Yokomo MR-4 TC Thread
#1531
Yeah, I'm looking forward to it. Hopefully they won't do like Losi and release a kit with absolutely no hopups.
Speedo
Speedo
#1532
Thanks for the link...How are Hewlett Packard and Microsoft related to a new Yokomo car?
Speedo
Speedo
#1533
Most likely the new car will be similar in looks and layout to the YMP option available for the MX-4.
#1534
Could be...
#1535
mr4tc ?
i am looking at getting a new car i am over the tc3, so i am looking at the special mr4tc , and my ? is what hop ups is best to get for this kit , like the direct drive , and ect. ? thanks for your input and help. chris
#1536
Read down a bit and you will see it is possible that Yokomo will come out with a new car in the next 6 months. If you still want a special, it is a great car, go for it. I would leave the one-ways in, for durability parts you might want stronger front axels and some graphite shock towers.
Speedo
Speedo
#1537
re:
thanks speedo, for the info. i heard that yokomo is comming out with another kit , but i just out of woundering i seen at speed tech this direct drive gear hop up. is this something good to get ? or what do you run ? thanks ...
#1538
Good timing, Looks like I'll be starting training for a new Job on Monday. Bring on the new Car
#1539
LOL, what's the job?
Well since the kit comes with both a front and center one-way, installing the direct drive center pulley leaves you with just the front, if you want to go full dd, you need the buy a front diff. In general, the one-ways will be faster. If your track doesn't have much grip, or if your driving style is braking hard, you might want to go to dd.
Speedo
Speedo
#1540
new yokomo car
has any one seen a proto type or know when it is going to be hitting the hobby shops ?
#1541
Naw, apparently Masami and crew have just started testing and it is all very "hush hush" (think XXXS)
Speedo
Speedo
#1542
Delivering Juice and Energy drinks all over Wellington. Should be a bit of a laugh, will finally have more money for toys..For the SP and the GSR...
#1543
Red Bull??? That stuff is the sh*t!
#1544
what does the mr4 bulkhead screw set include?
#1545
What shoud be the recommended length of the front and rear shocks? Do you guys use the longer shock-ends for the front and shorter shock-ends for the rear as per instruction?
