    Hide Wikipost
Old 09-10-2017, 07:26 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC EB410 Thread
Last edit by: RCBuddha
Welcome to the EB410 Wiki page.
Basic Stats/Features:
Shaft drive (tapered AL for light weight and straightness)
Gear differentials (all 3)
Low Angle CVAs (with captured pins so no ejecting them!)
Durable stub axles with 12mm hexes and optional offset adjustments
Reverse bellcrank steering system
Quick access bulkheads (for easy diff maintenance and tuning)
Spllt center diff holder (for easy diff maintenance and tuning)
CNC milled chassis
CNC milled adjustable hinge pin braces
8th scale style motor mount (for easy mesh adjustment)
13mm big bore shocks
3.5mm shock shafts
No EClips
Droop screws
Instruction Manual
EB410 Resources
Electronics requirements:
Shorty battery
Servo (low profile OR full size will both work, low profile will have lower CG)
Motor
ESC (Wiring: shortest possible with the ESC directly at back of motor)
Receiver
Additional things we know:
Works out of the box for mod or 13.5. Start mod gearing around 21t pinion, start 13.5 gearing around 29t pinion. Additional smaller spur gear(s) will also be made available.
Internal Gear Ratio: 2.5:1
For comparison:
B64 is 2.47:1
22-4 is 2.4:1
YZ4 is 2.6:1
Wheels
B6/22/rb6 wheels direct fit
22-4 front wheels direct fit
B64 front wheels will fit, but you need the +1 hexes (can use #TKR1654X, which is a +1mm hex)
22 2wd front wheels will also fit, possibly a good option for carpet.
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree584Likes
Old 12-22-2016, 05:04 PM   #31
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
shorties have become pretty standard, so curious what they go with.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-22-2016, 06:58 PM   #32
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
12mm hexes for sure. If you check out IFMAR's rules, there's an outline for standard wheel dimensions. It looks like all the manufacturer's are heading toward that.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-25-2016, 03:18 PM   #33
justpoet's Avatar
Trader Rating: 16 (100%+)
I really look forward to this so I can easily go back to being 4wd only, even during indoor season, when running multiple classes.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 12-26-2016, 03:45 PM   #34
Tech Legend
Cain's Avatar
At one point I was a 4wd only kind of guy too. I'd be game for that depending on if an entry point was offered for 4wd like 13.5 spec and I'd pickup vehicles for the kids too.
Old 12-28-2016, 07:12 AM   #35
Tech Legend
Cain's Avatar
Will the EB410 look into doing 2 variants of the vehicle for carpet and dirt? Seems like a slipper setup is desired for carpet and gear diff for dirt from what I am hearing for other vehicles. If you could make the vehicle out of the box with both options that would be excellent.
Old 12-31-2016, 04:44 AM   #36
cadillac's Avatar
Trader Rating: 85 (100%+)
finally
thanks danny and tekno. looking foward to driving one of these race cars.
Originally Posted by Allen Drebi View Post
Any more news on this?
Any peaks?
Just a small peak, come on������
diamond mine good try
Thanks to those who support me in my RC adventures....
COW RC / DE RACING / TEKNO RC / PHATDAD RC
cadillac is offline   Reply With Quote
Old 12-31-2016, 10:27 AM   #37
hairymuffin's Avatar
Trader Rating: 93 (100%+)
Is it going to be shaft drive? Opens up the possibility of running it 2wd
hairymuffin is offline   Reply With Quote
Old 12-31-2016, 03:26 PM   #38
SnotRkt's Avatar
Yeah, that probably wouldn't work too well. I know a few guys have tried turning a few 4wd's into 2wd and they were not even close to competitive in 2wd. Super hard to drive considering they were not designed to be that way...
AE RC10B6, TD DEST210R
SnotRkt is offline   Reply With Quote
Old 12-31-2016, 05:44 PM   #39
Tech Legend
Cain's Avatar
to do that I would think you need to be on really high traction. Durango's DEX210F basically looks like the dex410v5 just in 2wd mode. It was super fast on carpet.
Old 12-31-2016, 06:06 PM   #40
RC*PHREAK's Avatar
Trader Rating: 119 (100%+)
didn't xray do that? i thought they had a truly mid motor car. i know hobby pro did. maybe it's yokomo that i'm thinking of.
RC*PHREAK is offline   Reply With Quote
Old 12-31-2016, 06:23 PM   #41
Tech Legend
Cain's Avatar
yes they did:
https://www.teamxray.com/xb4-2wd/
If the eb410 takes off for tekno, would love to see if they throw there hat in the ring with an EB210.
Old 12-31-2016, 08:23 PM   #42
Well yea for a carpet/astro racer,serpents new 4w is designed to run as a carpet 2wd, also the kyosho rz6. Is basically a zx6 Without front drive
Old 01-12-2017, 11:46 AM   #43
Trader Rating: 15 (100%+)
I hope they have same battery dimensions as EB48.3 or SCT410.3 or ET48.3...
I own three of Tekno Vehicles and I am very happy that parts are all interchangeable... one type of battery can be used all around...
Only thing was SCT410.3 had shorter battery strap compared to the 8th scale vehicles.
Please allow EB410 to have same battery dimensions as the previous vehicles
kms7852 is offline   Reply With Quote
Old 01-12-2017, 11:50 AM   #44
snwchris's Avatar
When you look at all the 4w buggies out there, they are all tight configurations and using 2s Shorty packs.
Trying to use a full size 2s lipo would not work with the layout of the chassis, length of the chassis and width.
snwchris is offline   Reply With Quote
Old 01-12-2017, 01:21 PM   #45
Tech Legend
Cain's Avatar
I'll be very curious to see how they do there own take on this buggy. Seems like al ot of the designs are converging on one particular layout. Biggest diff I see is on how durango did their servo layout (centered) versus others like xray (off to side).
Official Team Associated RC10B64 Thread RCBuddha Electric Off-Road 2638 Today 11:21 AM
Official Tekno RC EB48SL Thread Matthew_Armeni Electric Off-Road 984 09-12-2017 01:40 PM
The Official Tekno ET48 Thread Matthew_Armeni Electric Off-Road 5334 09-06-2017 09:13 PM
Currently Active Users Viewing This Thread: 8 (5 members and 3 guests)
bsp, stueys, suzukipro, tjlayzer, WonTonsChicken
