TLR 22 4.0
#796
Anyone having issues with the rear ballstud becoming loose in the rear hubs (with 2mm or larger shim)? Assuming this is due to the aluminum top plate, not allowing the ball stud to screw into the plastic as much as it did before. Anyone try 10mm studs when using a 2mm shim?
I had one that was loose/stripped the first time screwing it in by hand.
Someone suggested using the 10mm stud with the 2mm shim. I switched over to that last week. I haven't driven it yet, but seemed to fit fine.
I remember a thread months ago about the 10mm stud going through the hub with no shim in the SCT thread.
#797
The tlr 4.0 chassis protector looks just like the tlr 3.0 version, just larger for the new chassis. Space to remove bumper and lock back in like the 3.0.
#798
TLRacing
I have mentioned this along with others a few pages back.
#799
Frank do you mean you look in the hub without the bearing inserted to make sure you don't see an obstruction? Or do you mean something more technical?
#801
What are peoples thoughts on the front and rear sway bars for the 4.0 on carpet. I will be running on a fairly tight track with high grip. I want to know if I should be ordering these upgrades.
#802
Sway bars are on the kit set up for carpet/astro so I would say yes. Although it probably depends on the level of grip and tyres you are using.
#804
Thanks, I will place an order for these. Had the aluminium diff for awhile actually since it first came out.
I've seen setup sheets with the HRC anti squat and toe-in plates. Anyone test these 2 parts out on carpet yet?
#806
Frank,
Noticed there is no dust cover for diff screw on sr diff and that thrust assembly is exposed to dirt and dust after installing composite outdrive. Very little time on my sr diff before noticing it needed service and wondering if this is a source of the problem. Have you had any success in servicing the thrust assembly only vs removing the diff from the buggy and opening up and servicing the entire assembly? Do you recommend using black grease sparingly on the thrust assembly so as not to attract dirt and dust? I typically use a normal amount of black grease per your video on thrust assembly fyi. Also, I use plenty of clear grease on my diff assembly and remove excess when I break-in diff while it is outside of a buggy fyi. Just trying to figure out how I can extend servicing the diff so any suggestions would be appreciated.
#807
I built mine just how the carpet setup is done in the manual (page 74). Still waiting on the sway bars to be in stock. I can tell you it handles fricking awesome on carpet even with the gear diff and no sway bars for now. Curious to see how they will improve my already quick 4.0
#808
#809
I used the LRC in the rear like the setup says. I haven't measured my ride height yet so im not sure 100%. I have read online other people are using yatabe arena springs which are a little shorter than standard springs. I am still trying to find yatabe (green) rear springs for myself. For now I am using Associated orange in front and the kit rear springs.
#810
Washout, definitely run the sway bars, it makes a big difference, try the different sizes to be sure of the one you like best, I'm running 1.4 front and rear right now, on a tight track.
To get rear end down until you find the shorter springs use the Associated 0 spring cups.
