    Hide Wikipost
Old 08-10-2017, 12:48 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB48.4 Thread
Last edit by: Bob Barry
Welcome to the EB4.4 Wiki page.
If you edit the page, please add your name and date prior to your addition. While an admin can view the history, this makes it easier for everyone to just check updates. We'll put the newest additions at the top.
Bob B 8/10/17 - Should I start with the kit setup?
The kit setup is a great place to start. One other option that many of us start with is Joe's rough track setup. You can find that setup here
In order to run it you need 3x2.1 pistons and 3x2.0 pistons. (They are marked on the sheet as 3.1 and 3.0).
Matt W 7/7/17 - What is overdrive and when should I use it?
The NB48.4 comes stock with a 12t pinion (TKR8152) and the 39t ring (TKR8151) in both the front and rear and the EB48.4 has a 12t pinion (TKR8152B) and the 40t ring (TKR8151B) in both the front and rear.
The two sets of gears are used to overdrive the front of the EBs or underdrive the rear of the NBs. If you have both vehicles and want to try underdrive it's as easy as swapping the front diff and pinion of the EB and the rear diff and pinion of the NB. Underdrive helps on very loose tracks, when you need more on power steering or if the rear of the car feels loose.
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree227Likes
Old 02-01-2017, 10:38 AM   #301
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Afer runninig mugen for years,the only times i stripped the plastic gears is because the motor moved.. but im sure the steel gear brings piece of mind.. not concerned with the noise, i run mostly in doors
hairymuffin is offline   Reply With Quote
Old 02-01-2017, 10:41 AM   #302
Whats the difference in the white and black plastic gear
Old 02-01-2017, 11:07 AM   #303
Mikeand22's Avatar
Trader Rating: 24 (100%+)
I've had the Tekno E-buggies, E-truggies, and the SCT for several years now and have never stripped a spur gear.
Mikeand22 is offline   Reply With Quote
Old 02-01-2017, 11:09 AM   #304
I'd stripped 3....Rocks jam between spur and chassis on all 3.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 02-01-2017, 11:11 AM   #305
Mikeand22's Avatar
Interesting, that's never happened once to me. I only race outdoors too.
Old 02-01-2017, 11:12 AM   #306
I race on an old school loose track. Rooster tails and all. It happens. Although twice on sct, and once on truggy.
Old 02-01-2017, 12:02 PM   #307
I order the white ones because they look cool. White ones are probably Delrin and the black ones are probably composite. But I don't know, and I haven't been able to find the answer either. I don't know if there is a sound difference or different wear characteristics.
greener74 is offline   Reply With Quote
Old 02-01-2017, 12:32 PM   #308
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
last time I checked on this i heard the only diff was the color.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 02-01-2017, 01:08 PM   #309
Trader Rating: 23 (100%+)
They are exactly the material just one is black and the other is white.
hawks is offline   Reply With Quote
Old 02-01-2017, 04:29 PM   #310
justpoet's Avatar
Trader Rating: 16 (100%+)
Spurs:
Metal is a good upgrade if you're often on a track with loose pebbles and you have a fairly open body, so they can get in if you're flipping a lot, or sitting behind others roosting.
That being said, I've never stripped a spur except when I blew a motor bearing, and I run on those kinds of tracks all the time. The SC is the only one open enough that I worry about that on occasion. But, if you find peace of mind from it, do it.
As for the black and natural colored spur gears, the black one is the same, but with black dye in it. No difference otherwise, same material. It was released because a bunch of folks really wanted to black out the inside of the vehicles.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 02-01-2017, 04:42 PM   #311
Tech Legend
Cain's Avatar
Looks like they corrected the price on tower. $549.99 again.
Old 02-01-2017, 05:04 PM   #312
i wonder why they had them for $569 in the first place
coombes is offline   Reply With Quote
Old 02-01-2017, 07:07 PM   #313
Default 48.4 or SL for indoor
At this time would the 48.4 be a decent choice primarily running on a small to medium indoor track or is SL version still going to be better choice? Probably do larger outdoor track a quarter of the time.
Arbane408 is offline   Reply With Quote
Old 02-01-2017, 07:25 PM   #314
EbbTide's Avatar
Trader Rating: 34 (100%+)
I'd probably only go for the SL if the indoor track requires e-buggies to run on 1/10 electronics like mine does. But if they allow 1/8 electrics I'd go for the 48.4 all day.
EbbTide is offline   Reply With Quote
Old 02-02-2017, 05:24 AM   #315
I was able to run my .4 for the second time last night at an indoor medium sized track. My first outing was just trying to adjust to the car (coming from a Losi 3.0). I was working on dialing in the car a bit more last night and spent some time ahead of getting on the track setting camber, ride height, etc. I was still struggling to find off power steering (diff fluid is 775). I changed my ride height to 22/28 (was at 26/29) and that alone brought a whole lot more off power steering. After that change I felt allot more comfortable running the car into the corners deeper and faster...last night was the best I have felt with any Escale buggy yet. I am no pro by any means and just enjoy hanging out with some good friends and have fun doing this. Can't wait til next time!!!
Flippin 416 is offline   Reply With Quote
Official Tekno RC SCT410.3 Thread Matthew_Armeni Electric Off-Road 5281 Yesterday 06:33 PM
Official Tekno RC EB48.3 Thread Matthew_Armeni Electric Off-Road 2945 07-23-2017 08:52 AM
