Building a Dead Shock.
#16
That design is sometimes employed in full scale racing (I had a pull/through shock on a full suspension mountain bike about 15 years ago). I can't find any evidence of an off road shock design from AME.
#17
Re shocks
[QUOTE=wittyname;14783642]RC is funny ....
Grown man with job spends hours building and rebuilding his shocks to attain perfection , sets down car , hits wall 23 times ...
Kid picks his nose , drops down his b4 , and laps the field .... shocks don't even have oil in them ...
^+100
Back to subject, having hydrolocked a losi mini t plastic shock and splitting in two when I compressed it, I do understand some of the discussion, that being said, why are there so many options for shock pistons (hole dia., # of holes, taper, etc) if they all just act like a hydraulic cylinder piston? Would bigger piston holes and an air tight shock act like a full scale shock? And/or thinner shock oil that actually passes through said holes in a manner fast enough to keep up with compression and rebound? That seems it'd be most consistant. I've been putting a lot (some would say too much) of thought into this subject lately, and just like the above quote it will NEVER actually keep me off the walls a 17 times per lap but I'm one of those special masochistic kinda nerds. Any thoughts on how to make our shocks actual oil shocks instead of air bag suspension?
^+100
#18
The reason for different size holes and oil weights is that different combinations create different turbulence & flow resistance at different piston speeds.
There are a few companies making directional flow pistons but none are as sophisticated as a full scale shock's directional vslving, wave washer stacks, and in the case of race level stuff, mukti circuit systems (damping control of volume overflow). Due to their tiny size, our stuff is pretty basic.
#19
#20
All of those things are available. Fioroni used to make alloy pistons with an o-ring and VRP, MIP make pistons with effective one-way valves (MIP's are even adjustable).
As for the thin viscosity/fine valving? I'm not sure why it doesn't work, or why "big-bore" is effective as that isn't done on full scale suspension either.
I've thojght a 2-stage compression damping could be useful but I can't figure out how we'd achieve both small bump compliance (high-speed damping) and chassis weight transfer (low-speed damping) while retaining bottoming resistance, which is where our little cars differ from full scale so much.
#21
shock pistons
asked this question on rc8b3e thread got no response. has any one tried fioroni t.a.p. 8x1.2mm 2ball/8x1.3mm 4ball pistons. or vrp x2/ vrp game changers. on rc8b3e. if so witch ones.trying to stop chassis slap. or should i try emulsion first before spending big money on any of these.
#22
#23
