Like Tree1Likes
Old 06-19-2017, 06:27 AM   #1
Default SWOLLEN LIPO
How do you guys dispose of your batteries. It still works I am just afraid of it now. I tried the freezer trick and it went down but as soon as it got back to room temp it had swollen back up.
just looking for the best way to get rid of it.
Rahdog07 is offline   Reply With Quote
Old 06-19-2017, 06:42 AM   #2
Bucket of salt water. Leave it for a week and it will be fully discharged, then you can dispose of it.
Mi4cxl is offline   Reply With Quote
Old 06-19-2017, 06:42 AM   #3
Or failing that shoot it like mine and watch it burn
Old 06-19-2017, 07:02 AM   #4
EbbTide's Avatar
Trader Rating: 35 (100%+)
You can also take it to your local fire department. At least in my area they'll take them and dispose them for us.
EbbTide is online now   Reply With Quote
Old 06-19-2017, 07:09 AM   #5
Trader Rating: 216 (100%+)
I discharge the battery down as low as possible w/charger, then I have a pr. of taillight bulbs soldered together and I plug the battery into that to discharge it down to nothing (lights out) and then do the salt water thingy for week and a half at least then toss in the garbage.
Andy Koback is offline   Reply With Quote
Old 06-19-2017, 07:20 AM   #6
JRSlash's Avatar
If there's a batteries plus store around you, they will take them.
https://www.batteriesplus.com/t/recycling/battery
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
Tekno EB410
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
JRSlash is offline   Reply With Quote
Old 06-19-2017, 08:35 AM   #7
loaba's Avatar
Do the salt water thing. It's kind of a cool science experiment.
Kyosho Ultima RB6.6 mid-motor/3-gear laydown 17.5t stock
loaba is offline   Reply With Quote
Old 06-19-2017, 08:48 AM   #8
the rc guy's Avatar
salt water trick is whats known as a wives tail does not work will not discharge a battery..might dissolve allunimum tabs.(in weeks).. hook a light bulb dis charger on it..let it sit.. depends where you live many dpw have a battery drop box or a batteries plus store will take ..and many land fills will also take..
the rc guy is offline   Reply With Quote
Old 06-19-2017, 08:49 AM   #9
Most Home depot have battery drops it front of store
ratititat is offline   Reply With Quote
Old 06-19-2017, 08:54 AM   #10
loaba's Avatar
Should I post a pic? Got a battery soaking right now, watched as the battery began discharging before my eyes.
Scott R likes this.
Old 06-19-2017, 08:57 AM   #11
Some tracks also dispose of batteries
SlashBash10 is offline   Reply With Quote
Old 06-19-2017, 09:01 AM   #12
Rick Hohwart's Avatar
It does work and will discharge (bubbles) until the tabs are dissolved. You think it is dead because you can't read any voltage. But it isn't. Good think is that it will be difficult to short circuit.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 06-19-2017, 02:25 PM   #13
the rc guy's Avatar
salt bath has been debated for years .. dissolving tabs does not discharge a battery....puncture it after you think the salt bath work..show me that video..
Old 06-19-2017, 03:17 PM   #14
I read somewhere that the salt/water brine creates an electrical draw between the +/- poles and that will finish off the leftover voltage. Some electrical guru should be able to verify this. Still need to discharge the battery as much as possible before the brine solution.
Old 06-19-2017, 03:56 PM   #15
I've seen a youtube video of the salt brine thing where the pack still explodes when punctured, after like 3 weeks! So no, that method does not really work. Plus...anybody notice that it takes multiple weeks?
1) Get a small-ish light bulb, (I have a couple 25 watt halogens), connect it to your battery, and walk away. How long it takes depends on the wattage of the bulb...in my case it was about 30min with 2 bulbs going.
2) When you come back, and the bulb is not lit up any more, the battery will be 100% discharged. Maybe check with a volt meter to make sure? The pack will get a little warm in the process, but nothing exciting. Do it outside if you are worried...
3) Cut off battery the connector, strip back insulation, and twist wires together. Secure wires together with wire nut or electrical tape. This makes it impossible for the pack to build up any charge after you drain it.
If you do this, your pack is guaranteed 100% safe. Poke it. Stab it. Throw it through a wood chipper. Nothing is gonna happen.
WrongClub Racing (Horray! My own team why not?)
fredygump is offline   Reply With Quote
How do i dispose of my old Lipo's mandy116 Electric Off-Road 23 02-18-2011 09:27 AM
SMC lipo's. Rubbish? JIM1 Electric On-Road 47 07-05-2010 07:42 PM
Can I revive these lipos?? JuddGA Radio and Electronics 13 02-06-2010 05:41 PM
