    Hide Wikipost
Old 08-10-2017, 12:48 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.4 Thread
Last edit by: Bob Barry
Welcome to the EB4.4 Wiki page.
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top.
Bob B 8/10/17 - Should I start with the kit setup?
The kit setup is a great place to start. One other option that many of us start with is Joe's rough track setup. You can find that setup here
In order to run it you need 3x2.1 pistons and 3x2.0 pistons. (They are marked on the sheet as 3.1 and 3.0).
Matt W 7/7/17 - What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree227Likes
Old 02-02-2017, 08:08 PM   #331
suzukipro's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Derrick87 View Post
What is the benefit of running it at 7.4v?
More torque and faster movement
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is online now   Reply With Quote
Old 02-03-2017, 04:22 AM   #332
I bought an MKS X6 HBL599 for my .4 and so far I am pleased with it. Has all the power in the world and it's quick and smooth.
Flippin 416 is offline   Reply With Quote
Old 02-03-2017, 04:46 AM   #333
Mikeand22's Avatar
Trader Rating: 24 (100%+)
I'm in the market for some servos and looked at the MKS HBL599 and I just can't get over the cost of them. It seems like $189.99 for a servo is crazy expensive.
Mikeand22 is offline   Reply With Quote
Old 02-03-2017, 04:52 AM   #334
jmcelroy42's Avatar
Really love my ProTek 170s!!
I would look into ProTek or Highest (the company that makes the ProTek) I've been Running them for years and they work great and haven't had any issues.
EB48.4 - TEKIN RX8 & SMC 2100
XB4 '16 - TEKIN RSX & ORCA 5.5
RC10B6 - HW Justock & 24K 17.5
jmcelroy42 is online now   Reply With Quote
Old 02-03-2017, 05:26 AM   #335
I have no experience with hobbywing, I have only ran the Tekin RX8, and teh SMC ESC. For cost effectiveness, I would without a doubt grab the SMC.
http://www.smc-racing.net/index.php?...y&path=123_155
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 02-03-2017, 05:29 AM   #336
I have the Protek 170s, and the highest dt2100 in a couple vehicls. My next servo purchase will be a proamps, Decently priced, and a 2 year warranty. They are new to the USA, but are very well respected overseas, and in in austrailia.
http://fiercercsolutions.com/Pro-Amps-Servos_c195.htm
Old 02-03-2017, 06:55 AM   #337
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
I use the Futaba S9372SV
http://www3.towerhobbies.com/cgi-bin...?&I=LXFSGA&P=M
Awesome specs at both 6V and 7.4V
please note however, its a fat servo, so it was a bit of a chore to squeeze it into the mount location.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 02-03-2017, 07:09 AM   #338
Only shows specs and rated for 6v, not 7.4. For $150, I would expect the specs and design to be a bit better. And 1 year limited warranty.
Ah, I found it on futaba's site. 342 oz and .06 speed at 7.4v....Curious why Tower doesn't show the 7.4v specs....7.4v specs look better for buggy.
Old 02-03-2017, 07:15 AM   #339
Maxxingout's Avatar
Trader Rating: 14 (100%+)
I'm using the Protek 150T. 1st time I fired it up it was so smooth and quiet compared to what I'm used to, Savox. Specs are very nice in either 6v or 7.4.
https://www.amainhobbies.com/protek-...k-150t/p228474
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 02-03-2017, 07:21 AM   #340
bigboyz12000's Avatar
Nice! I still have my S6280 in my .3 Buggy so i can test some changes i have made to it. I am testing the same 150T in my .4 buggy. Its fast and smooth when testing on my living room carpet. I have not yet tested it outdoors or on the track.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 02-03-2017, 07:55 AM   #341
[/IMG][/URL]
Have you had any issues with how close the xr8 is mounted next to motor? Seems like a tight fit.
Arbane408 is offline   Reply With Quote
Old 02-03-2017, 08:36 AM   #342
Trader Rating: 65 (100%+)
Lot of servo options these days. I'm still a big fan of Hitec because of the service experience. Outstanding performance and proven. I have 7950s in service nearly 4 years with only fresh grease on gears once a year. I'm a clean driver and do lots of preventative maintenance which helps.
Thunder Trail is offline   Reply With Quote
Old 02-03-2017, 08:41 AM   #343
Maxxingout's Avatar
I'll find out next sat how the servo does but I can't imagine not being satisfied.
Yes it is a bit close and I'll keep an eye on if I see rubbing. If I do I'll turn it with the caps facing out.
Old 02-03-2017, 08:54 AM   #344
Derrick87's Avatar
I thought it was a little slow compared to the Savox using the 89$ hobby wing esc. I guess my prob was it wasint getting enough voltage for the Spektrum.
"nvm i just looked at the spec's and it seems the Savox has better speed but no where near the torque the Spektrum has even at 6v"
Tekno EB48.4/Tekin Rx8 Gen2 1900kv/Spektrum/Futaba.
Derrick87 is offline   Reply With Quote
Old 02-03-2017, 10:24 AM   #345
Jmuck69's Avatar
Highest also makes the Reedy servos.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Official Tekno RC SCT410.3 Thread Matthew_Armeni Electric Off-Road 5287 Today 06:34 AM
Official Tekno RC EB48.3 Thread Matthew_Armeni Electric Off-Road 2945 07-23-2017 08:52 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
