Like Tree25Likes
Old 01-14-2017, 12:35 PM   #31
kiwiazbro's Avatar
Looks great. Have always loved Schumacher but just shelved my KR to move to a mid motor car (B6D) since I wasn't a fan of the KF given our surface is dirt. Now the KD is here I'll be looking at this. 👍
kiwiazbro is offline   Reply With Quote
Old 01-14-2017, 02:21 PM   #32
motorcitymatt's Avatar
Another nice feature of this car that will be quite useful is the adjustable wheelbase. Very large adjustments will be possible. The new front arms are designed to be "flippable" and they also accommodate what looks to be a 1.5mm spacer between the arm and the caster block.
The rear arms are also "flippable". The KD is actually using them in what would be a reverse position for the KF2. So you'll be able to flip them back and/or move the rear hub carrier a total 4.8mm using the two spacers.
That is a lot of movement and should help tune for different grip levels by manipulating the weight bias / transfer.
Schumacher Cougar KC, KF2 SE
RC Clubhouse in Warren, MI
DiscountRCStore.com (The best online hobby shop)
motorcitymatt is offline   Reply With Quote
Old 01-14-2017, 02:36 PM   #33
Trader Rating: 30 (100%+)
This new KD looks really cool!
Norse is offline   Reply With Quote
Old 01-14-2017, 02:47 PM   #34
Tony Newland's Avatar
Trader Rating: 50 (100%+)
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 01-14-2017, 03:01 PM   #35
Somebody a few posts back mentioned they maybe didn't like the new shock caps.
I think they are really nice if for only one reason. You will be able to change shock positions on the tower much faster. Before you had to pull the retaining nut, remove the plastic spacer washer and mount, then you had to remove the post. Now you just move the ball stud. Easy.
I am assuming the caps are molded so if things get loose after awhile just replace them as a consumable. Before you could only get the plastic mount pieces in U3937, which had things you didn't even need (spring retainers) so the price should be roughly equivalent.
Old 01-14-2017, 03:28 PM   #36
Originally Posted by Tony Newland View Post
I just may have to get on of these
Old 01-14-2017, 03:51 PM   #37
PsycoB4's Avatar
Trader Rating: 41 (96%+)
Originally Posted by Davidka View Post
After reading Schumacher's launch materials it's interesting to see that this is aimed at "low-traction" and "loose dirt".
Remember when we debated if a mid motor 2wd would ever be good enough to really be competitive on anything but carpet? It was like, 3-1/2 years ago. How things change...
Everybody laughed at me at my local track when I ran for schuey years ago, and came running the cougar MM And they were like hahah that wont work. Now Look when I come back, Every buggy and truggy is MM even SCT are MM. its funny
PsyCo_Chris
WWW.FinalTechniqueCustoModz.Com
Custom Metal Fabrications // LED Lighting // Jeep Specialist
PsycoB4 is offline   Reply With Quote
Old 01-14-2017, 04:11 PM   #38
Ha, I did the same half way through last year, but to a 22 3.0. Took hundreds of dollars in hop ups to go as fast as a box stock KR. Before I bought the TLR, I got a KF but it was just so bad on loose surfaces. The KD is an important car for the brand.
cjmurph is offline   Reply With Quote
Old 01-14-2017, 04:19 PM   #39
I have been running my SC6 in MIdmotor on low bite outdoor tracks for years as well. actually felt like I was cheating as the truck is so much faster than the RM SCT's thus again on low bite dirt.
Old 01-14-2017, 06:18 PM   #40
This car is bad ass! when will discount have it in stock?
AJrollin is offline   Reply With Quote
Old 01-14-2017, 06:45 PM   #41
Schumacher website says "February". Not sure if that means Feb 1 or Feb 28 or somewhere in between.
Old 01-15-2017, 05:44 AM   #42
Trader Rating: 9 (91%+)
I feel this car will work very well not just on dirt, but also on astro.
This is an important that they have finally filled. The KF will be for the carpets.
leongkc is offline   Reply With Quote
Old 01-15-2017, 09:04 AM   #43
anthonyjesmond's Avatar
Trader Rating: 84 (100%+)
KF on carpet still has a lot of drag for 17.5. It's a beast in mod but in 17.5 the B6, YZ2, and XB2 are dominating. It would be nice to see a lay down conversion for this car.
Anthony Jesmond
CT
Schumacher KF, KR, Mi5 Evo
Kyosho ZX6, Xray XB4 SCTE Ten 2.0,
Kyosho Scorpion, Monster Beetle
anthonyjesmond is offline   Reply With Quote
Old 01-15-2017, 09:18 AM   #44
Trader Rating: 42 (98%+)
Send a message via AIM to RockStar_199 Send a message via MSN to RockStar_199 Send a message via Yahoo to RockStar_199
very interested in this...............to much drag for 17.5???? please explain
Mark C. Math
Kyosho TKI4
Triton Engines: L4 2108
J&T Bearing Co.
RC Pro TX10280
RockStar_199 is offline   Reply With Quote
Old 01-15-2017, 02:22 PM   #45
Kf2 setup correctly should be less drag than anything else. Maybe you meant too heavy?
psycho02 is offline   Reply With Quote
Schumacher KR 2wd buggy Wavewrecker R/C Items: For Sale/Trade 10 04-19-2017 08:26 AM
Schumacher KF2 2WD Buggy OriginalDonk R/C Items: For Sale/Trade 15 08-24-2015 09:47 AM
