stuck bearing race in rear alum sc10 hub
i have a alum rear sc10 hub with a stuck outer bearing race in it how do i get the race out so i can put a new bearing in it? ive herd about heating it up but dont know what temp and if it will ruin the alum hub any help is appreciated
Turn your oven on the highest setting it has. Put the hub on a cookie sheet or something similar. Leave it for about 25-30 minutes. Then take it out. Use oven mitts or something of that nature. You should be able to get the race out pretty easy. If it doesn't come out easy just put the hub back in the oven for a few more mins.
Once the hub is hot enough you should be able to use a small pick or even a small hex wrench tip to easily push the race out.
Hope this helps
Hope this helps
This shouldn't be so difficult.
Use a dremel with a rounded diamond bit and create a recess on the inside of the race and then secure the hub on something so the bearing has clearance and then use a good flathead screwdriver and place the tip on the edge you dremeled into the race and proceed to tap it out.
DONE!
DONE!
Hope this helps
Hope this helps
