Old 01-26-2017, 05:28 AM   #1
Default Alot of play in front tires
Hello, So now im seeing a lot of play in the front tires. Whobble on the Ruster.. Based on what i read the answer seems to be to add "5x8x1mm plastic washers where the carrier meets the caster. Top and Bottom. Would anyone be able to provide a picture of what this would look like. Has anyoe else experienced this issue as well as other ways to resolve the whobble? Thanks in advance, Chris
rustlervxl is offline   Reply With Quote
Old 01-26-2017, 07:27 AM   #2
That could actually be anything, you might just have to investigate and see what's worn out / missing and what the cause of the wobble is. That's a pretty big plastic spacer for a caster shim. And rustlers are notorious for being a little sloppy. could be a worn out axel, worn out bearings, gaps or slop in the caster blocks, spindles, camber links, loose screws. Usually when I shim up a caster block or spindle the spacer is quite a bit smaller like 5x3x1 5mm outside diameter, 3mm inside diameter (same size as the hinge pin) and 1mm thick)
greener74 is offline   Reply With Quote
Old 01-26-2017, 07:32 AM   #3
these would probably work. Just remove the pin and place these in between the arm and the carrier. they are 1/2mm so it may take one or 2 to remove the slop. make sure you don't add too many and make it bind up.
https://www.amainhobbies.com/losi-3....256007/p453142
Old 01-26-2017, 09:54 AM   #4
Thank you for getting back to me. This is where i will show my ignorance. Is there a before and after pic of what this would look like. "Just remove the pin and place these in between the arm and the carrier". Ill check out your other suggestions this weekend.
Old 01-26-2017, 01:47 PM   #5
Old 01-26-2017, 03:51 PM   #6
that's great. Thanks a lot. Much appreciated.
Old 01-26-2017, 06:47 PM   #7
https://www.amainhobbies.com/traxxas...-tra1985/p3272
Here are the traxxas ones too
Cpan80 is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29647 Yesterday 09:32 AM
SC10 4x4 Thread CraigV Electric Off-Road 36436 09-06-2017 02:54 PM
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread SaladFork Electric Off-Road 46468 03-20-2017 08:56 PM
RC news in SABAH! jfc_tech Malaysian R/C Racers 5426 01-27-2017 10:21 PM
Droop Front to Rear Settings Victory Electric Off-Road 8 11-15-2013 01:46 PM
