TEAM ASSOCIATED DB8
#61
After looking over truck I saw I'm running stock droop. The droop was very wrong out of the box.
Also to get proper ride height I'm running 8mm of spring spacers in the front, a 5mm and a 3mm stacked. In the rear I'm running 3mm of spring spacers, just a single 3mm spacer.
I made gauges out of zip ties to help set the droop correctly.
#63
Page 27 middle step shows adjusting front droop to 103. Page 28 first step shows adjusting rear droop to 122.
Page 42 says 109 and 127.5. The thing is it says truggy shown but applicable for all vehicles. That doesn't make sense because that version of that truggy had longer shocks than the sc8.2 and rc8.2.
Either way, my droop was way too short out of the box, the rear was almost arms level.
I have my truck completely torn down at the moment, but with those spacers I think my rear arms were slightly above level and front arms were level or slightly below level.
I'll get it back together here shortly.
#66
No, I forgot I even had the stock one. I thought my mmx esc might have died, but turns out something broke inside my lipo. It reads good voltage but has connection error and rattles.
I sunk car when I was running on water with paddle tires.
Shallower water.
Shallower water.
#67
Got it back going. I run mostly off road, just doing quick test of new setup. Feels faster than video shows. Just running for like a minute or so. 6s 17t 1390kv.
+ YouTube Video | |
#71
Took the car to the "desert" - and old quarry for some runs with the new 2200kv hobbywing sensored setup. Also have the spare tyre mounted and the thick rear sway bar.
https://youtu.be/fUqQGSCPM7k
Have a tekin rx8 coming (to replace the SCT Pro) - hope its worth it! Also tossing up a Tekin T8 1900kv motor...
#72
+ YouTube Video | |
