TLR 22 4.0
#1667
I ran my TLR 22 4.0 laydown on an outdoor wet track with holeshots. Added the TLR 25 gram weight plate under the gearbox and kept the brass RF hinge pin holder. Shockingly, got very good grip. didn't want to change to much on the setup, as I run on med/hi bite clay and just wanted to add some weight. Buggy was awesome. If I were running that track more regularly, I would have added 0.5 degrees of toe to total 3.5 degrees as Frank has suggested. Would have been money I suspect. Also can lay the shock down in on the rear tower for some sidebite, but I would try it laydown.
#1669
Does the 4.0 SR kit come with the parts to run the Laydown tranny raised or lowered like the original 4.0 kit? plus the +3.5 rear hubs? I mostly run 17.5 class with my 3.0 with the original standup tranny. Just wanted to make sure I have the same chassis adjustments as the normal 4.0 kit (minus the option to run the standup tranny parts in the box)
#1672
Finally got a chance to run my 4.0's this weekend at round one of Tyler Hook's Southern Winter Payout Series. Was a little nervous since I hadn't had any track time with the cars but they were on point straight from the get go. Track was medium traction until mains and the cars were consistent all the way through. TQ and 1st in 17.5 and qualified 5th in the super stacked mod buggy A main and ended up 6th I think. I ran my super stock (13.5) car in the mod main and actually fast lapped the field in Q1 and Q2 but the car seemed to lose a little steering (initial and mid) once the track gripped up which hurt me in the mains as I traction rolled a couple times in A1 trying to hustle the car through the corner while running 2nd. All in all, really good first outing with the 4.0's!
#1673
Finally got a chance to run my 4.0's this weekend at round one of Tyler Hook's Southern Winter Payout Series. Was a little nervous since I hadn't had any track time with the cars but they were on point straight from the get go. Track was medium traction until mains and the cars were consistent all the way through. TQ and 1st in 17.5 and qualified 5th in the super stacked A main and ended up 6th I think. I ran my super stock (13.5) car in the mod main and actually fast lapped the field in Q1 and Q2 but the car seemed to lose a little steering (initial and mid) once the track gripped up which hurt me in the mains as I traction rolled a couple times in A1 trying to hustle the car through the corner while running 2nd. All in all, really good first outing with the 4.0's!
#1675
TLRacing
#1676
What is the purpose of the new steering rack being tested? Is this just for carpet (to not have to flip cranks)? thx - wondering if I should wait before upgrading
#1678
#1679
Is there a way to achieve a similar setup without flipping the cranks? Does the 2.0 spindle sit lower? Perhaps instead of 4mm on top of existing spindle 3mm top 1mm bottom to take away some turn in? Just a lot of work
#1680
the reason for using the 2.0 spindles is to get a completely different ackerman curve that is not possible with the 4.0 spindles, it just plain works really good on carpet, now you will need to trim away a large chunk of the bottom leg of the spindle, enough to get 5mm of spacers above the hub, this took around 15 minutes.
