Team Associated RC10B64 Thread
#1413
On another note does anyone know of any ballcups that fit lunsford titanium turnbuckles? Since the lunsford are a little thicker than stock I cant adjust the tierods without them popping off, so I have to adjust them off the car.
#1414
I am so happy I am not the only one who was confused with this lol
I run the 3.5mm versions and you need to drill out the ball cups. The standard 3mm versions should not need drilling, just black grease to. Are them work easier.
#1415
Not cheap at about $145 at Tower Hobbies, but will last through everything you can throw at it on the B64.
On a side note, this forum has helped a ton with my 44.3 and just received the B64 last week. Looking forward to getting some trigger time with the new car when my local track dries out.
#1416
Rear diff
Hey guys maybe girls too. I was bolting the rear diff to the chassis and could not get the two long screws to go in.Ripped every thing dwn to discover I had tightened the upper bolts that hold both halves together too tight , causing the plastic to warp outward and keeping the parts from sitting flush.I did blk grease and was just kinda
Hard to screw in. s So just a heads up if your moving fast like i was . Jus tryin to get her done.:lol
Cheers
Cheers
#1417
I got the punisher series ones. They measure 2.92mm at the threads and 3.20mm after the threads. stock measure 2.92mm at the threads and 3.00mm after.
#1419
I also had the popping out problem. These new ball cups aren't as tight fitting into the ball stud like the older B5 type so they can pop out relatively easier.
I poke in a 2mm hex wrench in the hole of a ball cup and into the ball stud to stop it from turning and popping out while adjusting the turnbuckles.
#1420
The 'super duty' (what I have) are 3.5mm and the cups need to be drilled out before you can thread in a turnbuckle. They're a pain for anyone considering them, because it's very easy to hog the hole out crooked.
#1421
#1424
I've raced around Cole since he was too short to look over the track wall at Trackside. He was a talented driver then and an even greater talent now.
What an outstanding ambassador to this hobby and the epitome of what a sponsored driver should aspire to be. Always positive, helpful, kind and humble. He has never failed to say hello to me and ask how I was doing - I'm just another acquaintance, another club racer. My point is, he treats everyone fairly, regardless of ability. I've not witnessed him say an unkind, flippant remark to anyone...even on the drivers stand when a lesser driver completely delivers him to the wall.
I understand this is a bit off topic, but we always seem to make an extra effort to say negative things, because criticism is easier.
This young man is a gem in all the good ways and Team Associated is lucky to have him promoting their products.
