Old 01-29-2017, 03:11 PM   #1
Default Drill Bits for Chassis Holes
So I'm coming down the home stretch with an RC10GT conversion from nitro to electric. Just need something to hold the battery...
The RC10GT uses 4-40 hardware.
What drill bit is used for making holes in a chassis similar to the ones already there? If I were going to tap that hole, I'd use a #43 bit... so I assume it should be a bit larger than that.
What bit is used to make the 82 degree countersink? I see all sorts of diameters for those bits...
Thanks!
PerryCodes is offline   Reply With Quote
Old 01-29-2017, 03:36 PM   #2
An 82 degree countersink is what the tool is caused. Diameter for the counter sink doesn't matter as long as it is larger than the diameter head of the screw you are countersinking.
If you're looking for a hole that is slightly larger than the screw to pass through without threading it a 1/8" drill bit would work or 9/64 if you want a little more wiggle room.
Associated B4 FT +8mm
Associated SC10 4x4
Associated B64D
Losi XXX-SCT
jimmer411 is offline   Reply With Quote
Old 01-29-2017, 03:41 PM   #3
Just found a chart online.
I think those numbers agree with what jimmer411 said above (thanks!).
Serpent S411 academygaz Electric On-Road 6982 Today 10:12 AM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 10:03 AM
stampede chassis extention sstumpf Electric Off-Road 14 07-04-2011 08:26 PM
making lower chassis davioh Electric On-Road 55 07-17-2003 03:37 PM
