    Hide Wikipost
Old 11-15-2017, 05:27 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB410 Thread
Last edit by: billdelong
Welcome to the EB410 Wiki page.
Basic Stats/Features:
  • Shaft drive (tapered AL for light weight and straightness)
  • Gear differentials (all 3)
  • Low Angle CVAs (with captured pins so no ejecting them!)
  • Durable stub axles with 12mm hexes and optional offset adjustments
  • Reverse bellcrank steering system
  • Quick access bulkheads (for easy diff maintenance and tuning)
  • Spllt center diff holder (for easy diff maintenance and tuning)
  • 8th scale style motor mount (for easy mesh adjustment)
  • 13mm big bore shocks
  • 3.5mm shock shafts
  • Droop screws
Videos
Servo Horns
Tekno included a plastic servo horn but also offers an aluminum one. This is highly recommended. Here's a list of servo horns that have been found to work:
Gearing:
Works out of the box for mod or 13.5.
  • Start mod gearing around 21t pinion
  • Start 13.5 gearing around 29t pinion with the stock spur (81tooth). If using a Tekin Spec R 13.5, start with a 24t pinion for medium sized indoor tracks.
  • Internal Gear Ratio: 2.5:1
  • For comparison:
  • B64 is 2.47:1
  • 22-4 is 2.4:1
  • YZ4 is 2.6:1
Wheels
  • B6/22/rb6 wheels direct fit
  • 22-4 front wheels direct fit
  • B64 front wheels will fit, but you need the +1 hexes (can use #TKR1654X, which is a +1mm hex)
  • 22 2wd front wheels will also fit, possibly a good option for carpet.
Setup Sheets and other documentation
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
Aftermarket Upgrades:
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Build Tips:
  • When fastening the steering posts with a 5.5mm socket wrench, you can back space the socket with some nuts to help drive the post into the bulk head
  • Place an alcohol swab over metal threads and drive screws through the swab to clean both sides of threads before applying thread lock
  • Use a metallic marker to indicate what fluids you have filled in your diffs for easy identification
  • Apply thin layer of grease on crown gears to help hold gaskets in place for easy hole alignment
  • Bags F and H have 2 different size set screws, be sure to use the smaller 3x3mm screws for the hexes or you may run into problems installing wheels over the hex if you use the longer 3x4mm screws
  • To make is easier to slip the o-rings on the shock cap bleeder screws, apply a drop of shock oil and slip them over a 1.5mm hex bit, then line up the bit with the screw and transfer the o-ring over using fingernails or needle nose pliers
  • Use HoBao Hyper10 3x35mm hinge pins for the rear arms
  • pinch+rotate shock caps in 17mm hex wrench to improve roundness
    More shock build tips here
Print Wikipost
Like Tree1247Likes
Old 11-27-2016, 01:03 PM   #16
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
sounds good. With the various vehicles being made in the 1/10 4wd class, I am looking forward to seeing what Tekno comes out with that will define the vehicle even if the general layout copies what the various manufacturers are going with.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-27-2016, 06:35 PM   #17
advpball's Avatar
Trader Rating: 28 (100%+)
subscribed
xray xb2 de
Johnny 5 designs xsc2
Tekno eb410
all powered by smc battery's and Motiv motors
hobbywing esc, airtronics controlled MT4s
advpball is offline   Reply With Quote
Old 11-30-2016, 06:21 PM   #18
shadaloo's Avatar
The wait is too long!!!! ><
shadaloo is offline   Reply With Quote
Old 12-01-2016, 06:36 AM   #19
oivaf1's Avatar
Good things come to those that wait
Associated SC10 4x4 (CC 3800kv- CC MMP ESC)
Associated RC10 T3 (CC 5700kv- CC Sidewinder ESC)
XTM X-Cellerator (.18 XTM nitro)
Tekno SCT 410.3 (CC 2400kv- CC MMP ESC)
oivaf1 is offline   Reply With Quote
Old 12-01-2016, 07:04 AM   #20
That's true but I had to buy a ZX6.6 to tide me over. I was sick of associateds bs.
SpongeX is offline   Reply With Quote
Old 12-01-2016, 08:05 AM   #21
Tech Legend
Cain's Avatar
hopefully the thread is updated with more info on a regular basis and not just the annoucement to keep people happy. Announcing this far out should be an interesting ride.
One thing I hope they can tell us now is what offset wheels the vehicle will use (be cool if you could use different offsets with a simple hex change)
Old 12-01-2016, 11:04 AM   #22
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Are you referring to the front or rear wheels? The offsets between the different brands are all very close, just the tube length of the axle hole is different on the rears. The fronts are also very close across the brands, very little difference in offset and the Kyosho just has a smaller axle hole. But to your question, right now all I can say is that it will have 12mm hexes front and rear.
Side note, I really hope the new IFMAR rules get enforced. Then all wheels will be standard across all cars. I don't think they've released the 2wd front offset rules yet, but it can't be long. It's kind of amazing to me that the class has been around as long as it has without having stricter wheel dimensions.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-01-2016, 11:35 AM   #23
Tech Legend
Cain's Avatar
Mainly thinking about the TLR 12mm 4wd front offset. I got some of those wheels as that is what works for the dex410v5 12mm exotek conversion. Rears would be B6 compatible here.
Old 12-07-2016, 10:23 PM   #24
justpoet's Avatar
Trader Rating: 16 (100%+)
I ran Kyosho 10th scales for a long time, still have a few. A common thing we did was the Avid rear stub axle change so that one could use the other wheel thicknesses and everything would fit for any brand 12mm rear wheel.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 12-19-2016, 12:30 AM   #25
Any more news on this?
Any peaks?
Just a small peak, come on🤑🤑🤑
Allen Drebi is offline   Reply With Quote
Old 12-19-2016, 09:50 AM   #26
Tech Legend
Cain's Avatar
with the announcement this far out, I'd be curious what they would be willing to divulge.
I do hope to see some Tekno specific takes on the layout of a 1/10 4wd buggy. From my perspective at least I'd be curious on the benefits of a more inline electronic setup (servo centered ala durango) versus the current way other designs are going.
Old 12-22-2016, 04:01 AM   #27
I am hope same layout as a buggy but smaller size
coombes is offline   Reply With Quote
Old 12-22-2016, 05:20 AM   #28
advpball's Avatar
12 mm hexes? I hope,something close to xray's xb4
xray xb2 de
Tekno eb410
Old 12-22-2016, 01:03 PM   #29
Tech Legend
Cain's Avatar
yeah i think 12mm would be a given but you never know.
It would be cool if it would be possible to do a layout similar to the eb48.3 . Or who knows, maybe something that allows more weight bias changes that what we currently see with other vehicles.
not saying thats a requirement for me, just curious on Tekno's take on things.
Old 12-22-2016, 04:27 PM   #30
For me to used my lipos out my truck that would be a good thing as I don't want buy different lipos
Team Associated RC10B64 Thread RCBuddha Electric Off-Road 2850 Yesterday 11:33 PM
Tekno ET48 Thread Matthew_Armeni Electric Off-Road 5348 Yesterday 11:27 AM
Tekno RC EB48SL Thread Matthew_Armeni Electric Off-Road 1022 11-08-2017 07:32 AM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
strodedawg
