    Hide Wikipost
Old 11-15-2017, 05:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB410 Thread
Last edit by: billdelong
Welcome to the EB410 Wiki page.
Basic Stats/Features:
  • Shaft drive (tapered AL for light weight and straightness)
  • Gear differentials (all 3)
  • Low Angle CVAs (with captured pins so no ejecting them!)
  • Durable stub axles with 12mm hexes and optional offset adjustments
  • Reverse bellcrank steering system
  • Quick access bulkheads (for easy diff maintenance and tuning)
  • Spllt center diff holder (for easy diff maintenance and tuning)
  • 8th scale style motor mount (for easy mesh adjustment)
  • 13mm big bore shocks
  • 3.5mm shock shafts
  • Droop screws
Videos
Servo Horns
Tekno included a plastic servo horn but also offers an aluminum one. This is highly recommended. Here's a list of servo horns that have been found to work:
Gearing:
Works out of the box for mod or 13.5.
  • Start mod gearing around 21t pinion
  • Start 13.5 gearing around 29t pinion with the stock spur (81tooth). If using a Tekin Spec R 13.5, start with a 24t pinion for medium sized indoor tracks.
  • Internal Gear Ratio: 2.5:1
  • For comparison:
  • B64 is 2.47:1
  • 22-4 is 2.4:1
  • YZ4 is 2.6:1
Wheels
  • B6/22/rb6 wheels direct fit
  • 22-4 front wheels direct fit
  • B64 front wheels will fit, but you need the +1 hexes (can use #TKR1654X, which is a +1mm hex)
  • 22 2wd front wheels will also fit, possibly a good option for carpet.
Setup Sheets and other documentation
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
Aftermarket Upgrades:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Build Tips:
  • When fastening the steering posts with a 5.5mm socket wrench, you can back space the socket with some nuts to help drive the post into the bulk head
  • Place an alcohol swab over metal threads and drive screws through the swab to clean both sides of threads before applying thread lock
  • Use a metallic marker to indicate what fluids you have filled in your diffs for easy identification
  • Apply thin layer of grease on crown gears to help hold gaskets in place for easy hole alignment
  • Bags F and H have 2 different size set screws, be sure to use the smaller 3x3mm screws for the hexes or you may run into problems installing wheels over the hex if you use the longer 3x4mm screws
  • To make is easier to slip the o-rings on the shock cap bleeder screws, apply a drop of shock oil and slip them over a 1.5mm hex bit, then line up the bit with the screw and transfer the o-ring over using fingernails or needle nose pliers
  • Use HoBao Hyper10 3x35mm hinge pins for the rear arms
  • pinch+rotate shock caps in 17mm hex wrench to improve roundness
    More shock build tips here
Print Wikipost
Like Tree1245Likes
Old 08-16-2017, 10:13 AM   #526
mrniss99's Avatar
Trader Rating: 42 (100%+)
Originally Posted by offroad dude View Post
Where can I buy that wiring wrap????
I have always gone through these guys.
https://www.wirecare.com/category/braided-sleeving
offroad dude likes this.
TQHobby.com
Tekno EB410 - Tekin RS Pro BE/ Tekin SPEC-R 13.5 / Xpert PI-3402
Tekno SCT410.3 - Tekin RX8G2 / Tekin Pro4HD 4300 / Xpert SI-4431
Tekno EB48.3 - Tekin RX8G3 / Tekin T8 Gen2 1900 / Xpert SI-4531
Associated B6 - Tekin RSG2 / Tekin G3 13.5 / Xpert PI-3402
mrniss99 is offline   Reply With Quote
Old 08-17-2017, 05:36 PM   #527
justpoet's Avatar
Trader Rating: 16 (100%+)
Soon™, very soon!
"End of summer is coming, end of summer is coming!"
…and a reminder of what that means.
https://www.facebook.com/teknorc/vid...4228003119649/
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 08-17-2017, 06:43 PM   #528
fast-ho-cars's Avatar
was this car ran at recent ROAR Nats?
fast-ho-cars is online now   Reply With Quote
Old 08-17-2017, 07:18 PM   #529
justpoet's Avatar
Nope, though it did beat up on some top guys that went to practice at OCRC prior.
EbbTide likes this.
