    Hide Wikipost
Old 03-22-2017, 06:19 AM   -   Wikipost
R/C Tech Forums Thread Wiki: TLR 22 4.0
Last edit by: Matt M.
22-4.0 Wiki
Print Wikipost
Like Tree252Likes
Old 03-04-2017, 01:18 AM   #61
Looks nice shame I just bought a 22 3.0
daz_75 is offline   Reply With Quote
Old 03-04-2017, 07:26 AM   #62
Trader Rating: 14 (100%+)
Originally Posted by TitanBurns View Post
This is NOT a 3.0 -> 4.0 conversion. I just want to get the new laydown into my 3.0LD (newer dirt laydown). I race it on carpet, so I was hoping to take advantage the setup options for carpet
Another thought I had..... Can I buy the 4.0 and build it onto my Dirt laydown chassis? minus the newer mud guards? I just finally got bodies painted for my 3.0 and don't want to have to get new ones done lol
I haven't seen it confirmed that the dirt lay down tranny uses the same holes as the new molded tranny.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-04-2017, 07:41 AM   #63
Trader Rating: 39 (100%+)
To the chassis maybe, to the waterfall brace no. The 4.0 waterfall brace is much lower than the dirt trans.
sksdean is offline   Reply With Quote
Old 03-04-2017, 07:44 AM   #64
One track mind. The stand up setup I can see your point I would think so to.
Old 03-04-2017, 12:06 PM   #65
Some questions for Frank if you don't mind answering them ?!
1) which springs will be in the kit ?
2) how the diff height adjustment will work (I assume inserts similar to the 8ight rear diff that can be flipped?)
3) will the original 3.0 body still fit the 4.0
4) will 4 gear stand up box still fit this layout?
5) is the rear shock tower on the laydown a different geometry to the standup?
As a Uk based racer I was disappointed when the SR was announced as I though the rest of the world had been forgotten. Glad to see TLR have rewarded our patience with a "all-in1" kit.
TLR 22 3.0
TLR 22 3.0SCT
Hobbywing
Sanwa
losi8lunie is offline   Reply With Quote
Old 03-04-2017, 12:17 PM   #66
Default Losi 4.0. Looks awesome ! For carpet and turf !
I run on high grip carpet indoors. Or AstroTurf outside. I have 2 Losi 22 3.0. With carpet lay down. I am by my choosing a Losi loyalist. And the 3.0 on carpet have been ok for my skill level fun easy to drive durable. But always a step below other cars on carpet like b6 and yokomo and X-ray. I have already told local hobby store to get me two of these 4.0. Cause they finally came out with something that's should be highly competitive on the surface that I run on Can't wait for April !!
tlr224 is offline   Reply With Quote
Old 03-04-2017, 02:55 PM   #67
jag5508's Avatar
My SR is should be here Tuesday lol . Maybe I'll send it back and forget about switching . I only wanted it for stock . Is anything compatible with the 4.0 ?
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 03-05-2017, 10:42 AM   #68
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
1. LF springs, silver front and white rear.
2. They are eccentric inserts for the diff and two different inserts for the idler shaft.
3. It will not.
4. Yes, it sure will.
5. Shock tower geometry is the same.
We've always working towards making it dialed for as many as possible.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 03-05-2017, 11:25 AM   #69
F N CUDA's Avatar
Trader Rating: 31 (100%+)
After further review and also having jumped on the 3.0 SR,
I realize that if I had a 4.0, I would most likely set it up just like my 3.0 anyway and still be wishing that I had the lightweight parts as well since I run in the stock class.
So for me, on medium bite clay and stock racing, the 3.0 SR is perfect.
3 gear stand up, shocks mounted rearward, slipper eliminator and all the lightweight stuff.
Good luck getting one if you want one now.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 03-05-2017, 12:10 PM   #70
Trader Rating: 19 (100%+)
I feel the same way about my SR so not as excited about the 4.0 as my SCT/T 3.0s. Buggy still has so much more to offer than my slowly improving skills can take advantage of. Will eventually want a 4.0 just because but don't feel the urgency. Of course, that can change quickly when the track owner posts they're getting kits in this week and a couple aren't spoken for.
rayzcar is offline   Reply With Quote
Old 03-05-2017, 12:46 PM   #71
jag5508's Avatar
I'll most likely keep it just because all the light weight stuff . I got to for 17.5 in the first place . Who knows maybe a 4.0 later if I want to run mod too .
TOYZ 4 BOYZ
Old 03-05-2017, 02:01 PM   #72
F N CUDA's Avatar
Or if you need one for carpet, turf or super hi bite you'll be hooked up with the laydown options.
For me where I'm at, already super dialed on medium bite surface
Craig Hammon
Old 03-05-2017, 04:26 PM   #73
Send a message via AIM to 4wd Racer
3. It will not.
Wanted to expand on question 3.)
con't 3.) When the new 22 4.0 2wd buggy is built in either standard 3-gear stand-up (or 4-gear stand-up) configuration with the shocks behind the tower (normal location as seen on the 3.0 of course), the original 22 3.0 body would able to be carried over & used on the 4.0 with no issues. Please correct me if I am wrong.
(However if the 3-gear laydown option is chosen, with the rear shocks in front of the rear tower (new optional rear shock location), then the new 4.0 body must be used in this case obviously.) Correct?
Far as using the 3-gear laydown, with the rear shocks behind the tower (same normal usual location as the 3.0) what is the case? The 3.0 body would work in this case as well? Would that be correct as well?
New Question 6.) The 3.0 built as is (with the new optional bell crank steering at the time) with the stock front spindle used only specifically for that bell crank system has 4mm trail built in the front as standard, even though it's marked as SC2, or what is the case here again? (4mm trail is stock & standard for the 3.0 correct or?)
Note: If all this is correct. Maybe we could get it added to the WiKi as well? Good useful info for anyone wanting to know in the future to compare the differences between the 3.0 and the new 4.0 car far as trying out new adjustments
Team Losi Racing 22 3.0, 22.4, 22T 2.0, w/ Spektrum DX4R Radio & Servos, HobbyWing ESC & Motors, Team Orion Batteries & Chargers, LRP power supply. (Mod Off-Road Nationals Finalist)
4wd Racer is offline   Reply With Quote
Old 03-05-2017, 07:04 PM   #74
mtn bkr's Avatar
Trader Rating: 17 (100%+)
The 3.0 body will not fit the 4.0 chassis no matter which rear shock/transmission configuration you run. The 4.0 chassis is wider behind the servo area.
Ron M.
mtn bkr is offline   Reply With Quote
Old 03-05-2017, 07:13 PM   #75
At first i didnt like the 4.0 body but now its growing on me. Wonder if it would work on the SR chassis. Im running the Yokomo body now and there is a little gap up front. Looks to be close to the new chassis
TLR 8ight 4.0 nitro roller brad996 R/C Items: For Sale/Trade 15 05-29-2017 06:24 AM
For Sale: (one race old) TLR 8ight-E 3.0 &TLR 8ight 4.0 Nitro gporta77 R/C Items: For Sale/Trade 6 03-31-2016 05:10 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dodge426
