    Hide Wikipost
Old 08-10-2017, 12:48 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.4 Thread
Last edit by: Bob Barry
Welcome to the EB4.4 Wiki page.
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top.
Bob B 8/10/17 - Should I start with the kit setup?
The kit setup is a great place to start. One other option that many of us start with is Joe's rough track setup. You can find that setup here
In order to run it you need 3x2.1 pistons and 3x2.0 pistons. (They are marked on the sheet as 3.1 and 3.0).
Matt W 7/7/17 - What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree232Likes
Old 12-27-2016, 08:44 PM   #76
Suspended
Originally Posted by Cain View Post
Hot Bodies 4S battery system looks interesting from that perspective on how you can orient the battery position.
Exact same layout as a tekno. Only difference is how the battery is secured. Difference is tekno has greater steering able to corner tighter, yet doesn't have bad overseer like a hb. Plus we all know the history of how long it takes to get hb parts. I give credit to those that design their own cars differently, not the weaselly that can only copy top brands, hire world class drivers and then boom, on the map.
I intentionally took the bait.
latentspeed is offline   Reply With Quote
Old 12-28-2016, 03:42 AM   #77
There's still options. You could basically have the design you're looking for if you used two sets of 1/10 saddle packs.
SpongeX is offline   Reply With Quote
Old 12-28-2016, 06:14 AM   #78
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
not following on the bait thing but yeah the design of the HB car looks like the V4 conversions with there own twist on some things like the battery tray. If its a very good copy of the V4 layout then it should perform well as it has a good base to go off of.
Still seeing these as late dec for a variety of places. Any more news on that like packages shipped out to places like tower, etc?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 12-28-2016, 06:54 AM   #79
I just noticed this change on the Tekno web site EB48.4 page
In stock and ready to ship!
jjl1 is offline   Reply With Quote
Old 12-28-2016, 08:22 AM   #80
Tech Legend
Cain's Avatar
Good stuff.
Is there any pics of the full chassis? This TKR8006
Trying to see what exactly is different. I am thinking the droop screw points based on the wider pivots so curious what else.
Old 12-28-2016, 02:28 PM   #81
Good stuff.
The 1st page of this forum lists the changes. Looks like quite a few differences.
qstorm777 is offline   Reply With Quote
Old 12-28-2016, 05:12 PM   #82
Tech Legend
Cain's Avatar
yeah I am looking to see like a full pic of the just the chassis plate.
Old 12-29-2016, 06:56 AM   #83
Maxxingout's Avatar
Trader Rating: 14 (100%+)
Money went through on my order for the .4 from Towers, now to order the truggy
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 12-29-2016, 11:12 AM   #84
Tech Legend
Cain's Avatar
showing as in stock limited quantities.
Old 12-29-2016, 03:07 PM   #85
Hello Everyone, we posted a new recommended indoor setup for the EB48.4. It's a little more neutral and easier to drive than Ryan or Joe's. Check it out, it's pretty good!
P.S. We will be constantly updating our recommended setups on our site. Check often for the latest setup, they will be updated when we find something good!
http://www.teknorc.com/setup-sheets/
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 12-29-2016, 07:56 PM   #86
lala4fire's Avatar
If you go to the Tekno web sight and put your arrow over the pic with the chassis/dblock, it gives an animated pic of the changes.
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
HB D413/tekin rsx/gen3 6.5
lala4fire is offline   Reply With Quote
Old 12-29-2016, 09:17 PM   #87
Default Pistons?
Looking at the two Bornhorst setups for the 48.4 can somebody tell me what the shock pistons are? 2x3.0?
crash n go is offline   Reply With Quote
Old 12-29-2016, 09:21 PM   #88
Trader Rating: 16 (100%+)
4X1.9
MX304 is offline   Reply With Quote
Old 12-29-2016, 11:36 PM   #89
has anyone built their kit yet? does it include an aluminum servo horn in this one or do i need to order one seperately? thanks all
caffeine357 is offline   Reply With Quote
Old 12-29-2016, 11:41 PM   #90
EbbTide's Avatar
Trader Rating: 35 (100%+)
Check the manual online. You can see if there are any bits you want to replace with aluminum options.
EbbTide is online now   Reply With Quote
Tekno RC SCT410.3 Thread Matthew_Armeni Electric Off-Road 5306 10-13-2017 04:44 PM
Official Tekno RC EB48.3 Thread Matthew_Armeni Electric Off-Road 2945 07-23-2017 08:52 AM
