speedo
Old 05-27-2002, 08:34 PM   #1650
Simon K's Avatar
Wink
There's some pics from the Worlds here...
http://www.mytsn.com/events/imggal.asp?eid=816
Including one of Masami's car.
Race Results Addict sa RC Manila Racers 1028 03-29-2016 08:55 PM
New Yokomo TC, the BD-5 YokomoAmerica Electric On-Road 3801 04-26-2014 03:05 AM
Yokomo MR-4TC SD Cat Electric On-Road 15814 04-18-2014 08:15 AM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 01:10 PM
