4wd buggy???
4wd buggy???
I'm having trouble deciding if I should keep my hot bodies d413 or pick up either the new Associated B64d or the Tekno eb410,is the new associated durable that's my main concern not that I wreck a lot or anything I just like to know I have a durable car any suggestions would be helpful thanks
If you want something new go for the B64d but if you like the way the d413 drives than keep it . I'm new to the D413 but its jumps and is pretty much the strongest 4wd buggy out there wears good just a little sloppy not a bad thing.
Comparison Review
Ok sounds good I do really like the d413 because of its durability but a couple guys at my local track got B64d's and that's the only 4wd buggy that can run with my d413 and I don't really like the slop I have in the steering with the d413 so yeah I'll probably run it until it runs no more and then I'll consider buying the b64
If your looking at chooseing something strong in a 4wd buggy the D413 and this new Tekno coming out is the only ones .
small sample size, but i have 3 race days on my B64 and i have yet to break anything. i had a 413 for about a year and a half and broke a ball cup and two front shock tower supports (the plastic a-frame, not the carbon fiber) and the car was down for weeks as nobody had the supports in stock.
The B64 is an ok car. It has a few weak spots and lots of things do break. Its average on the breakability scale. The one upside is that its super easy to work on. That's its strong point. If you're concerned about breaking stick with the D413 or get an XB4. The 22-4 2.0 is also more durable than the B64. I have, or have had, them all. The D413 is a good car and if you're competitive with it I see no reason to make a change....unless you're just bored and want to try something new.
I don't know how you broke them things on that buggy ive jumped hugh triple jumps that were welded metal at a indoor clay track.
Part support now isn't to bad for that buggy .
i know of several people in my area who broke rear camber link ball cups including myself. as for the front shock tower support, apparently i wasn't the only one as the part was sold out for literally weeks.
Tech Legend
The issues being reported by some with the AE car personally I think may be related to say a bad run of parts. But, even if it isn't, the vehicle is pretty new so over time AE I am assuming will beef up where they see fit.
Because of this reasoning to me, I ended up with 2 (actually 3 but sold the extra) D413s as they are cheap to buy, pretty durable and they are popular at the track I attend for indoor carpet due to those facts, so variety of people can support each other on parts.
Performance wise it works great too and still has backing from a race team.
All in all, very happy with the car.
If you are wanting that "new feeling", I will say the Exotek chassis with exotek diff mount can give you that. The main complaint I have with the car is getting to the center diff with the stock setup. Really a pain compared to other designs. The front an drear diffs are not too back fo rme at least,l but man that center ... lol. Now, should be much better.
Xray XB4.... I previously had a D413 for about 1.5yrs and switched to the 2016 XB4 back in December. Absolutely love the XB4 how easy it is to work on for maintenance and the build was super smooth and easy. The car is very durable and dependable a lot more set-up options IMO.
I'm able to drive the XB4 harder than I could with the D413 and was nice to prove out on same layout before doing a track change.