Old 08-18-2017, 07:00 AM   #530
boudin4evr's Avatar
Trader Rating: 18 (100%+)
https://gallery.mailchimp.com/952373...88197113e4.jpg
Marc Richard
If it smells burnt up.. it's more than likely hot.. you don't have to touch it!
Tekin, JConcepts, TEKNO RC, AVID Bearings, Schelle Racing Products, DialedRC Hobbies formerly (VP Pro USA), MAXAMPS, Kal Gard Lubricants, Tresrey USA, Panther RC, Sweep Racing USA, Team INTEGY, Hy-Traction Juice, Fioroni, SMC Batteries
boudin4evr is offline   Reply With Quote
Old 08-18-2017, 07:11 AM   #531
Sean B. is offline   Reply With Quote
Old 08-18-2017, 08:25 AM   #532
Trader Rating: 15 (100%+)
Impressions at first glace:
That front end is interesting....those front arms look unbreakable!
Cool body - I like the fighter canopy look.
Diffs look to remove easily, a la XB4 etc.
Daragh Slowey
EB410/SPGT2Pro/Orca5.5/1258TGBlk/Nosram shorty
B6D/SPGT2Pro/Fantom7.5/1258TG/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is offline   Reply With Quote
Old 08-18-2017, 08:40 AM   #533
Looks like a smaller EB48.4. Zero complaints about that!
flat6 and JoeW like this.
Excellent Lipo Guide: https://rogershobbycenter.com/lipoguide/
Jason B is offline   Reply With Quote
Old 08-18-2017, 08:44 AM   #534
EbbTide's Avatar
Trader Rating: 35 (100%+)
*picks up mouth off floor* thank you Tekno! Pre orders soon I hope
:::Tekno EB410 (Under construction)::: Tekno EB48SL ::: HPI Blitz ::: Kyosho RB5 SP2 WC :::Team Durango DEX210 v2 ::: Team Durango ExoDex210 :::Tamiya TB03r/TRF418-ish :::
EbbTide is online now   Reply With Quote
Old 08-18-2017, 09:13 AM   #535
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
+1 liking the looks of the front a-arms.
So it seems the date only slightly slipped barring anything should make it in time for when indoor starts up. Hopefully supply of parts, etc. will be in full swing when the vehicle is released.
With the MSRP being $649.99, assuming the price of Tekno vehicles on there site that is crossed out is the actual MSRP, its possible using the Tekno SCT410.3 as an example that this vehicle could go for $399.99 .
If Tekno actually does push that as the price and can hit the performance and durability seen in general from there other kits, then they could have a real seller here, like big time based on what other current 1/10 4wd buggies cost.
EbbTide, JoeW and ezlight like this.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 08-18-2017, 09:34 AM   #536
Pre-orders start tonight at www.FierceRCsolutions.com
JoeW likes this.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 08-18-2017, 09:41 AM   #537
EbbTide's Avatar
Originally Posted by ezlight View Post
I'll be waiting for Amain or Tower to do their pre orders. Hopefully around the same time
Old 08-18-2017, 10:21 AM   #538
RC*PHREAK's Avatar
Trader Rating: 120 (100%+)
for front tower, could be a small CF type ala-D413, but there's no way that rear tower is CF with all those cutouts right?
i hope they're not going the SCT410 way and putting cheap stamped towers in the box and make you upgrade.
Cain likes this.
RC*PHREAK is offline   Reply With Quote
Old 08-18-2017, 10:52 AM   #539
EbbTide's Avatar
So where is the first article eh??????? I need some reading material for my afternoon!
Old 08-18-2017, 10:53 AM   #540
Tech Legend
Cain's Avatar
I think that is going to be the big thing in general to see where exactly some "savings" were made on versus what the competition offers. Very curious to see as well.
Tekno ET48 Thread Matthew_Armeni Electric Off-Road 5348 Today 11:27 AM
Team Associated RC10B64 Thread RCBuddha Electric Off-Road 2846 Today 10:58 AM
Tekno RC EB48SL Thread Matthew_Armeni Electric Off-Road 1022 11-08-2017 07:32 AM
Currently Active Users Viewing This Thread: 14 (3 members and 11 guests)
carpetburner, proliteandsc, rccars4scott
