Old 01-30-2017, 05:57 PM   #1
Default Do ballooning tires really = fast?
It seems to be a common theme on YouTube and some other places that ballooning tires = fast. Is this necessarily true? I feel like it just means air is entering from a bad glue job. Let me know what you guys think
ERevo4738 is offline   Reply With Quote
Old 01-30-2017, 06:12 PM   #2
shannow's Avatar
Tire ballooning is bad for racing and is something to be avoided. Mostly happens when accelerating and the center diff is very light and basically the front diffs out. Pretty much means you won't have much steering when accelerating and the wear on the tire will be awful.
If you're talking about all four wheel ballooning when accelerating it's just the motor which is OP. Way too much power for anything to be controllable. Again tire wear, suspension compromised (foam won't do it's job )etc...
Yokomo YZ-2 , sanwa M12
Tekno EB 48.3 1900kv Hobbywing XR8+
Tekno NB48.4 Ko propo servo's Alpha dragon III
shannow is online now   Reply With Quote
Old 01-30-2017, 06:30 PM   #3
Has nothing to do with how tires are glued. Has to do with the effects of centrifugal force.
Rather Race is offline   Reply With Quote
Old 01-30-2017, 06:42 PM   #4
I installed a 7.5t sonic m3 in my b4. The tires are only ballooning slightly. Is that normal?
Old 01-30-2017, 06:42 PM   #5
Should a 7.5t sonic motor make my b4 tires balloon?
Old 01-30-2017, 06:45 PM   #6
EbbTide's Avatar
Trader Rating: 35 (100%+)
They'll stretch out a bit on the straight away but they shouldn't necessarily balloon like what you see in overpowered setups.
EbbTide is online now   Reply With Quote
Old 01-30-2017, 06:58 PM   #7
Okay cool. I've yet to even try it out on the track. I'm just skeptical about how it all soldered together lol
Old 01-31-2017, 09:35 AM   #8
Ballooning tires are basically a variable speed transmission and they work on rc cars the same as they do on drag cars. You don't want them to balloon to the point the blow apart or instantly at the hit of the throttle but you do want them to balloon some on the straight away to give you that little extra speed.
Badsn95 is offline   Reply With Quote
Old 01-31-2017, 09:54 AM   #9
JRSlash's Avatar
Tires will balloon. Now, If they balloon while you are racing, that's not good. Means lack of traction or car is over powered or over-geared. Wheel spin which created ballooning of the tires just gonna get you nowhere fast while overheating the motor, wearing the tires and draining the battery. In the basher truck I used to put duck tape inside the tires and in my racing cars just poke a hole on either the wheels or the tire so that the tire comes back to normal shape if it happens to balloon.
SOAR Seiki 998 TD1 Nitro
SOAR Seiki 998 TD1 E-buggy
Tekno EB410
Yokomo YZ-2
Dialed-RC Hobbies (www.dialedhobbies.com), SOAR Seiki USA
JRSlash is offline   Reply With Quote
Old 01-31-2017, 09:57 AM   #10
It also depends on the tires being used. Big, wide, soft MT tires will balloon much more than most other tires. Just because of size and softness.
Zinergy is offline   Reply With Quote
Old 01-31-2017, 10:00 AM   #11
EbbTide's Avatar
It is strangely satisfying to see a tire balloon to the point it separates from the wheel and continues rolling for ages lol.
Old 01-31-2017, 10:03 AM   #12
I'm surprised my Ten-MT tires are still glued to the rim with factory glue. Those tires on 3s balloon so large you can't make turns on the throttle. The tires rub against the body bad when you turn. The grow like 2-3 times in diameter at full throttle.
