Old 01-14-2006, 07:37 PM   #1
Default Okay, now idle adjust
I finally got the Ultra Comp LX to fire off but is seems it wants to rev all the way up. I had to go lean to get it to run but what is the method for adjusting the idle? Remember, I'm new and ignorant, so too technical will lose me. Thanks! by the way, the OFNA manual stinks
jpfishmaster is offline   Reply With Quote
Old 01-14-2006, 07:49 PM   #2
ntro75's Avatar
are you sure the electronics are operating correctly? if they are then turn the idle adj. screw counter clock wise a little at a time..blurp the throttle and tap the brakes to see if it idles down,if it does when breaks applied but the idle rises once you release the breaks then you need to adjust your trim setting(little round know on transmitter that has th trim written above it)
ntro75 is offline   Reply With Quote
DROOP,,,what is it ghow to adjust Gen Nitro Off-Road 6 02-13-2008 12:01 PM
clutch spring adjust nut musti72 Nitro On-Road 5 01-28-2008 07:21 AM
Adjust Car Setup or Driving Style? LJae Electric On-Road 10 01-19-2007 08:04 PM
how to adjust a 2speed trannie for my rs4 teck2000 Nitro On-Road 1 06-28-2005 04:50 PM
Servo saver-how to adjust? vti-chris Electric Off-Road 2 02-18-2005 09:02 PM
SEO by vBSEO 3.5.0
