    Hide Wikipost
Old 08-10-2017, 12:48 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.4 Thread
Last edit by: Bob Barry
Welcome to the EB4.4 Wiki page.
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top.
Bob B 8/10/17 - Should I start with the kit setup?
The kit setup is a great place to start. One other option that many of us start with is Joe's rough track setup. You can find that setup here
In order to run it you need 3x2.1 pistons and 3x2.0 pistons. (They are marked on the sheet as 3.1 and 3.0).
Matt W 7/7/17 - What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree209Likes
Old 02-02-2017, 06:23 AM   #316
Maxxingout's Avatar
Trader Rating: 14 (100%+)
I was able to run my .4 for the second time last night at an indoor medium sized track. My first outing was just trying to adjust to the car (coming from a Losi 3.0). I was working on dialing in the car a bit more last night and spent some time ahead of getting on the track setting camber, ride height, etc. I was still struggling to find off power steering (diff fluid is 775). I changed my ride height to 22/28 (was at 26/29) and that alone brought a whole lot more off power steering. After that change I felt allot more comfortable running the car into the corners deeper and faster...last night was the best I have felt with any Escale buggy yet. I am no pro by any means and just enjoy hanging out with some good friends and have fun doing this. Can't wait til next time!!!
Seeings as you're from Dover, I'm guessing the track you're talking about is NEO in Hartville? Hopefully I'll get a chance to try out my new .4 next sat for the 1st time. Interested to see how it feels to drive a diff brand after all these yrs.
Tekno EB48.4, Hobbywing XR8Plus-1900kv
Tekno ET48.3, Tekin Gen2-T8-1900kv
Maxxingout is offline   Reply With Quote
Old 02-02-2017, 07:24 AM   #317
That would be the one. We just started going there this year...I bought my Losi 3.0 late summer so I am still pretty green about most of this stuff. The new layout is the best of the 3 I have driven on IMO. They do a great job up there!
Flippin 416 is offline   Reply With Quote
Old 02-02-2017, 01:18 PM   #318
Derrick87's Avatar
Guys what servo would i benefit more running in this buggy the Savox sc-1258 or the Spektrum s6280?
Tekno EB48.4/Tekin Rx8 Gen2 1900kv/Spektrum/Futaba.
Derrick87 is offline   Reply With Quote
Old 02-02-2017, 01:40 PM   #319
Without a doubt not the 1258tg.
The stats on the s6280 look decent at 7.4v. I have no direct experience with that servo though.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 02-02-2017, 02:00 PM   #320
Trader Rating: 16 (100%+)
SC-1258 does not have anywhere near enough torque for 1/8 scale.
MX304 is offline   Reply With Quote
Old 02-02-2017, 02:14 PM   #321
Trader Rating: 23 (100%+)
I use the Savox SB-2274SG in my .4
Great servo.
hawks is offline   Reply With Quote
Old 02-02-2017, 02:23 PM   #322
I think I have a 1258 in mine, been there for 2 years. Never had any problem needing more torque. Not saying I would recommend it, but it has worked well for me.
greener74 is offline   Reply With Quote
Old 02-02-2017, 04:35 PM   #323
bigboyz12000's Avatar
I have been running the S6280 in my .3 and i love it. I run mine on 7.4 and it has plenty of power and it is smooth when cornering.
-Tekno EB48.4 Tekin RX8.2 1900 S6280
-Tekno NB48.3 Mito4 .21 S6280's
bigboyz12000 is offline   Reply With Quote
Old 02-02-2017, 05:42 PM   #324
Derrick87's Avatar
With the Spektrum s6280 do i need to add an extra battery? Not really sure what you mean be 7.4.
Old 02-02-2017, 05:50 PM   #325
EbbTide's Avatar
Trader Rating: 32 (100%+)
That would be 7.4 volts. You'd either need an esc capable of 7 4v on the BEC or have an external rx lipo battery
EbbTide is online now   Reply With Quote
Old 02-02-2017, 05:55 PM   #326
Derrick87's Avatar
would this esc be ok to run that servo?
https://www.amainhobbies.com/hobbywi...020262/p279090
Old 02-02-2017, 06:05 PM   #327
rcgod's Avatar
Trader Rating: 27 (100%+)
I recommend this one for a little more. It has an adjustable bec so you can run 7.4v to the servo.
https://www.amainhobbies.com/hobbywing-xerun-xr8-sct-1-8-sensored-brushless-esc-hwa30113301/p540793
rcgod is offline   Reply With Quote
Old 02-02-2017, 06:06 PM   #328
EbbTide's Avatar
Yeah although you would be limited to 6v which the servo is capable of. But it would benefit from a higher voltage in the future.
Old 02-02-2017, 06:31 PM   #329
Derrick87's Avatar
https://www.amainhobbies.com/hobbywi...113301/p540793
What is the benefit of running it at 7.4v?
Old 02-02-2017, 06:32 PM   #330
Derrick87's Avatar
Thanks for your reply
Official Tekno RC SCT410.3 Thread Matthew_Armeni Electric Off-Road 5228 Today 12:08 PM
Official Tekno RC EB48.3 Thread Matthew_Armeni Electric Off-Road 2945 07-23-2017 08:52 AM
