TLR 22T 3.0 Stadium Truck Race Kit Thread!
#167
Hey Guys!
I currently have a 22T 2.0, 22 3.0 and a 22-4 2.0. Each one of these builds I have purchased ALL of the Alumnimun upgrades from TLR. I only drive these cars at OCRC (Modified Motor).
I am going to pick up the 22T 3.0 and I wanted to get your guys opinion (setting the price of aluminum aside) on what aluminum parts are really necessary versus just for the bling.
These are the parts that I was going to get for this kit:
- Aluminum servo horn
- Aluminum servo mounts
- Aluminum bellcranks & Drag link
- Aluminum front camber block
What do you guys think? Other than the servo horn and servo mounts, do you think that the steering and camber block are necessary?
Thanks for the info!!
#168
Hey Guys!
#169
Thanks Frank. I appreciate it!
#170
One more question for you guys -
On my 22T 2.0 I did the brass hinge pin weight (35G) and it really helped. Would you recommend the 30g Hinge pin brace for the 22T 3.0 or any other added weight? The truck is driven at OCRC.
Thanks!
Thanks!
#171
I'm not running it for 13.5t. Maybe for mod? Traction is definitely improved from the 2.0. I say try it without it, and if you're not happy then buy it.
#172
Good idea. Thanks!
#173
Regarding the aluminum steering set, I would skip it. While the aluminum is obviously stronger, it has more slop than its plastic counterpart. Most of this comes from the bearing fitment where the bell cranks meet the rack. For what it's worth, I've never damaged or broken a plastic steering rack on any of my 22 vehicles.
#174
I agree with this. In my experience, the plastic camber block is pretty stout but if you hit hard enough in the right spot it will give out. I now run aluminum blocks on my vehicles. In other words, when mine broke I was happy it was the only thing that broke given the severity of the wreck.
#175
Front Ball Cup Temporary Fit
Been popping off front ball cups. Racing last nite and pop two different front ball cups again. Since I have never pop a ball cup on my Hot Bodies D413 and I noticed the cruved front ball cups were similar to the 22T.
I'm sure TLR will have a fix soon, but you might want to give this a try for the short term. You we see from the pics they fit just fine without any interference with the wheel on the turning radius. I only had to cut off a little on the one connected to the steering. I used the Lunsford straight ball cup that connects to the camber block. You still have a little adjustmenet if needed on both.
#176
Did a few changes to the front end to get this thing to rotate better. Went with a spring one step softer than the blue and added the aluminum camber block (cause I have bad luck breaking the plastic ones in the past). I know the camber block had little to no effect on the rotation but dang does this thing respond really nice to little changes. I also changed my camber up a little all the way around with a good response as well. The only issues that I seem to be having is the same as everyone else with the ball cups but I know those will come in due time. Also I just wanted to know if anyone is having a problem with the ball stud ripping out, the ball stud that is on the front spindle (controls turning.) If not could some one give me a tip on what I might be doing wrong to rip that out of the threads.
#177
#178
Thanks I will check it out and see if I could do that with enough clearance. I ended up doing something similar to what you are saying when I ripped the screws out of the body mount on my SCT3.0. I am guessing that the next size up in ball stud should do the trick. Not going to do it today but next time I break I will try it out.
#179
I had the same ballstud rip out on my SR using the new spindles and I noticed that the top 2 or so mm of thread was stripped and there weren't any clean threads until a bit lower in the hole. When I built my 22T I was careful to make sure it threaded well and have had no issues.
#180
